Transonic jet simulation
Old   January 24, 2006, 13:40
Default Hi everybody, I am a beginn
Magnus Åberg
magnus is on a distinguished road
Hi everybody,
I am a beginner OpenFOAM user with a wish of doing an investigation of the acoustics generated by a transonic jet through a nozzle. For this I tried rhoSonicFoam with initial conditions for the velocity field given by an incompressible solution of the same case.
I then start the compressible case using a really low Courant number. After some 6000 iterations the calculation still looks good but then blows up very quickly.
This is the case both when i use higher order vanLeer but also when I tried the upwind scheme.
As I am a beginner user maybe this is not the right solver that I have choosen.
Does anybody have ideas/suggestions of what I can do?
Thanks for your kind answers!
/Magnus
magnus is offline   Reply With Quote
Old   January 25, 2006, 03:20
Default It is usually something physic
Mattijs Janssens
It is usually something physical happening that causes this blowing up after such a long time of stable running. Check the solution just before it blows up. Maybe there is something happening (inflow?) at the outlet? Is the initial shock (from starting from an incompatible solution) reaching the outlet. Or is the solution finally going supersonic?
Old   January 25, 2006, 03:38
Default IC and BC should always be an
Shiuh-Hwa Shyu (Steven)
sshyu is on a distinguished road
IC and BC should always be an issue. A bad IC might eventially kills your calculation. But sometimes, the code might get survived and give you final solution. This would depend on the physical problem. As for BC, it would either give you a wrong solution, or just blow up. In my experience, the FDM tends to survive for quite a long period of time before it blows up, or gives you wrong solution. As for the spectral-like method, it would diverge quite quickly. This is a good thing though.
sshyu is offline   Reply With Quote
Old   January 25, 2006, 10:17
Default Many Thanks for your input!
Magnus Åberg
I restarted my calculations, using first order schemes, with zero for pressure and velocity in the interior. I can see that the problem comes from the inlet patch
I looked throught my boundary conditions and I found that maybe I misunderstand the meaning of pressureInletVelocity. What is the value i need to specify there?
I want to specify totalpressure and totaltemperature what is the correct velocity BC for this setup?
/Magnus
Old   January 25, 2006, 10:19
Magnus Åberg
/Magnus
Old   February 1, 2006, 11:54
Default Hi, I realize that what i w
Magnus Åberg
I realize that what i wanted to do is not implemented.
So I ask instead if somebody can give me a suggestion of which solver to use for a transonic turbulent jet with moving shocks. The inlet is subsonic and I whish to use LES for closure.
Thank you
/Magnus
Old   February 1, 2006, 12:23
Default coodles with "transonic true
Eugene de Villiers
eugene is on a distinguished road
coodles with
"transonic true;"
added to the PISO subdictionary.
No way it will capture shocks properly though.
eugene is offline   Reply With Quote
Old   February 11, 2006, 14:57
Default Could I modify sonicFoam (merg
Thomas Hauser
thauser is on a distinguished road
Could I modify sonicFoam (merge with coodles) to create a LES solver for compressible flow with shocks? Or are there better ways?
thauser is offline   Reply With Quote
Old   June 14, 2006, 02:43
Default I have the same question as wh
Dihao Tang
tangd is on a distinguished road
I have the same question as what Magnus asked:
"I want to specify totalpressure and totaltemperature what is the correct velocity BC for this setup?"
I also use coodles, hope somebody can give me the answer, thanks!
tangd is offline   Reply With Quote
AVL Fire transonic simulation Ainil Main CFD Forum 1 August 24, 2010 15:53
transonic simulation with OpenFoam Shyam Main CFD Forum 0 June 12, 2008 02:39
Simulation of transonic flow over NACA0012 airfoil MSc Student Siemens 2 August 9, 2006 13:49
Compressible transonic airfoil RAE2822 simulation Stefano Siemens 9 June 21, 2006 10:47
Transonic DNS cfd-freak Main CFD Forum 1 April 16, 2003 12:39
