xulixian
Rep Power: 17 ![]() |
am puzzled by the simulation of H2/air combustion using CFX. I could not get the expected temperature, the maximum flame temperature is always below 980K. I use stoichiometric mixture of hydrogen and air, but after the reaction, their always a lot of O2 left. It looks like a lean combustion. And the in the beginning of the simulation, CFX tell me
" Reactants and products do not balance for a reaction. | Products will not be scaled for conservation of mass. | | | | Reaction : Hydrogen Oxygen | | Products scale = 2.7750 " My reaction chamber is a tube with 0.2 mm in diameter and 1.55mm in length, the inlet diameter is 0.1mm. Adiabatic wall condition.The boundary is the following: Inlet: 300K, 6 m/s, Mass fraction H2: 0.02857 O2: 0.22857 N2: constraint, Outlet: static pressure 1 bar Initial temperature: 1000K I use the default stoichiometric coefficient, so the reaction is H2 + 0.5 O2 = H2O, Pre-Exponential Factor : 3.12e7 [m^1.5 s^-1 mol^-0.5] **(the value in Fluent is 9.87e8, I change the value since I have to switch the uint from "kmol" in Fluent to "mol" in CFX.) Temperature Exponent : 0 Activation Energy : 3.1e+04 j/mol. In the begining of the simulation, I use the time step of 1 e-7 s, then I increase the time step to 1 e-5 s. Can you help me to diagnose the simulation? I appreciate for your help. |
Kerstin Heinen
you should read the thread about wall heat flux in CFX answered by Bernhard. ;-) Seems to become more and more people stumbling in the wrong forum. So we can start having fun now? ;-) |
xulixian
Hi Kerstin,
thank you for your reply. Acctually I proposed my question in CFX forum, but I didn't get any answers from them, so I tried my luck here, and it looks not bad! ^_^ I will check the thread you mentioned. thanks again. regards, Lixian |
which s/w for turbine simulation, Fluent/ CFX ? | Parag | FLUENT | 0 | March 8, 2007 02:28 |
Simulation of turbine cascade in CFX. | Jonas Pedro Caumo | CFX | 0 | December 9, 2006 13:54 |
Problems modeling CONTACT SURFACES with CFX Mesh | MAldaz | CFX | 2 | September 12, 2006 17:10 |
problems of turbo simulation in CFX-10 | Qiang | CFX | 0 | September 11, 2006 23:19 |
Problems in CFX 5.5.1 | Sulviyanti | CFX | 6 | February 7, 2003 16:46 |
