Putting submesh field values into field on parent mesh
Old   June 19, 2006, 09:37
Default Hi, I've created a subMesh
Helmut Roth
helmut is on a distinguished road
I've created a subMesh from a cellSet of a parent mesh and solved for some fields on the subMesh. Now I'd like to transfer the values of those subMesh fields back to fields on the parent mesh. Any ideas on how to do this in OpenFoam?
Thanks and best regards,
Helmut
helmut is offline   Reply With Quote
Old   June 20, 2006, 02:29
Default mapFields or modify subsetM
Mattijs Janssens
mattijs is on a distinguished road
mapFields
or modify subsetMesh to store the cellMap(), faceMap() etc from fvMeshSubset and use these to map back.
These maps are from the subsetted mesh back to the original
mattijs is offline   Reply With Quote
Old   June 20, 2006, 07:31
Default fvMeshSubset gives you the map
Hrvoje Jasak
fvMeshSubset gives you the mapping data and the interpolation functions - yo should not need anything else.
Hrv
Hrvoje Jasak
[mesh manipulation] Mesh refinemt by scalar field zurdo OpenFOAM Meshing & Mesh Conversion 3 January 9, 2008 05:15
How to get Pressure field from velocity field qunwuhe@hotmail.com Main CFD Forum 4 October 14, 2007 07:38
Calculated Values in scalar field arkangel OpenFOAM Running, Solving & CFD 0 June 28, 2007 07:53
How to input Magnetic Field values in ESTER Code? Amit Gupta Phoenics 0 September 21, 2006 13:38
field by field decomposition vs. component-wise zhanglei Main CFD Forum 0 January 5, 2001 09:06
