September 6, 2007, 10:57 |
hi people, well again me. i st
robert maduta
Rep Power: 17 |
hi people, well again me. i still have the same problem, which is like this. if i do a turbulent channel flow simulation i get good results with k-epsilon and reynolds stress models. if i do the same simulation with any nonlinear model i always get profils which are completely non-axissymmetric. for example all the turbulent kinetic energy is on one side and the velocity profile has its peak more near one side than on the centreline. i am wondering if someone else had a problem like this before and maybe can help me. as inlet and outlet boundary condition i chose the pressureoutlet boundary condition, because the pressure is the only thing i know.
September 6, 2007, 11:39 |
and something else i forgott.
robert maduta
Rep Power: 17 |
and something else i forgott. can plz someone tell where i can find the iplementation of y+ in openfoam. i want to change it somehow so that it is easier to get a y+ over 100 for a channel flow.
September 6, 2007, 11:45 |
Could not resist it - I just l
Hrvoje Jasak
Rep Power: 33 |
Could not resist it - I just love this code:
scalar yPlus = Cmu25*turbulenceModel::y_[patchi][facei]*sqrt(k_[faceCelli])/nuw[facei]; Can it be easier? /home/hjasak/OpenFOAM/OpenFOAM-1.4.2/src/turbulenceModels/incompressible/wallFun ctions/wallFunctionsI.H Enjoy, Hrv
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
September 6, 2007, 11:58 |
yeah that part i also found...
robert maduta
Rep Power: 17 |
yeah that part i also found....but how can i change it, so that the values for y+ which are calculated are a lot higher with the same grid? i am not that much into c++, i just tried to multiply the expression by a high constant. it is not really working. after changing or edditing the file do i only have to save it, or do i have to compile it?
September 6, 2007, 14:11 |
Srinath Madhavan (a.k.a pUl|)
Rep Power: 21 |
Forgive me if I'm mistaken, but I always thought that Y+ was a function of the distance of the first grid point from the wall. In other words if you need to maintain a different Y+ range, you can change your mesh accordingly. Why does anyone need to tinker with header files unless they want to modify the way it is calculated? do i have to compile it? Almost certainly, if you've edited any source file. You need to either build just the library that the source contributes to (*.so) or if the source is directly linked to your solver you need to rebuild your solver as well. |
September 6, 2007, 14:25 |
well here is the thing...y+ ha
robert maduta
Rep Power: 17 |
well here is the thing...y+ has to be over 100 for openfoam in combination with wall functions. if you take a channel flow with water (v = e-6, Re = 10000) it is nearly impossible to get such an unfine mesh so that the wallfunctions are valid.for height of 0.2 m even if i take 10 elements it is too fine :-)
so i thought about changing the hole wallfunction-y+ implementation. but i am not sure. i think i get weird values with the nonlinear models because of the bad y+-grid combination i have. the other models seem to be unsensitive against it. |
September 6, 2007, 14:36 |
It isn't a good idea to change
Rep Power: 21 |
It isn't a good idea to change the way Y+ is calculated. If I remember my turbulence modeling correctly, standard wall functions take care of the near-wall region and bridge the gap between k-epsilon solution in the bulk and the wall itself. So the wall functions are essentially based on some assumptions one of which is to ensure that the first resolved grid point away from the wall and should not fall in the laminar sub-layer or the buffer layer. Which means that if you change the way Y+ is calculated, you will no doubt relax some of the assumptions that were used to formulate the wall functions. Logic suggests that you will then also need to change the wall functions itself. Am I making sense here?
September 6, 2007, 14:46 |
sure that makes sense....but f
robert maduta
Rep Power: 17 |
sure that makes sense....but for example i found another standard wall function expression......i thought that this other one could work better. also y+ has to be over 40 in that one. but well maybe its also another problem why the nonlinear models are not working :-)
May 10, 2012, 11:09 |
#9 |
Aniko Rakai
Rep Power: 16 |
Hi all!
It's been a while since you wrote here but did someone find out what is wrong with the nonlinear models? Until now I did not check for the wall functions for nonlinear models but with nonlinearKEShih I also have problems. I am also trying to use them, first some tests with a boundary layer flow. The results are different from the analytical solution and I thought maybe because from the original Shih paper mentioned in the code the dirac terms, i.e. the double dot products or the gradU are not implemented. Also in the cubic I find no such terms. I think they are responsible to make the contraction of the resulting Re-stress tensor equal to 2/3 k but I am not exactly sure if it can cause this behaviour mentioned here before. Did someone have the same feeling when comparing with the paper? Aniko |
May 5, 2018, 21:32 |
#10 | |
Huang Xianbei
Rep Power: 13 |
It's a long time since your post. In fact, I also find such problems with non-linear RASModel, in OF-2.3.0 with NonlinearShih and LienCubic. The results were wired when I simulated the Taylor-Couette flow. The Taylor vortex never existed between the walls and the flow tended even to go through the periodic patches! I will go on with the topic. If you have got some idea, please inform me. Thank you! Xianbei |
