Moving a rigid body in a fluid
Old   April 3, 2007, 15:12
Default Hi! I am kind of new to openf
Dominique Turmel
doum is on a distinguished road
Hi!
I am kind of new to openfoam, but it looks like this is what I need!
I am a master student, working in natural risks. I am trying to model a "submarine rockfall". In few words : A big rock (more than 1m of diameter) fall from a submarine cliff and travel in the water. It may bounce on the cliff, roll, slide, or have a "freefall" behavior.
I would like to model the simplest case : a sphere that may have only freefall behavior or bouncing behavior.
Some of you seems experts in CFD modeling. What is the simplest way to do what I want to do? (or if no simplest way, what should I do!)
Thanks a lot!
P.S. Sorry for my english! My first language is french!
doum is offline   Reply With Quote
Old   April 4, 2007, 05:59
Default By far the easiest method in O
Eugene de Villiers
eugene is on a distinguished road
By far the easiest method in OpemFOAM would be to model the rock as a very very viscous fluid using the inteface capturing VOF method. I'm not sure how accurate this would be since fluids generally don't support elastic deformation (i.e. no bouncing), but I guess it would be a good starting point.
After this I would suggest you contract an experienced OpenFOAM developer to add the additional stress terms to the transport equations. Or keep learning and do so yourself!
I vaguely recall a project about baking cookies and residual stresses from ~5 years ago. Perhaps someone still has that code.
eugene is offline   Reply With Quote
Old   April 4, 2007, 09:09
Default Thanks a lot! This seems to b
Dominique Turmel
Thanks a lot!
This seems to be a good starting point!
In fact, I don't think I will have to introduce elastic deformations on the rock. For the "collisions", I will try to use what we call restitution coefficients (ratio between in and out velocity). When the mass will be very close to the cliff, there will be an apparent contact force, but the block won't deform...
About rigid-body solution? billpeace CFX 8 April 23, 2006 18:49
rigid body motion antonello FLUENT 3 July 28, 2004 03:25
What type of boundary for a moving rigid body? Ryan FLUENT 5 April 13, 2004 11:55
rigid body simulation nabeel mohsin FLUENT 0 September 4, 2003 02:46
HELP: unsteady solving of Moving body in fluid Quain Tchew Main CFD Forum 1 May 21, 2003 23:21
