URGENT NEED FOR HELP
Old   September 25, 2007, 00:32
Default My blockmeshdict is :
Mojtaba Shahmohammadian
msha is on a distinguished road
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.3 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
FoamFile
version 2.0;
format ascii;
root "";
case "";
instance "";
local "";
class dictionary;
object blockMeshDict;
convertToMeters 1;
vertices
(-0.5 0.33377906 0.01457311)
(-0.45 0.31030427 0.01354818)
(-0.4 0.28768137 0.01256044)
(-0.35 0.26612769 0.01161939)
(-0.3 0.24592454 0.0107373)
(-0.25 0.22743209 0.0099299)
(-0.2 0.21110041 0.00921684)
(-0.15 0.19746635 0.00862157)
(-0.1 0.18712052 0.00816986)
(-0.05 0.1806288 0.00788642)
(0 0.17841241 0.00778965)
(0.05 0.1806288 0.00788642)
(0.1 0.18712052 0.00816986)
(0.15 0.19746635 0.00862157)
(0.2 0.21110041 0.00921684)
(0.25 0.22743209 0.0099299)
(0.3 0.24592454 0.0107373)
(0.35 0.26612769 0.01161939)
(0.4 0.28768137 0.01256044)
(0.45 0.31030427 0.01354818)
(0.5 0.33377906 0.01457311)
(-0.5 0.33377906 -0.01457311)
(-0.45 0.31030427 -0.01354818)
(-0.4 0.28768137 -0.01256044)
(-0.35 0.26612769 -0.01161939)
(-0.3 0.24592454 -0.0107373)
(-0.25 0.22743209 -0.0099299)
(-0.2 0.21110041 -0.00921684)
(-0.15 0.19746635 -0.00862157)
(-0.1 0.18712052 -0.00816986)
(-0.05 0.1806288 -0.00788642)
(0 0.17841241 -0.00778965)
(0.05 0.1806288 -0.00788642)
(0.1 0.18712052 -0.00816986)
(0.15 0.19746635 -0.00862157)
(0.2 0.21110041 -0.00921684)
(0.25 0.22743209 -0.0099299)
(0.3 0.24592454 -0.0107373)
(0.35 0.26612769 -0.01161939)
(0.4 0.28768137 -0.01256044)
(0.45 0.31030427 -0.01354818)
(0.5 0.33377906 -0.01457311)
( -0.5 0 0)
(-0.45 0 0)
(-0.4 0 0)
(-0.35 0 0)
(-0.3 0 0)
(-0.25 0 0)
(-0.2 0 0)
(-0.15 0 0)
(-0.1 0 0)
(-0.05 0 0)
(0 0 0)
(0.05 0 0)
(0.1 0 0)
(0.15 0 0)
(0.2 0 0)
(0.25 0 0)
(0.3 0 0)
(0.35 0 0)
(0.4 0 0)
(0.45 0 0)
(0.5 0 0)
blocks
hex (42 43 22 21 42 43 1 0) (5 20 1) simpleGrading (1 1 1)
hex (43 44 23 22 43 44 2 1) (5 20 1) simpleGrading (1 1 1)
hex (44 45 24 23 44 45 3 2) (5 20 1) simpleGrading (1 1 1)
hex (45 46 25 24 45 46 4 3) (5 20 1) simpleGrading (1 1 1)
hex (46 47 26 25 46 47 5 4) (5 20 1) simpleGrading (1 1 1)
hex (47 48 27 26 47 48 6 5) (5 20 1) simpleGrading (1 1 1)
hex (48 49 28 27 48 49 7 6) (5 20 1) simpleGrading (1 1 1)
hex (49 50 29 28 49 50 8 7) (5 20 1) simpleGrading (1 1 1)
hex (50 51 30 29 50 51 9 8) (5 20 1) simpleGrading (1 1 1)
hex (51 52 31 30 51 52 10 9) (5 20 1) simpleGrading (1 1 1)
hex (52 53 32 31 52 53 11 10) (5 20 1) simpleGrading (1 1 1)
hex (53 54 33 32 53 54 12 11) (5 20 1) simpleGrading (1 1 1)
hex (54 55 34 33 54 55 13 12) (5 20 1) simpleGrading (1 1 1)
hex (55 56 35 34 55 56 14 13) (5 20 1) simpleGrading (1 1 1)
hex (56 57 36 35 56 57 15 14) (5 20 1) simpleGrading (1 1 1)
hex (57 58 37 36 57 58 16 15) (5 20 1) simpleGrading (1 1 1)
hex (58 59 38 37 58 59 17 16) (5 20 1) simpleGrading (1 1 1)
hex (59 60 39 38 59 60 18 17) (5 20 1) simpleGrading (1 1 1)
hex (60 61 40 39 60 61 19 18) (5 20 1) simpleGrading (1 1 1)
hex (61 62 41 40 61 62 20 19) (5 20 1) simpleGrading (1 1 1)
edges
patches
patch inlet
(42 42 0 21)
patch outlet
(62 62 41 20)
wall wall
(0 1 22 21)
(1 2 23 22)
(2 3 24 23)
(3 4 25 24)
(4 5 26 25)
(5 6 27 26)
(6 7 28 27)
(7 8 29 28)
(8 9 30 29)
(9 10 31 30)
(10 11 32 31)
(11 12 33 32)
(12 13 34 33)
(13 14 35 34)
(14 15 36 35)
(15 16 37 36)
(16 17 38 37)
(17 18 39 38)
(18 19 40 39)
(19 20 41 40)
wedge front
(42 43 1 0)
(43 44 2 1)
(44 45 3 2)
(45 46 4 3)
(46 47 5 4)
(47 48 6 5)
(48 49 7 6)
(49 50 8 7)
(50 51 9 8)
(51 52 10 9)
(52 53 11 10)
(53 54 12 11)
(54 55 13 12)
