buoyantSimpleFoam error message
Old   April 10, 2009, 04:47
Default buoyantSimpleFoam error message
Kyian Barrat
Khelian973 is on a distinguished road
Hello Foamers,
Im a beginner. I use OpenFoam 1.5 on Ubunto...
I would like to use the solver buoyantSimpleFoam for a case, so I started the tutorial. But i have this error message when i launch the solver
Create time
Create mesh for time = 0
Reading environmentalProperties
Reading thermophysical properties
Selecting thermodynamics package hThermo<pureMixture<constTransport<specieThermo<hC onstThermo<perfectGas>>>>>
Reading field U
Creating turbulence model
Selecting RAS turbulence model kEpsilon
kEpsilonCoeffs
Cmu 0.09;
C1 1.44;
C2 1.92;
C3 0.85;
alphah 1;
alphak 1;
alphaEps 0.76923;
Calculating field g.h
Creating field pd
Starting time loop
Time = 1
DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 4.95158e-06, No Iterations 3
DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 7.32619e-06, No Iterations 3
DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 4.95158e-06, No Iterations 3
#0 Foam::error:rintStack(Foam::Ostream&) in "/DATA/Softs/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/DATA/Softs/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#2 ?? in "/lib/libc.so.6"
#3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/DATA/Softs/OpenFOAM/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM.so"
#4 void Foam::divide<Foam::fvsPatchField, Foam::surfaceMesh>(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&) in "/DATA/Softs/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/buoyantSimpleFoam"
#5 Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > Foam:perator/<Foam::fvsPatchField, Foam::surfaceMesh>(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::tmp<Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> > const&) in "/DATA/Softs/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/buoyantSimpleFoam"
#6 main in "/DATA/Softs/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/buoyantSimpleFoam"
#7 __libc_start_main in "/lib/libc.so.6"
#8 Foam::regIOobject::readIfModified() in "/DATA/Softs/OpenFOAM/OpenFOAM-1.5/applications/bin/linux64GccDPOpt/buoyantSimpleFoam"
Floating point exception
I think it's probably due to the installation of the librairies, but im not really into it, so i would like to have a confirmation and the solution to solve the problem..
Thanks
Khelian973 is offline   Reply With Quote
Old   April 11, 2009, 13:22
Mattijs Janssens
mattijs is on a distinguished road
Is this the hotRoom tutorial? Did you try 1.5.x?
http://www.cfd-online.com/Forums/ope...tml#post209324
mattijs is offline   Reply With Quote
Old   April 14, 2009, 10:12
Kyian Barrat
Thanks Mattijs for your answer.
Yes it's the hotRoom tutorial. I succeed to do it with buoyantFoam, but with buoyantSimpleFoam, i have the message i posted, even after i change the mesh configuration.
And no i didnt try the 1.5.x version. Maybe i will when i have time, but i prefer stay in 1.5 first.
Old   April 16, 2009, 04:15
Marco Müller
marico is on a distinguished road
Hi all,
I'm having also trouble with buoyantSimpleFoam! I get the error message, too. It vanishs if the initial values for internal field of "p" is set to 10000 (As the boundary conditions). Is this a failure in tutorial setup???
In my understandig p is absolute pressure (for calculation of density?) and pd the relative pressure?!
Marco
marico is offline   Reply With Quote
Old   April 16, 2009, 04:45
Kyian Barrat
im not sure it's a problem from the tutorial... I understand the p and pd exactly like you. it looks normal to initialise the pression field with the absolute pression. but it's not so obvious when you are a beginner lol
BuoyantSimpleFoam tutorial error erydj OpenFOAM Installation 2 June 23, 2011 05:46
BuoyantSimpleFoam amitshah OpenFOAM Running, Solving & CFD 4 June 3, 2009 06:04
buoyantSimpleFoam Message error Khelian973 OpenFOAM Running, Solving & CFD 8 June 2, 2009 13:26
BuoyantSimpleFoam Channel problem prashant24983 OpenFOAM Running, Solving & CFD 7 September 18, 2008 04:50
Error in buoyantSImpleFoam solver antopnieta OpenFOAM Running, Solving & CFD 2 January 18, 2008 07:30
