Doug Hunsaker
Rep Power: 17 ![]() |
I'm trying to implement a new turbulence model. I've read through many of the other posts about implementing the k-omega model from the wiki into 1.3:
http://www.cfd-online.com/OpenFOAM_D...tml?1168380100 In 1.4, this model comes built-in, so I'd like to jump straight to implementing my own model. I've created a directory user/src/turbulenceModels/incompressible into which I copied the following directories from the OF/src/turbulenceModels/incompressible folder: laminar, lnInclude, Make, turbulenceModel, and wallFunctions. I then added my own directory called myKEpsilon which is basically a copy of the original kEpsilon src files renamed (just to learn how to link this turbulence model into the code). I then changed the Make/files file to: turbulenceModel/turbulenceModel.C turbulenceModel/newTurbulenceModel.C laminar/laminar.C myKEpsilon/myKEpsilon.C wallFunctions/nutWallFunction/nutWallFunction/nutWallFunctionFvPatchScalarField. C wallFunctions/nutWallFunction/nutStandardWallFunction/nutStandardWallFunctionFvP atchScalarField.C wallFunctions/nutWallFunction/nutStandardRoughWallFunction/nutStandardRoughWallF unctionFvPatchScalarField.C LIB = $(FOAM_USER_LIBBIN)/libincompressibleTurbulenceModels Then I tried to compile by using the ./Allwmake in the user/src/turbulenceModels directory and got the following error: doug@dell:~/OpenFOAM/doug-1.4/src/turbulenceModels> ./Allwmake Making dependency list for source file myKEpsilon/myKEpsilon.C SOURCE=myKEpsilon/myKEpsilon.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -I/home/doug/OpenFOAM/OpenFOAM-1.4/src/finiteVolume/lnInclude -I/home/doug/OpenFOAM/OpenFOAM-1.4/src/meshTools/lnInclude -I/home/doug/OpenFOAM/OpenFOAM-1.4/src/transportModels -IlnInclude -I. -I/home/doug/OpenFOAM/OpenFOAM-1.4/src/OpenFOAM/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGcc4DPOpt/myKEpsilon.o myKEpsilon/myKEpsilon.C: In constructor 'Foam::turbulenceModels::myKEpsilon::myKEpsilon(co nst Foam::volVectorField&, const Foam::surfaceScalarField&, Foam::transportModel&)': myKEpsilon/myKEpsilon.C:52: error: 'Foam::IOobject' is an ambiguous base of 'Foam::fvMesh' myKEpsilon/myKEpsilon.C: In member function 'virtual bool Foam::turbulenceModels::myKEpsilon::read()': myKEpsilon/myKEpsilon.C:97: error: 'turublenceModel' has not been declared myKEpsilon/myKEpsilon.C: In member function 'virtual void Foam::turbulenceModels::myKEpsilon::correct()': myKEpsilon/myKEpsilon.C:135: error: 'sp' is not a member of 'Foam::fvm' myKEpsilon/myKEpsilon.C:153: error: 'class Foam::volScalarField' has no member named 'k_' make: *** [Make/linuxGcc4DPOpt/myKEpsilon.o] Error 1 Any ideas? It seems to me that implementing a new turbulence model should be quite common, and therefore well documented somewhere. However, I haven't found much help on the wiki or the discussion board. Any guidance to better documentation would also be appreciated. Thanks. -doug |
Alberto Passalacqua
Rep Power: 36 ![]() ![]() |
Hello Doug,
you don't need to change all those files to implement a new turbulence model in OpenFOAM. You just need to: - Look for the model closest to the one you want to add. For example, for an incompressible k-eps model, consider the files in incompressible/kEpsilon. - Copy the kEpsilon directory and rename it. - Modify the class name (files, code). - Modify the code according to the two-equation model you want. - Create make rules (look at the content of the Make directory). This is everything for the equations part. For the wall-functions, the procedure is the same, but take the content of the wallFunctions directory. With kind regards, Alberto