(55 56 14 13)
(56 57 15 14)
(57 58 16 15)
(58 59 17 16)
(59 60 18 17)
(60 61 19 18)
(61 62 20 19)
wedge back
(21 22 43 42)
(22 23 44 43)
(23 24 45 44)
(24 25 46 45)
(25 26 47 46)
(26 27 48 47)
(27 28 49 48)
(28 29 50 49)
(29 30 51 50)
(30 31 52 51)
(31 32 53 52)
(32 33 54 53)
(33 34 55 54)
(34 35 56 55)
(35 36 57 56)
(36 37 58 57)
(37 38 59 58)
(38 39 60 59)
(39 40 61 60)
(40 41 62 61)
empty axis
(42 43 43 42)
(43 44 44 43)
(44 45 45 44)
(45 46 46 45)
(46 47 47 46)
(47 48 48 47)
(48 49 49 48)
(49 50 50 49)
(50 51 51 50)
(51 52 52 51)
(52 53 53 52)
(53 54 54 53)
(54 55 55 54)
(55 56 56 55)
(56 57 57 56)
(57 58 58 57)
(58 59 59 58)
(59 60 60 59)
(60 61 61 60)
(61 62 62 61)
mergePatchPairs
this is a 2d axis-symmetry nozzle . The solver is rhoSonicFoam ,when I run the case this error appears:
Root : /home/msha/OpenFOAM/msha-1.3/run/tutorials/rhoSonicFoam
Case : nozzle
Nprocs : 1
Create time
Create mesh for time = 0
Reading thermodynamicProperties
Reading field p
Reading field T
Reading field U
Starting time loop
Time = 1e-05
Lookup interpolationScheme for interpolate(rho)
Lookup interpolationScheme for interpolate(rhoU)
Max Courant Number = 0.120569
Lookup divScheme for div(phiv,rho)
Lookup gradScheme for grad(rho)
--> FOAM FATAL ERROR :
request for surfaceScalarField phi from objectRegistry region0 failed
available objects of type surfaceScalarField are
4
weightingFactors
limiter
differenceFactors_
phiv
From function objectRegistry::lookupObject<type>(const word&) const
in file /home/dm2/henry/OpenFOAM/OpenFOAM-1.3/src/OpenFOAM/lnInclude/objectRegistryTempl ates.C at line 122.
FOAM aborting
Foam::error::printStack(Foam:stream&)
Foam::error::abort()
Foam::GeometricField<double,> const& Foam::objectRegistry::lookupObject<foam::geometric field<double,> >(Foam::word const&) const
Foam::totalPressureFvPatchScalarField::updateCoeff s()
Foam::GeometricField<double,>::GeometricBoundaryFi eld::updateCoeffs()
Foam::fvMatrix<double>::fvMatrix(Foam::GeometricFi eld<double,>&, Foam::dimensionSet const&)
Foam::fv::gaussConvectionScheme<double>::fvmDiv(Fo am::GeometricField<double,> const&, Foam::GeometricField<double,>&) const
Foam::tmp<foam::fvmatrix<double> > Foam::fvm::div<double>(Foam::GeometricField<double ,> const&, Foam::GeometricField<double,>&, Foam::word const&)
Foam::tmp<foam::fvmatrix<double> > Foam::fvm::div<double>(Foam::GeometricField<double ,> const&, Foam::GeometricField<double,>&)
rhoSonicFoam [0x8059060]
__libc_start_main
__gxx_personality_v0
Aborted
msha is offline   Reply With Quote
Old   September 25, 2007, 03:24
Default the problem lies in your fvSch
pbo
Patrick Bourdin
pbo is on a distinguished road
the problem lies in your fvSchemes file, not in blockMeshDict.
It seems you declared an unvalid (unexisting) scheme in fvSchemes, as suggested by your error output:
4
weightingFactors
limiter
differenceFactors_
phiv
pbo is offline   Reply With Quote
Old   September 28, 2007, 03:16
Default Hi Thank you for reply R u
Hi
Thank you for reply
R u sure? I have just copied fvSchemes file from an existing tutorial case without any changes.
Is it possible that the problem was been arisen from boundary condition or initial values?
Best regards.
Urgent, Urgent, a UDF problem, PLEASE HELP!!! Max FLUENT 1 September 24, 2010 20:30
plz help its urgent garima chaudhary FLUENT 0 September 25, 2007 05:28
need urgent help please! shirrant FLUENT 0 September 25, 2007 03:35
need paper very urgent humanity,very urgent,urgent mohamed FLUENT 0 August 9, 2006 11:40
tmerge urgent urgent jessica FLUENT 4 July 15, 2006 13:37
