June 14, 2009, 15:52 |
gasoline spray simulation using dieselFoam
Rep Power: 17 |
Dear All,
Has anybody ever used the dieselFoam solver to simulate a gasoline spray/combustion? I just wonder which fuel did you use in your simulation? I could not find any fuel type with similar properties to gasoline in the fuel library in dieselFoam, like isooctane (C8H18)... I appreciate any suggestions from you. Thanks a lot, -Jason |
June 16, 2009, 11:35 |
Rachel Vogl
Rep Power: 16 |
Hi Jason,
http://foam.sourceforge.net/doc/Doxy...2d8a6a643.html I guess that is the liquid you are looking for? |
June 16, 2009, 15:10 |
Rep Power: 17 |
Thank you very much, Rachel.
-Jason |
June 19, 2009, 02:22 |
Rachel Vogl
Rep Power: 16 |
Hi Jason,
Try changing to CHEMKINFile "$FOAM_CASE/chemkin/chem.inp"; CHEMKINThermoFile "$FOAM_CASE/chemkin/therm.dat"; |
June 22, 2009, 12:00 |
Gasoline injection and chemkin.inp setup
Simone Malaguti
I'm trynig to simulate a gasoline injection starting from the aachenBomb tutorial. I need to change the chemkin.inp file in order to match with octane fuel propreties. May you suggest to me the costant values I have to use into the file to balance the reaction? Thank you very much for your help Simone |
June 23, 2009, 05:02 |
#6 | |
Niklas Nordin
Rep Power: 29 |
balancing C, H and O atoms. C: x = b -> b= x H: y = 2c -> c = y/2 O: 2a = 2b + c -> a = b + c/2 = x + y/4 |
June 23, 2009, 06:52 |
Simone Malaguti
Thank you very much, but my question was too general. I meant the three Arrhenius coefficients used in the chem.inp: I'm not able to find the correct values for octante reaction and at the same time I'm not able to understand the meaning of the last two variable of the file (I mean the two line "FORD" in the reported code for the eptane below).
ELEMENTS H O C N AR END SPECIE C7H16 O2 N2 CO2 H2O END REACTIONS C7H16 + 11O2 => 7CO2 + 8H2O 5.00E+8 0.0 15780.0! 1 FORD / C7H16 0.25 / FORD / O2 1.5 / END |
June 23, 2009, 07:05 |
Niklas Nordin
Rep Power: 29 |
http://www.cvd.louisville.edu/Course/Chemical Vapour Deposition/Manuals/chemkin/chemkin1chemkin.pdf
page 29 the correct values are trickier... |
June 25, 2009, 15:51 |
#9 |
Rep Power: 17 |
have tried changing to "$FOAM_CASE/chemkin/therm.dat", but the problem is still there. I think the "therm.dat" file does not contrain any data of C8H18. I assume I need to use another thermophysical model rather than "hMixtureThermo<reactingMixture>". Do you guys have any further suggestions?
April 23, 2016, 03:01 |
diesel foam
#10 |
HIMANSHU AGARWAL
I want to use C10H22 in place of C7H16 for this what changes i have to do
July 10, 2016, 01:55 |
#11 |
mubashar
Hello Jason,
I have the same issue, i want to use iso octane rather than heptane; can you guide me how to do this. |
Gasoline Spray Modeling | sekkizhar | Siemens | 4 | May 31, 2017 10:23 |
Gasoline Spray | sekkizhar | STAR-CD | 7 | April 17, 2009 07:31 |
Star crashed with spray simulation, please help! | Jimmy Fox | Siemens | 4 | October 17, 2006 16:09 |
problems with unsteady spray simulation | Mathias | FLUENT | 1 | July 20, 2006 16:13 |
Gasoline spray modelling | Enrico | Main CFD Forum | 2 | May 26, 1999 15:38 |