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. ![]() |
Doug Hunsaker
Alberto-
Thanks a ton! It worked perfectly. -Doug |
Mojtaba Shahmohammadian
ALBERTO
I need more dtails about the steps (I mean)HOW to add a new model in details |
OpenFoam
Rep Power: 13 ![]() |
I am trying to implement the myKepsilon turbulence model to run the pitzDaily tutorial in OF 2.1.1
1) I followed all the step by step instruction given in the Wiki SIG without any changes. Wmake libso gave me following output: http@http-OptiPlex-990:~/OpenFOAM/http-2.1.1/mykEpsilon$ wmake libso wmakeLnInclude: linking include files to ./lnInclude Making dependency list for source file mykEpsilon.C could not open file RASModel.H for source file mykEpsilon.C could not open file backwardsCompatibilityWallFunctions.H for source file mykEpsilon.C SOURCE=mykEpsilon.C ; g++ -m64 -Dlinux64 -DWM_DP -Wall -Wextra -Wno-unused-parameter -Wold-style-cast -Wnon-virtual-dtor -O3 -DNoRepository -ftemplate-depth-100 -I/opt/openfoam211/src/finiteVolume/lnInclude -I/opt/openfoam211/src/meshTools/lnInclude -I/opt/openfoam211/src/turbulenceModels -I/opt/openfoam211/src/transportModels -I/opt/openfoam211/src/turbulenceModels/incompressible/lnInclude -IlnInclude -I. -I/opt/openfoam211/src/OpenFOAM/lnInclude -I/opt/openfoam211/src/OSspecific/POSIX/lnInclude -fPIC -c $SOURCE -o Make/linux64GccDPOpt/mykEpsilon.o In file included from mykEpsilon.C:26:0: mykEpsilon.H:49:22: fatal error: RASModel.H: No such file or directory compilation terminated. make: *** [Make/linux64GccDPOpt/mykEpsilon.o] Error 1 Please give me a solution...! 2)Also in the next step we need to add libs ("libmyTurbulenceModels.so"); to the controldict file of system folder. Can i add it anywhere or specifically inside any loop? |
OpenFoam
anyone here ready to help me... please... im stuck with my project..!!
Bernhard
Rep Power: 21 ![]() |
1)
The error message reads RASModel.H cannot be found. This is probably due to the fact that the reference in Make/options is not correct. Probably you should as this line -I$(LIB_SRC)/turbulenceModels/incompressible/RAS/lnInclude 2) It doesn't really matter where you put it. |
OpenFoam
Thank you Bernhard..! :-)
mykEpsilon.C:46:1: error: ‘Info’ does not name a type Now i got this error by trying to add an "info" statement into mykEpsilon.C file as explained in this tutorial. i am using OF 2.1.1. Can you help me to resolve this problem? |
#9 |
Bernhard
What is the code that gives you this error?
#10 |
OpenFoam
Plz find the attached folder for mykEpsilon solver.
#11 |
Bernhard
You're using this info statement on an unusual location, which is probably the reason that it doesn't work. I assume that it gives no difficulties if you put it inside the constructor.
#12 |
Amir-hossein Mokhtari
Rep Power: 11 ![]() |
Hi my friends
I do not know what changes should be made fvSchemes and fvSolution or eAnywhere else for use PANS turbulence model. help me. tanx sajjad alimardani. |
turbulence model | elkan | FLUENT | 3 | June 13, 2007 03:42 |
V2F turbulence model | Luke | CFX | 2 | May 19, 2007 07:38 |
changing model constants in k-e turbulence model | Sunil | CFX | 3 | October 3, 2006 12:12 |
HELP! TURBULENCE k-e OR k-omega TURBULENCE MODEL? | Mirek Kabacinski | FLUENT | 5 | August 24, 2003 22:31 |
adding turbulence models to CFX | Steve Collie | CFX | 0 | January 30, 2001 16:32 |
