buoyantSimpleFoam with LaunderSharmaKE
Old   April 14, 2009, 04:59
Default buoyantSimpleFoam with LaunderSharmaKE
Marco Müller
marico is on a distinguished road
Hi All,
I'm trying to simulate the case described here:
http://cfd.mace.manchester.ac.uk/cgi...&0&0&0&unknown
The W direction is resolved with 6 elements.
The solution progresses well except of Turbulence equations!! Residuals
there stick at 0.1-0.4... (Low-Re has to be used!!?)
The result is that velocities are much too small (~0.3 mm/s), but qualitatively right. Heat Transfer is without convection...
Turbulence quantities have zeroGradient BC's, for "p" and "pd" I wasn't sure what to use. Currently it is "wallBuoyantPressure, uniform 1 bar" for p (calculated, uniform 1 bar" gave same results) and "fixedFluxBuoyantPressure, uniform 0" for pd!
Any suggestions?
Is there any other solver/turbulence model for that problem??
Thanks in advance
Marco
marico is offline   Reply With Quote
Old   April 16, 2009, 01:53
Marco Müller
Ok, some update:
with 1e-10 for BC values for turbulence quantities it converges better, but the flow is even slower!!
Marco
Old   April 21, 2009, 06:17
Default Update
Marco Müller
Hi again,
I hope that someone can help. First of all, I made a failure in mesh: The thin direction now is resolved with 150 cells (LowRE), the height is 250 cells and the third direction 5 cells. That sounds stupid, but for CFX (sorry) it works perfect and some professionals (Menter..) chose an even worser resolution...
Here are the compared results:
(CFX results with SST model)
As you can see, the results are the same for 50% height and 10% height with OpenFOAM. The flow is too slow, turbulence switched of seems to change nothing...
Here is the case:
BuoyantCavity.tar.gz
Thanks for your help
Marco
BuoyantSimpleFoam tutorial error erydj OpenFOAM Installation 2 June 23, 2011 05:46
BuoyantSimpleFoam amitshah OpenFOAM Running, Solving & CFD 4 June 3, 2009 06:04
buoyantSimpleFoam Message error Khelian973 OpenFOAM Running, Solving & CFD 8 June 2, 2009 13:26
buoyantSimpleFoam error message Khelian973 OpenFOAM Running, Solving & CFD 4 April 16, 2009 04:45
BuoyantSimpleFoam Channel problem prashant24983 OpenFOAM Running, Solving & CFD 7 September 18, 2008 04:50
