a question of turbulent mixing layer
Old   April 2, 2009, 09:21
Default a question of turbulent mixing layer
JJY
Jianying Jiao
JJY is on a distinguished road
Hi
I am new to OpenFoam and i want to calculate turbulent mixing layer.
The free-stream Mach number M=0.2;
Re=50;
temperature T=273.15K;
pressure p=100000pa;
equal and opposite free-stream speed U;
I don't know to use which solver?
How to simulate it?
Thank you
Best regards
Jianying
JJY is offline   Reply With Quote
Old   April 3, 2009, 03:59
Antonio Attili
wizard1301 is on a distinguished road
You could use rhoTurbFoam or coodles the first for RANS, the second for LES modelling. These are compressible solvers, probably you can use incompressible solvers if your Mach number is low.
Bye
Antonio
wizard1301 is offline   Reply With Quote
Old   April 3, 2009, 10:08
JJY
Jianying Jiao
Hi Antonio
Thank you for your answer.
How do I set initial velocity and other conditions?
Are they like conditions of channelOodles?
Thank you
Jianying
Old   April 3, 2009, 11:14
Antonio Attili
Hi Jianying
You should start with one of the tutorial that you can find in the user/run/tutorial folder. Try with the coodles tutorial (it's a simple step with imposed inlet velocity) and try to change boundary condition; then try to change geometry, modifying the blockMeshDict in the costant directory of the tutorial/coodles dir and running the blockMesh utility.
In the userguide you can find a step by step guide to do something similar for the cavity tutorial.
Antonio
Old   April 3, 2009, 11:25
JJY
Jianying Jiao
Hi Antonio
I will try it .
Jianying
Question on turbulent dispersion force in momentum Emmery FLUENT 0 December 12, 2007 10:31
Look for a paper about DNS of Mixing layer by lele leaf Main CFD Forum 1 June 3, 2006 05:39
Turbulent Boundary Layer Reference Erika Johnson FLUENT 2 January 27, 2006 09:10
Validation of shear mixing layer using kwsst Samuell FLUENT 0 September 9, 2003 22:27
Grid for turbulent mixing layers Jason Main CFD Forum 1 March 11, 2000 21:56
