Error turbFoam
Old   June 21, 2007, 06:22
Default Hi, i have modified the turbf
jackdaniels83 is on a distinguished road
i have modified the turbfoam solver in a way that i can calculate forces in selected patches.
the problem is that the solver aborts and gives the following message:
Create time
Create mesh for time = 0
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model kEpsilon
Reading the patch force dictionary
Reading force solver data
Starting time loop
Time = 0.01
Courant Number mean: 0 max: 0
DILUPBiCG: Solving for Ux, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG: Solving for Uy, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 2.34397e-13, No Iterations 1
AMG: Solving for p, Initial residual = 1, Final residual = 0.0483882, No Iterations 1
time step continuity errors : sum local = 0.000553499, global = -8.75052e-07, cumulative = -8.75052e-07
AMG: Solving for p, Initial residual = 0.314146, Final residual = 0.0218164, No Iterations 1
time step continuity errors : sum local = 0.000303637, global = 4.96421e-05, cumulative = 4.8767e-05
Calculating Pressure Forces....
Area of patch cock = 820.124
Pressure force on patch cock = -1.02047e+08 N
Total Pressure Force in cock moving direction = -1.02047e+08 N
Calculating Wall Shear Forces....
Shear Force on patch cock = 0 N
Total Shear Force in cock moving direction = 0N
Total Force in cock moving direction = -1.02047e+08N
#0 Foam::error::printStack(Foam:stream&)
#1 Foam::sigFpe::sigFpeHandler(int)
#2 Uninterpreted: [0xffffe420]
#3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&)
#4 void Foam::divide<foam::fvpatchfield,>(Foam::GeometricF ield<double,>&, Foam::GeometricField<double,> const&, Foam::GeometricField<double,> const&)
#5 Foam::tmp<foam::geometricfield<double,> > Foam::operator/<foam::fvpatchfield,>(Foam::tmp<foam::geometricfie ld<double,> > const&, Foam::GeometricField<double,> const&)
#6 Foam::turbulenceModels::kEpsilon::correct()
#7 main
#8 __libc_start_main
#9 Foam::regIOobject::readIfModified()
Can someone tell me what i have done wrong, because the problem is the same when i use the normal tubfoam solver, too.
Daniel
jackdaniels83 is offline   Reply With Quote
Old   June 21, 2007, 07:24
Default When i turn off turbulence or
When i turn off turbulence or choose the laminar turbulence model the problem is gone. What do i have to do, to get the turbulence run?
Daniel
Old   June 21, 2007, 07:35
Default Check you initial and boundary
Alberto Passalacqua
Check you initial and boundary conditions for k and epsilon.
Regards,
Alberto
Alberto Passalacqua
Old   June 21, 2007, 07:42
Default Thanks for you answer! He
Here are my conditions:
object k;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
dummyPatch3
type zeroGradient;
dummyPatch4
type zeroGradient;
dummyPatch5
type zeroGradient;
in
type fixedValue;
value uniform 0.00375;
out
type zeroGradient;
cock
type zeroGradient;
object epsilon;
dimensions [0 2 -3 0 0 0 0];
boundaryField
dummyPatch3
type zeroGradient;
dummyPatch4
type zeroGradient;
dummyPatch5
type zeroGradient;
in
type fixedValue;
value uniform 0.00377;
out
type zeroGradient;
cock
type zeroGradient;
object boundary;
dummyPatch3
type wall;
physicalType wallFunctions;
startFace 445651;
nFaces 3898;
dummyPatch4
type wall;
startFace 449549;
nFaces 768;
dummyPatch5
type wall;
startFace 450317;
nFaces 9312;
in
type patch;
physicalType pressureInlet;
startFace 459629;
nFaces 1154;
out
type patch;
physicalType pressureOutlet;
startFace 460783;
nFaces 414;
cock
type wall;
startFace 461197;
nFaces 508;
I can't see anything wrong with them...
Daniel
Old   June 21, 2007, 07:59
Default The initialization of the inte
Alberto Passalacqua
The initialization of the internal fields is wrong.
With
you're setting the initial values of k and eps to zero in you whole domain.
