SonicFoam error
Old   December 27, 2007, 00:01
Default WHAT IS THIS ERROR Cr
kalaiselvan
21kalee is on a distinguished road
WHAT IS THIS ERROR
Create time
Create mesh for time = 0
Reading thermodynamicProperties
Reading transportProperties
Reading field p
Reading field T
Calculating field e from T
Reading field U
#0 Foam::error::printStack(Foam:stream&)
#1 Foam::sigFpe::sigFpeHandler(int)
#2 Uninterpreted: [0xbfffe420]
#3 Foam::divide(Foam::Field<double>&, double const&, Foam::UList<double> const&)
#4 Foam::tmp<foam::geometricfield<double,> > Foam::operator/<foam::fvpatchfield,>(Foam::dimensioned<double> const&, Foam::tmp<foam::geometricfield<double,> > const&)
#5 Foam::tmp<foam::geometricfield<double,> > Foam::operator/<foam::fvpatchfield,>(double const&, Foam::tmp<foam::geometricfield<double,> > const&)
#6 main
#7 __libc_start_main
#8 __gxx_personality_v0 at /usr/src/packages/BUILD/glibc-2.3/csu/../sysdeps/i386/elf/start.S:122
Finishing FoamXCaseServer::main(int argc, char **argv)
21kalee is offline   Reply With Quote
Old   December 27, 2007, 06:05
Default It seems that in casefolder 0
Mojtaba Shahmohammadian
msha is on a distinguished road
It seems that in casefolder 0 of your case the field U is not properly defined
See U file in sonicFoam\case\0 (i.e. your initial condition for velocity field)
msha is offline   Reply With Quote
Old   December 28, 2007, 12:55
Default Are you using the GUI? i ha
Laurence Griffiths
lgriffiths is on a distinguished road
i had similar problems when using sonicFOAM and editing the input files from the GUI. But cant remember exactly what my errors were.
If that is the case try editing the files by hand from the example cases
lgriffiths is offline   Reply With Quote
Old   January 1, 2008, 06:58
Default The tutorial case given in Son
kalaiselvan
The tutorial case given in SonicFoam 'shockTube' is not working, it is showing the following error. I think it is not giving the initial conditions properly. It has a code called 'setShock.C'. The error is as follows:
Create time
Reading field p
Reading field T
Reading field U
Starting time loop
Time = 1e-05
#3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&)
#4 void Foam::divide<foam::fvpatchfield,>(Foam::GeometricF ield<double,>&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,> const&)
#5 Foam::tmp<foam::geometricfield<double,> > Foam::operator/<foam::fvpatchfield,>(Foam::tmp<foam::geometricfie ld<double,> > const&, Foam::tmp<foam::geometricfield<double,> > const&)
#6 main
Please help me with this....... Do i have to do anything with the code or......!!!!!!??????
Old   January 1, 2008, 07:20
Default You did not run it correctly -
Hrvoje Jasak
hjasak will become famous soon enough
You did not run it correctly - first, compile and run setShock (or do the equivalent with the setFieldsDict and then run the code. Currently, all your fields are zero and there's a problem with zero density and temperature, right?
Hrv
Hrvoje Jasak
Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk
hjasak is offline   Reply With Quote
Old   January 1, 2008, 18:19
Default Thank you very much for your g
kalaiselvan
Thank you very much for your guidance...
I got to know how to compile...
Old   January 2, 2008, 14:00
Default Has SonicFoam been "fixed" sin
Jon Tegner
jont is on a distinguished road
Has SonicFoam been "fixed" since 1.3?
Case under tutorials is slightly off regarding speed of shock.
/j
jont is offline   Reply With Quote
SonicFoam stvtiegh OpenFOAM Running, Solving & CFD 1 June 26, 2008 09:30
PISO in sonicFoam srinath OpenFOAM Running, Solving & CFD 0 June 20, 2008 03:21
SonicFoam and SIMPLE lgriffiths OpenFOAM Running, Solving & CFD 1 March 8, 2008 10:28
SonicFoam divphiU dimi OpenFOAM Running, Solving & CFD 3 June 25, 2007 05:47
Help me with sonicFoam marcelo OpenFOAM Running, Solving & CFD 6 December 10, 2005 02:57
