August 10, 2007, 14:58 |
Is it possible to have two ins
Srinath Madhavan (a.k.a pUl|)
Rep Power: 21 |
Is it possible to have two instances of lamd on one 4 CPU machine (for instance). Then one could run two 2-CPU jobs independent of each other.
August 10, 2007, 15:12 |
Got it. Using varying values o
Rep Power: 21 |
Got it. Using varying values of the environment variable LAM_MPI_SESSION_SUFFIX before running lamboot.
August 10, 2007, 15:37 |
Hey Srinath,
Quick question
Philippose Rajan
Rep Power: 25 |
Hey Srinath,
Quick question... what happens if you have a 4 CPU machine, and you run lamboot once... And then, run "mpirun -np 2 ......." two times? Wont the Linux kernel automatically assign two processors for one "mpirun", and the other two for the second "mpirun" ?? I very often run one parallel run (with two processors...using one "mpirun -np 2 ...."), and one normal run on a Quad Core. I have found that leaving one processor in a Quad Core free actually speeds things up, compared to a parallel run which uses all 4 processing cores....would you able to confirm that for me ? Have a nice evening! Philippose |
August 10, 2007, 16:36 |
Rep Power: 21 |
And then, run "mpirun -np 2 ......." two times? Wont the Linux kernel automatically assign two processors for one "mpirun", and the other two for the second "mpirun" ?? Frankly, I don't know! I think it depends on how many nodes you specified in the machines file you supplied to lamboot. With regards to the quad-core, my analysis can be found here[1]. Hope that helps! [1] http://www.cfd-online.com/OpenFOAM_D...tml?1181823034 |
August 10, 2007, 17:05 |
Hmmmm..... When you use "mpiru
Philippose Rajan
Rep Power: 25 |
Hmmmm..... When you use "mpirun -np <n>", you dont need to specify the number of nodes for the lamboot command....
I usually use a file called "machines", in which I put in the IP of the machine I use... example: 127.0.0.1 Thats it... and then... "lamboot -v machines" Specification of the number of nodes is done in the "mpirun -np <n>" command. Anyway... shall try this out on Monday... no access to the Quad core over the weekend. Have a nice weekend! Philippose |
August 10, 2007, 17:10 |
I'm pretty sure of one thing t
Rep Power: 21 |
I'm pretty sure of one thing though. One instance of the LAM daemon (lamd) cannot support two separate MPI instances. Otherwise I wonder why would they provide for a LAM_MPI_SESSION_SUFFIX variable?
Anyways, I eagerly look forward to your quad-core results. |