Regards,
Alberto
Alberto Passalacqua
Old   June 21, 2007, 08:05
Default Thanks a lot Alberto, I've
I've choosen the same values like for the inlet now and it works, how can i calculate that values for the internal field for different complex parts?
Daniel
Old   June 21, 2007, 08:21
Default If you haven't detailed inform
Alberto Passalacqua
If you haven't detailed information, just use an average value of what you expect k and epsilon to be or the inlet value, as you're doing.
Assuming you simulate for a time long enough, the final result is not influenced by the choice of your initial condition.
With kind regards,
A.
Alberto Passalacqua
Old   June 21, 2007, 08:25
Default Thanks for your fast reply. No
Thanks for your fast reply. Now it is working and i can go on with my tests,
Regards,
Daniel
Old   June 25, 2007, 16:57
Default Hello Daniel, A Good day to
Philippose Rajan
philippose will become famous soon enough
Hello Daniel,
A Good day to you!
I just happened to be looking through these messages, when I realised that you seem to be using a version of the solver "turbForceFoam", which incorporates rigid body motion (as of now in 1-D).
It would be great if you could give me feedback regarding this modified solver.... have you made any interesting additions to the solver?
Since I am currently making changes to it, it would be nice if you could let me know if there are any specific problems, or improvements which you have come up with while using it.
Awaiting a reply!
Enjoy!
Philippose
philippose is offline   Reply With Quote
Old   June 26, 2007, 05:11
Default Hi Philippose, yes i am using
Hi Philippose,
yes i am using the turbforcefoam solver. I have modified it because i don't need the body motion. I am only interested in the forces calculated by the solver.
I am simulating hydraulic manifold valves for a automatic gear box and want to have the forces in the direction of the cock motion.
Now a little question: How long has the case to be run to get god values for k and epsilon? I am trying with 100 steps from time 0 to 1e-5 with deltaT = 1e.7.
Regards,
Daniel
Old   June 27, 2007, 05:35
Default Another question: the force
  #11
Another question:
the forces are only written as single values in a file, how can i write them as a field like p or u, so that i can view them in paraView?
Daniel
Old   June 27, 2007, 14:22
  #12
Philippose Rajan
Hello Daniel,
A Good day to you!
Its interesting that you are from Baden Wuerttemberg :-)! I guess your town cant be too far from where I am :-)!
Anyway.... as for your questions:
a. Regarding convergence of k and epsilon.... this is dependent on many factors.... for example.... how accurate a solution are you expecting.... how complex the geometry is.... what kind of meshes you are using.... the boundary conditions, etc...etc.... :-)!
I run cases between around 300,000 to around 1.5 Million pure tetrahedral cells, and I have found that "k" is the slowest of all the variables to converge. Epsilon and the velocity variables are more or less the same, and pressure converges the fastest.
My simulations are normally run till an initial residual of around 1e-06, and this normally takes upto around 0.001 seconds, with a variable deltaT which hovers around 4e-07.
b. Since turbForceFoam was written to incorporate the capability of rigid body motion into the fluid solver, I do not calculate the force as a field. Rather, I take a sum of the pressure at each boundary cell, multiplied by the area of the face of that cell which is on the boundary. This results in a single vector, which is the total force on a given patch.
In order to save the force as a field, you will have to create a vector field similar to the velocity ("U") field, and instead of calculating the sum, you need to calculate the force on each patch cell face.
I have not tried this yet, so I cannot give you the exact code to write... but I dont foresee it as being too difficult.
Have a nice day!
Philippose
Problem with turbFoam sivakumar OpenFOAM Pre-Processing 7 August 28, 2008 04:45
Turbfoam error danie OpenFOAM Running, Solving & CFD 2 July 30, 2008 07:45
TurbFoam hsieh OpenFOAM Running, Solving & CFD 12 July 23, 2008 07:40
Basic turbFoam error message sippycup OpenFOAM Running, Solving & CFD 14 May 18, 2008 23:45
Some hints with turbFoam giampippetto OpenFOAM Running, Solving & CFD 0 March 9, 2006 02:21
