Inletoutlet
Like Tree12Likes
  • 9 Post By eugene
  • 1 Post By matejfor
  • 2 Post By Tobi
Old   December 11, 2007, 12:38
Default hi i use a simplefoam case
rengu
hi
i use a simplefoam case with a velocityinlet and a pressure outlet
i have see a lot topics about inletoutlet but i'm sorry to not understand
1/i've got sometimes a reverse flow in the outlet
i have to use an inletoutlet or an outletinlet?
if i would have got a reverse flow in the inlet?
2/for the inletoutlet,we've got to put inletoutlet for U,K,epsilon,R,nutilda and fixed value for p
is it the same if we use an outletinlet?
3/do we have got to put the same value between inletvalue & value or between outletvalue and value?
bestregards
Old   December 11, 2007, 12:50
Default For an outlet that sometimes h
Eugene de Villiers
eugene is on a distinguished road
For an outlet that sometimes has inflow:
U:outlet
type inletOutlet;
inletValue uniform (0 0 0);
value uniform (0 0 0);
Note: this does not guarantee the inflow wont become unbounded.
Basically, inletOutlet is zero gradient unless the flow is inward in which case it is fixed value (inletValue). outletInlet is zero gradient if the flow is inward and fixed value (outletValue) if the flow is outward.
eugene is offline   Reply With Quote
Old   May 10, 2010, 08:24
heavy_user is on a distinguished road
Hey There,
I used this vor velocity Outlet conditions (i am supposed to do a simple jet-flame)
outlet
type inletOutlet;
value zeroGradient;
My phi file after 1sec simulationtime shows inflow and outflow...
Is it the "value zeroGradient" that messes up or did I do anything else wrong?
    outlet
        type            calculated;
        value           nonuniform List<scalar>
150
1.18479e-09
3.57232e-09
5.98072e-09
8.4018e-09
1.0827e-08
1.32471e-08
1.56525e-08
1.80329e-08
2.03774e-08
2.26741e-08
2.49105e-08
2.70731e-08
2.91473e-08
3.11175e-08
3.29669e-08
3.46772e-08
3.62291e-08
3.76015e-08
3.8772e-08
3.97166e-08
4.04096e-08
4.0824e-08
4.09312e-08
4.07016e-08
4.01047e-08
3.91097e-08
3.76862e-08
3.58065e-08
3.34439e-08
3.05774e-08
2.71942e-08
2.32919e-08
1.88829e-08
1.39957e-08
8.67884e-09
2.99631e-09
-4.29712e-10
-1.07772e-09
0
0
-1.65135e-09
0
-1.68011e-09
0
-1.6987e-09
0
-1.76071e-09
0
-1.87588e-09
0
0
-2.10134e-09
0
-2.26909e-09
-2.32623e-09
0
-2.53649e-09
-2.59421e-09
0
-2.79956e-09
-2.86481e-09
0
0
-3.19882e-09
-3.29259e-09
0
0
-3.73476e-09
-3.86297e-09
0
0
-4.45479e-09
-4.64113e-09
0
0
-5.3705e-09
-5.60678e-09
0
0
0
-6.73772e-09
-7.01818e-09
0
0
0
-8.31723e-09
-8.64441e-09
0
0
0
-1.01283e-08
-1.03598e-08
-1.09536e-08
0
0
0
-1.29333e-08
-1.32577e-08
-1.40739e-08
0
0
0
-1.67663e-08
-1.71719e-08
-1.82183e-08
0
0
0
-2.11411e-08
-2.13324e-08
-2.19324e-08
-2.29834e-08
0
0
0
-2.50653e-08
-2.49111e-08
-2.52797e-08
-2.61831e-08
0
0
0
0
-2.80991e-08
-2.77534e-08
-2.81132e-08
-2.90127e-08
0
0
0
0
-3.11371e-08
-3.06585e-08
-3.10425e-08
-3.153e-08
-3.25285e-08
0
0
0
0
0
-3.57539e-08
-3.51538e-08
-3.54954e-08
-3.6443e-08
-3.67535e-08
0
0
0
-4.09139e-08
heavy_user is offline   Reply With Quote
Old   May 11, 2010, 07:37
matej forman
matejfor is on a distinguished road
sure it does!
value needs scalar or vector, as you set in type inletOutlet BC, which is mainly Dirichlet BC, which wants number. the keyword zeroGradient is setting Neumann type BC with a specified flux =0.
change value to a vector like (0 0 0).
good luck
matej
vsammartano likes this.
matejfor is offline   Reply With Quote
Old   May 18, 2010, 09:29
Originally Posted by matejfor View Post
sure it does!
good luck
matej
Hi matej,
thx for your answer!
