Lagrangian track not support empty patch interaction?
Like Tree1Likes
  • 1 Post By su_junwei
Old   March 24, 2009, 19:54
Default Lagrangian track not support empty patch interaction?
su_junwei's Avatar
su junwei
su_junwei is on a distinguished road
Send a message via MSN to su_junwei
Dear All
It seems that the Lagrangian track methods in OpenFOAM don't support the empty patch. How to treat particle behaviors the 2D geometry with empty patch with these methods?
Junwei
sourav90 likes this.
su_junwei is offline   Reply With Quote
Old   March 25, 2009, 02:15
niklas's Avatar
Niklas Nordin
niklas will become famous soon enoughniklas will become famous soon enough
hmmm....tracking in 2D. not a good idea if you ask me.
And here's why.
Lets look at the for instance the momentum (mass and energy will suffer the same problem).
When we calculate the momentum gain/loss for the particle and transfer that to the gas the change in gas velocity will depend on the thickness of your 2D-slab.
If you make the slab very thick the gas will hardly feel the influence of the particles because the gas volume in 1 cell will be quite high.
On the other side, if you make it very very thin, the volume of the gas can be even less than the volume of the particle, hence the transferred momentum to the gas will result in a very fast respons on the gas.
If you do a 2d calculation on wedge you will have similar problem, a drop far from the axis of symmetry will influence the gas less than if its close to the center.
I hope that illustrates the problem.
niklas is offline   Reply With Quote
Old   March 25, 2009, 05:47
su_junwei's Avatar
su junwei
Exactly Niklas
But there are some cases where a 3D simulation is more computational demanding especially for dense disperse flow, fluidized bed for instance. A possible way is using a pseudo 3D simulation with a direction with thickness equaling to the particle diameter.
If we treat the front and back plane as a wall, it will of course influence the continuous phase flow. It is better to make it an empty patch and do the simulation. In such a situation, removing the normal component of the velocity when encountering the empty patch can be a feasible way.
Junwei
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
CheckMeshbs errors ivanyao OpenFOAM Running, Solving & CFD 2 March 11, 2009 02:34
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
