Kuul Sergey
Rep Power: 0 ![]() |
I start to learn OpenFOAM and try to make my own mesh for T pipe inside icofoam tutorial case. I would very thankful if somebody can describe how to deal with errors that I have in log file. CheckMesh says that mesh is OK. The pressure and velocity b.c. seem to be consistent: U "internalField uniform (0 0 0); boundaryField { inlet_F { type fixedValue; value uniform (0.1 0 0); } outlet_F1 { type zeroGradient; } outlet_F2 { type zeroGradient; } pipe { type fixedvalue; value uniform (0 0 0); } }" P "internalField uniform 0; boundaryField { inlet_F { type zeroGradient; } outlet_F1 { type fixedvalue; value uniform 0; } outlet_F2 { type fixedvalue; value uniform 0; } pipe { type zeroGradient; } }" I use default fvSchemes and fvSolution files. Log file contains the following info: "Create time Create mesh for time = 0 Reading transportProperties Reading field p Reading field U Reading/calculating face flux field phi Starting time loop Time = 0.001 Courant Number mean: 0 max: 0 --> FOAM FATAL ERROR : gradientInternalCoeffs cannot be called for a defaultFvPatchField. (Actual type fixedvalue) You are probably trying to solve for a field with a default boundary conditions. From function defaultFvPatchField<type>::gradientInternalCoeffs( ) const in file fields/fvPatchFields/basicFvPatchFields/default/defaultFvPatchField.C at line 489. FOAM exiting" The same errors are for the same mesh and b.c.even in potentialfoam Thanks, Sergey. |
IcoFoam continuity error in 2D transient simulation | finch | OpenFOAM Running, Solving & CFD | 15 | June 29, 2016 10:39 |
Foam error in icoFoam cavityClipped although the mesh is good | mgz1985 | OpenFOAM Running, Solving & CFD | 3 | May 8, 2014 10:39 |
OF15 glibc error upon successful completion of icoFoam run | aunola | OpenFOAM Bugs | 10 | April 24, 2009 03:27 |
Error while running icoFoam OpenFOAM15 | skabilan | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 00:04 |
Tow Critical Error about GCC amp icoFoam | chnrdu | OpenFOAM Installation | 4 | July 8, 2005 06:14 |
