Question concerning the heat capacity Cp
Old   July 6, 2006, 07:36
Default Currently I'm using sonicTurbF
Dihao Tang
tangd is on a distinguished road
Currently I'm using sonicTurbFoam for my simulation. I'm trying to implement the heat capacity Cp which is temperature dependent as an input variable for the boundary condition. Now the case in sonicTurbFoam is that Cp is treated as a constant in thermophysicalProperties. Could anybody give some suggestion how to implement the temperature-dependent Cp? Thank you so much!
tangd is offline   Reply With Quote
Old   July 10, 2006, 03:25
Default I guess the temperature-depend
Dihao Tang
I guess the temperature-dependent Cp should be written by myself. If I had to write the code for it, is there some code already existed so that I can reference? Thanks!
How to provide specific heat capacity ratio? Hrishikesh FLUENT 1 July 18, 2009 20:27
Enthalpy in apparent heat capacity method Feng FLUENT 0 October 13, 2006 13:42
Cn specific heat capacity changes with Temperatur? lightgas CFX 4 July 7, 2006 06:51
increasing the specific heat capacity Viatcheslav FLUENT 6 November 30, 2005 09:09
heat capacity=f(T) in solids Micha Siemens 0 July 18, 2003 06:48