It does, in deed. And if you use it correctly the solver wont accept O-Gradient.
I forgot the ; after inletValue () ; , so he didi not complain about O-gradient.
I am trying to simulate a jetflame. Unfortunately I still have inflow in the area of the cowflow using inletOutlet for a cowflow velocity below 1.5 m/sec. Is this BC generally unstable for very low velocities ???
regards!
Old   September 6, 2012, 08:11
Tobi's Avatar
Tobias Holzmann
Uutlet
type inletOutlet;
if I set up inletValue uniform (0 0 0), then I have no inlet flow couse the inlet flux is set to zero. Is that correct?
If there are faces with inlet flow and I set inletValue uniform (0 0 1), then I ll have an flow inside my domain with the velocity vector of (0 0 1).
Is that right ?
So in my case I have an vortex-breakdown after a diffuser. If I am using inletOutlet, then I get just a piece of outlet faces and the rest, where the flow should go back is fixed with (0 0 0).
Should I use "pressureInletOutletVelocity" for that case?
But I set fixed pressure at the outlet :/ ?
Any suggestions
Thanks
Tobi
mizzou and Teresa.Z like this.
Old   October 30, 2012, 16:44
Default Question about inletOutlet/outletInlet
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
[THIS SHOULD BE ITS OWN THREAD; I HAD MULTIPLE WINDOWS OPEN AND MADE A MISTAKE. ADMINS, COULD YOU DELETE THIS POST?]
Hello everyone,
I'm looking about implementing a custom boundary condition that simulates a check valve, and I believe I can base it on mixedFvPatchField like the inletOutlet/outletInlet patch.
The user guide (http://www.openfoam.org/docs/user/boundaries.php) mentioned that inletOutlet switched U and p between zeroGradient and fixedValue depending on the direction of the flow, but I have been unable to find out how this is done. From reading the source, it seems that it only switches between zeroGradient and fixedValue depending on the flux. I'd like to know where the switch happens (it may be in mixedFvPatch field, but I can't find it).
I want to know in case I need to make changes there. Or is the the U/p switch a typo/deprecated feature that was never cleaned out of the manual.
Thanks!
Last edited by mturcios777; October 30, 2012 at 16:46. Reason: Thread in wrong location
mturcios777 is offline   Reply With Quote
Old   June 8, 2015, 03:02
KateEisenhower is on a distinguished road
Uutlet
type inletOutlet;
thank you for the explanation. However, I looked at the simpleFoam/Motorbike tutorial where they defined the inlet and outlet BCs for velocity as follows:
    inlet
       type            fixedValue;
       value           uniform (20 0 0);
    outlet
        type            inletOutlet;
Isn't this over-determined than? Wouldn't it be better to set zeroGradient to the outlet?
Thank you in advance,
Kate
KateEisenhower is offline   Reply With Quote
Old   December 25, 2015, 15:44
Mohammad Reza
Bana is on a distinguished road
Hi everybody
Recently I have tried this boundary condition "inletOutlet" at the outlet patch of my case to prevent back flow but it didn't work and I had reverse flow at the outlet. I have no idea what is wrong?
Uutlet
type inletOutlet;
The same was set for K,epsilon files too.
Any insight would be very much appreciated.
Thanks in advance
Bana is offline   Reply With Quote
LinkBacks (?)
LinkBack to this Thread: https://www.cfd-online.com/Forums/openfoam-solving/59287-inletoutlet.html
Posted By For Type Date
openfoam:bc [florio] This thread Refback August 14, 2009 07:55
InletOutlet condition with arbitrary direction matteoc OpenFOAM Running, Solving & CFD 8 May 31, 2011 06:49
Cyclic inletoutlet with icoFoam sripplinger OpenFOAM Running, Solving & CFD 5 November 8, 2008 04:48
Velocity Jump at InletOutlet cliffoi OpenFOAM Running, Solving & CFD 0 September 8, 2008 05:34
TwoPhaseEulerFoam and InletOutlet boundary condition hemph OpenFOAM Running, Solving & CFD 10 January 29, 2007 09:47
TwoPhaseEulerFoam and InletOutlet BC hemph OpenFOAM Bugs 0 January 29, 2007 04:57
