Motion interFoam and icoFoamAutoMotion
Old   January 18, 2006, 08:20
Default What is the difference between
Frank Bos
lr103476 is on a distinguished road
What is the difference between the implementation of mesh motion between the following two solvers: interFoam and icoFoamAutoMotion.
Thanks, Frank
Frank Bos
lr103476 is offline   Reply With Quote
Old   January 18, 2006, 08:49
Default From the mesh motion side, non
Hrvoje Jasak
hjasak will become famous soon enough
From the mesh motion side, none really. I don't know which version you're looking at, but now both solvers should have the run-time selectable mesh motion and have the option of using the automatic mesh motion solver.
Algorithmically, the icoFoamAutoMotion solver uses the relative flux formulation of the pressure equation whereas interFoam works wih absolute fluxes.
Enjoy,
Hrv
Hrvoje Jasak
Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk
hjasak is offline   Reply With Quote
Old   January 18, 2006, 09:31
Default I am running OpenFOAM 1.2.
Frank Bos
As far as I can see, the icoFoamAutoMotion solver takes care of the motion using the motionSolver.C class. The way the unsteady boundary motion could be implemented is by applying transient boundary conditions on motionU.
On the other hand, interFoam uses the movingFvMesh.C class to move/deform the mesh. According to this implementation it is possible to write a user defined class, like movingFlapFvMesh or movingInkjetFvMesh. Then the main motion parameters, like frequency and amplitude, can be run time selectable. In fact I want to implement the movingFlapFvMesh into icoFoamAutoMotion, is that possible?
Is my understanding correct, or not?
Thanks, Frank
Frank Bos
Old   January 18, 2006, 09:44
Default Yup, just rip out the movingFv
Hrvoje Jasak
Yup, just rip out the movingFvMesh stuff form the interFoam solver and put it into (your own version) of icoFoamAutoMotion, update the call syntax, make sure moving flap is linked in and you're in business. I have already done so for the next release.
Hrv
Hrvoje Jasak
InterfaceCompression interFoam sega OpenFOAM Running, Solving & CFD 4 May 25, 2016 10:29
InterFoam floooo OpenFOAM Running, Solving & CFD 0 November 3, 2008 11:00
Modeling shaking motion Vs Rotational motion jaswi OpenFOAM Running, Solving & CFD 2 July 19, 2007 22:44
Evaporation in interfoam khleitz OpenFOAM Running, Solving & CFD 0 May 25, 2007 03:31
IcoFoamAutoMotion missing in my distribution vinz OpenFOAM Running, Solving & CFD 6 November 17, 2006 00:58
