SimpleFoam nutilda an R
Like Tree11Likes
  • 1 Post By danie
  • 1 Post By ngj
  • 1 Post By eugene
  • 3 Post By markusrehm
  • 5 Post By Tobi
Old   May 26, 2008, 04:41
Default SimpleFoam nutilda an R
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
What are nutilda and R for when solving using simpleFoam?
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
Old   May 26, 2008, 04:52
Default nuTilda is the kinematic turbu
Daniela
danie is on a distinguished road
nuTilda is the kinematic turbulent viscosity
rafa13 likes this.
danie is offline   Reply With Quote
Old   May 26, 2008, 05:12
Default and R is the Reynolds Stress t
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
and R is the Reynolds Stress tensor.
Best regards,
Niels
rafa13 likes this.
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
ngj is offline   Reply With Quote
Old   May 26, 2008, 07:18
Default Hey thanks for the quick reply
linnemann's Avatar
Niels Nielsen
Hey thanks for the quick reply :-)
Linnemann
Old   May 26, 2008, 16:30
Default Hi everybody! concerning R
Leonardo Nettis
dinonettis is on a distinguished road
Hi everybody!
concerning R and nutilda I would like to know something more as well!!
-First of all, should I iniatilize them with a value different from 0??
-Second, in simpleFoam when I use the k-epsilon model I've read on this forum that they are not necessary. Why??
Thank you in advance.
dino
dinonettis is offline   Reply With Quote
Old   August 17, 2008, 10:55
Default Hi, I am running a k-eps
Ivan Lau
ivanwhlau is on a distinguished road
I am running a k-epsilon RNG model (simepleFoam).
turbulent, incompressible air flow around a rectangular low rise 3D building
I have set the following initial values of inlet:
U
k=1/2(UI)^2
epsilon=Cmu^0.75*k^1.5/l
nuTilda=Cmu&K^2/epsilon (is it correct?)
Do I need to set the value of R (currently, zeros)? If so, what should that be?
Please kindly advise.
Regards,
Ivan
ivanwhlau is offline   Reply With Quote
Old   August 17, 2008, 11:07
Default Hi, all, In regards to bo
Ivan Lau
Hi, all,
In regards to boundary conditions, besides inlet,
I have the following: outlet, wall, ground, external
zeroGradient for every parameters
U=0,0,0 at wall & ground
p=0 at outlet
Should I set k as zero at wall?
Re~=10^5
Pleas kindly help.
Regards,
Ivan
Old   August 18, 2008, 05:57
Default You only have to set the field
Eugene de Villiers
eugene is on a distinguished road
You only have to set the fields used by your solver/model. nuTilda and R are not used by the RNG model. For high-Re models k at the wall is normally set to zero gradient.
aow likes this.
eugene is offline   Reply With Quote
Old   August 18, 2008, 06:14
Default Thanks a lot, Eugene.
Ivan Lau
Old   March 9, 2009, 05:44
Default Hi openfomers, I am trying to
Gerard Mouokue
gerado is on a distinguished road
Hi openfomers,
I am trying to understand the implementation of simpleFoam but I have a problem with nuTilda.
can someone tell me the difference between nut and nuTilda ?
Regards
Gerard
gerado is offline   Reply With Quote
Old   March 13, 2009, 05:22
Default HI Gerard, I dont know the
  #11
Rishi .
hellorishi is on a distinguished road
HI Gerard,
I dont know the details, however I am also interested.
Just a clue: check the C++ documentation:
http://foam.sourceforge.net/doc/Doxygen/html/incompressible_2kEpsilon_2kEpsilon_ 8C-source.html
00120 nut_(Cmu_*sqr(k_)/(epsilon_ + epsilonSmall_))
and some details...
http://foam.sourceforge.net/doc/Doxygen/html/classFoam_1_1incompressible_1_1RASM odel.html
Yet to read it completely. Post here if you find answers to your questions.
Regards
Rishi
hellorishi is offline   Reply With Quote
Old   January 18, 2011, 03:08
Markus Rehm
markusrehm is on a distinguished road
an answer is given here
http://www.cfd-online.com/Forums/ope...t-nutilda.html
Markus
palmerlee, chengyu and aow like this.
markusrehm is offline   Reply With Quote
Old   October 8, 2014, 12:14
Altan
alyucel is on a distinguished road
Originally Posted by dinonettis View Post
Hi everybody!
dino
i'am wondering too
and where is using openFoam R and nuTilda?
alyucel is offline   Reply With Quote
Old   October 9, 2014, 08:14
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
  • nut is not necessary to declar if you want standard settings. OpenFOAM sets up your nuTilda -> nut itselfs and you will get this field in every saved iteration step.
  • R is not necessary anymore
Source code:
$FOAM_SRC/turbulenceModel/incompressible/ras/kEpsilon
    nut_
        IOobject
            "nut",
            runTime_.timeName(),
            mesh_,
            IOobject::NO_READ,
            IOobject::AUTO_WRITE
        autoCreateNut("nut", mesh_)
tmp<volSymmTensorField> kEpsilon::R() const
    return tmp<volSymmTensorField>
        new volSymmTensorField
            IOobject
                "R",
                mesh_,
                IOobject::NO_READ,
                IOobject::NO_WRITE
            ((2.0/3.0)*I)*k_ - nut_*twoSymm(fvc::grad(U_)),
            k_.boundaryField().types()
vaina74, sadjad.s, aow and 2 others like this.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Problems with the RSM in simpleFoam sberg OpenFOAM Running, Solving & CFD 10 February 25, 2014 19:39
What is phi in simpleFoam ehsan_vaghefi OpenFOAM Running, Solving & CFD 7 September 29, 2013 11:00
Using simpleFoam with water nico765 OpenFOAM Running, Solving & CFD 7 October 23, 2007 05:39
SimpleFoam woes msrinath80 OpenFOAM Bugs 2 April 13, 2007 10:15
What does the variables R and nuTilda represent in the icofoam ztdep OpenFOAM Running, Solving & CFD 2 August 18, 2005 22:21
