Including user defined eqations
Old   June 28, 2007, 09:03
Default I am trying to include a new e
Tomislav Sencic
tsencic is on a distinguished road
I am trying to include a new equation in dieselEngineFoam.
I included:
fvScalarMatrix sootEqn
solve
fvm::ddt(rho, soot)
+ fvm::div(phi, soot)
0.5*mag(U)
In createFields.H I defined the field by:
volScalarField soot
IOobject
"soot",
runTime.timeName(),
mesh,
IOobject::MUST_READ,
IOobject::AUTO_WRITE
mesh,
dimensionedScalar("zero", dimensionSet(1,-3,-1,0,0,0,0), 0.0)
It compiles, but at the beginning of the run I recive the error:
--> FOAM FATAL ERROR : valueInternalCoeffs cannot be called for a calculatedFvPatchField.
You are probably trying to solve for a field with a calculated boundary conditions.
From function
calculatedFvPatchField<type>::valueInternalCoeffs( const tmp<scalarfield>&) const
in file fields/fvPatchFields/basicFvPatchFields/calculated/calculatedFvPatchField.C at line 136.
FOAM exiting
What does it mean? How can I solve it?
Tomislav
tsencic is offline   Reply With Quote
Old   June 28, 2007, 10:18
Default What it means is: "I created a
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
What it means is: "I created a field with no defined boundary conditions. This is OK. But you want me to solve an equation without BCs. This is not OK"
Get rid of the last parameter for your soot field. Instead create a soot file in your 0 directory with intial-BC(==0), dimensions AND boundary conditions
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
gschaider is offline   Reply With Quote
Old   June 29, 2007, 07:40
Default Thanks, it helped. But, whe
Tomislav Sencic
Thanks, it helped.
But, when I set the soot dimensions in the 0 directory to:
dimensions [0 0 0 0 0 0 0];
I obtain:
--> FOAM FATAL ERROR : incompatible dimensions for operation
[soot[1 -3 -1 0 0 0 0] ] == [scal[0 0 0 0 0 0 0] ]
Where else could be defined the soot dimensions, where does come from the [soot[1 -3 -1 0 0 0 0] ] dimension?
Old   June 29, 2007, 08:41
Default soot is the dimension of the r
Assistant Moderator
Bernhard Gschaider
soot[1 -3 -1 0 0 0 0] is the dimension of the right hand side (density per second) - the ddt ad div seem to be consistent. What seems to be wrong is the dimension of the right hand side. You've got to add a dimensioned scalar that has the right dimension (but think about the physical meaning of that)
Old   July 2, 2007, 11:17
Default I meant to say "left side" in
Assistant Moderator
Bernhard Gschaider
I meant to say "left side" in my last post. rho has dimension [1 -3 0 0 0 0 0] ddt adds [0 0 -1 0 0 0 0] with your undimensioned soot the resulting dimension is [1 -3 -1 0 0 0 0]
How many iterations does the linear solver need to get to "internalField uniform 0;"? What are the boundary conditions for soot? Try without a source term, but with an inhomogenous initial distribution
of soot.
Old   July 3, 2007, 07:07
Default OK, I got the dimensions. I
Tomislav Sencic
I do not know the number of iterations because in the log file "soot" is never mentioned, there is no something like:
BICCG: Solving for soot, Initial residual = 1, Final residual = 1.53774e-08, No Iterations 5
Could this be the key of the problem?
I tried the other things you suggested, but without result.
The boundary conditions are:
boundaryField
piston
type zeroGradient;
liner
type zeroGradient;
cylinderHead
type zeroGradient;
cyclic
type cyclic;
value uniform 0;
Old   July 3, 2007, 07:10
Default ON, so you've got a field with
Hrvoje Jasak
hjasak will become famous soon enough
ON, so you've got a field with zero gradient or cyclic b.c.-s all the way around and I suspect a uniform internal field. Do you have any sources or sinks in the equation or does the current solution satisfy the equations already?
If it does, OpenFOAM won't bother solving for it.
Hrv
Hrvoje Jasak
Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk
hjasak is offline   Reply With Quote
User defined bc anja OpenFOAM Running, Solving & CFD 20 June 6, 2008 12:12
User-Defined Fan Socrate FLUENT 0 March 28, 2007 10:25
User Defined GUI Frederik FLUENT 0 June 23, 2006 16:12
user defined scalars ramesh FLUENT 1 June 11, 2004 17:25
user defined viscosity solomon FLUENT 0 July 13, 2003 21:09
