Can microgravity simulations be performed by FOAM
Old   February 20, 2006, 22:09
Default I want to know the operations
zoujianfeng
zou_mo is on a distinguished road
Send a message via MSN to zou_mo
I want to know the operations needed for micro-gravity simulation.
Thanks.
zou_mo is offline   Reply With Quote
Old   February 20, 2006, 22:35
Default That's a painfully general que
brooksmoses
That's a painfully general question. It's general enough that there isn't a useful answer, besides referring you to the User's Guide.
Since the User's Guide doesn't explicitly refer to micro-gravity conditions, the following may be useful as well:
Most OpenFOAM solvers do not include a gravitational force, and thus are valid for micro-gravity flows without any changes. For the solvers which do include gravity, there is usually a way to set the direction and strength of the gravity vector; for instance, in the Breaking-Dam example from the user's manual, the gravity force vector is set in the "environmentalProperties" file in the "constant" subdirectory of the case directory. Other solvers will have the gravity vector stored in a similar location. To do a micro-gravity simulation, simply change the force vector's magnitude to zero (or the appropriate very small number).
Beyond that simple change, everything else in the User's Guide will apply directly.
How are a transient simulations performed?? Luk Main CFD Forum 0 October 19, 2007 10:09
2D Simulations Uros CFX 7 February 24, 2007 08:04
Why sometimes momentum predictor step is not performed liu OpenFOAM Running, Solving & CFD 10 July 3, 2005 06:56
LES simulations Ben Andrus FLUENT 3 December 4, 2004 09:23
Simulations of CDA Ernesto Benini Main CFD Forum 0 November 21, 2000 06:30
