March 30, 2009, 20:16 |
Plane channel flow
Rep Power: 17 |
I'm a very begginer in OpenFOAM. I'm just trying to simulate a laminar plane channel flow using icoFoam. I got the conditions from the analytical solution and fvSchemes and fvSolution from Cavity tutorial. My problem is that Courant number keeps growing until explode. The setup is attached. Thanks in advance. |
March 31, 2009, 05:00 |
Here are two test-cases that may help you: http://openfoamwiki.net/index.php/Ma...leSimple2DFlow http://openfoamwiki.net/index.php/Bl...Flow_Benchmark Regards, Jose Santos |
March 31, 2009, 20:14 |
Rep Power: 17 |
Obrigado, Jose Santos!
I've got it to work. I had a problem in the BC and my time step was too high. |
June 4, 2009, 17:07 |
Sven Winkler
Rep Power: 17 |
Hi Rodrigo,
I try to solve the same case and I think I also have some problems with my boundary conditions, especially with the one for the outlet. Could you please post your boundary conditions? That would be great! Thanks a lot! |
June 5, 2009, 10:17 |
Sven Schweikert
Rep Power: 17 |
Hello
I also started with this simple case to collect experiments in OF. Copied the cavity tutorial and generated new mesh with new BC and initial conditions to solve with icoFoam a 2D channel case. Now I am wondering - in folder .../case/0/ the dimension definition for pressure p? -> dimensions [ 0 2 -2 0 0 0 0] -> this is no pressure!? Anybody an idea about this background? Thanks & regards |
June 5, 2009, 10:33 |
p is the kinematic pressure. If you multiply it by the density, you'll get Pascal units (kg/ms^2). Regards, Jose Santos |
June 5, 2009, 12:19 |
Rep Power: 17 |
Hello.
You have my setup attached. Hope it helps. |
June 5, 2009, 15:51 |
Sven Winkler
Rep Power: 17 |
@santos
O.K. p is the kinematic pressure, I understand this. But what should I do if I don't want to set-up a dynamic pressure but a static pressure? If I just change the dimension, I get an error compiling it, which says, that the dimensions don't match. So, what do I have to do if I want to initialize my flowfield with a static pressure? |
June 5, 2009, 19:47 |
#9 |
Rep Power: 17 |
Hello Sven,
p is the static pressure divided by density (this is what Santos means with kinematic pressure). You should not change units to set a static pressure, just divide the value by the constant density and set the resulting value. |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
VOF modelling open channel river flow | Matthew Roberts | FLUENT | 6 | July 31, 2009 12:52 |
Channel flow set up | Jung | Main CFD Forum | 2 | November 21, 2007 06:51 |
Channel flow - Galerkin method | Ingo Meisel | Main CFD Forum | 1 | November 15, 2002 05:15 |
channel flow.. | R.D.Prabhu | Main CFD Forum | 0 | July 14, 1998 00:22 |
