SimpleFoam pipe flow velocity blowup
Old   June 9, 2006, 16:52
Default Hi, In order to make sure I
Greg Zink
gzink is on a distinguished road
In order to make sure I'm running OpenFoam correctly, I am running simpleFoam for a straight pipe with a small pressure differential that should induce a constant velocity through the pipe.
I use pressureInlet and pressureOutlet to specify the pressures on either end of the pipe and initialize the internal flow to the velocity I expect from Bernoulli.
What I keep seeing is that the velocity is constant through the pipe, but the magnitude just keeps rising with each iteration, and never converges. I can run this case in Fluent, and it converges very quickly.
Does anyone have any idea why the velocity field would increase in this way?
Greg Z.
gzink is offline   Reply With Quote
Steady pipe flow mean velocity higher than inlet velocity anita OpenFOAM Running, Solving & CFD 7 September 25, 2012 05:35
which pipe has the biggest velocity? Song CFX 1 December 26, 2008 12:44
Temperature blowup for with 6-DOF falling object Andrew Wick FLUENT 3 October 16, 2005 15:56
SimpleFoam for laminar flow hsing OpenFOAM Running, Solving & CFD 3 April 14, 2005 14:39
Velocity and turbulence measurements for a pipe John Grimm Main CFD Forum 2 January 29, 2002 12:37
