Comparison of axisymmetric case, Starccm+ and OpenFOAM |
June 26, 2009, 09:15 |
Comparison of axisymmetric/2D case, Starccm+ and OpenFOAM
Niels Nielsen
Rep Power: 27 |
Hi all
I've decided to post some of my results regarding comparing Starccm+ and OpenFOAM on a axisymmteric case for a ship nozzle. First of all here are some basics. Profile length (chord) ~1.95m transportproperties water @ 20C nu=1.004e-6 high Re > 1e7, Turbulence model Realizable K-e freestream velocity 6.16667m/s reference pressure 0Pa Turbulent kinetic energy (estimate) = 1.5*(Intensity (5-10%) * u_avg)^2 = 1.5 * (0.1*6.16667)^2 = 0.57 (Fluent Manual) Turbulent dissipation rate (estimate) = (mu_t = rho * Cu *(k/e)^2) => e= (k*sqrt(rho)*sqrt(Cu))/mu_t. Where mu_t can be estimated to be 2 orders of magnitude larger than the molecular viscosity, Fluent Manual, This gives an e=17.08. First of all I wanted to see how it would compare in a strict 2D case so i created a mesh using Salome - export to UNV. Converted it to OpenFOAM using ideasUnvToFoam, transformPoints -scale "(0.001 0.001 0.001)" to get it in meters, split the mesh into patches using autoPatch 45. Move the new mesh with split patches to constant/polymesh mv 1/polyMesh/* constant/polyMesh/ To create a fine enough grid for the y+ I used the refineWallLayer command and split the first cell adjacent to the nozzle wall into 5 (see pictures) to do this I created this small script. #!/bin/bash echo "step 1" refineWallLayer dyse 0.833 mv 1/polyMesh/* constant/polyMesh/ echo "step 2" refineWallLayer dyse 0.694 mv 1/polyMesh/* constant/polyMesh/ echo "step 3" refineWallLayer dyse 0.578 mv 1/polyMesh/* constant/polyMesh/ echo "step 4" refineWallLayer dyse 0.482 mv 1/polyMesh/* constant/polyMesh/ echo "step 5" refineWallLayer dyse 0.402 mv 1/polyMesh/* constant/polyMesh/ Then I set up the correct boundary conditions for the OpenFOAM case and set it to itterate, after 300 or so itterations i changed the divergence scheme from upwind to a higher order. (one at a time, change 1 then iterate 20 and change the next). This is done all on the fly. div(phi,U) Gauss linearUpwindV cellLimited Gauss linear 1; div(phi,k) Gauss linearUpwind cellLimited Gauss linear 1; div(phi,epsilon) Gauss linearUpwind cellLimited Gauss linear 1; Using yPlusRAS after it has converged gives y+ between 25-170 average 100 so it should be ok. to get lift and drag I used the following in my controlDict functions ( forces { type forceCoeffs; functionObjectLibs ("libforces.so"); patches (dyse); //Name of patche to integrate forces rhoInf 998.2; CofR (0 0 0); liftDir (0 1 0); dragDir (1 0 0); pitchAxis (0 0 0); magUInf 6.16667; lRef 1.0; Aref 1.0; } ); To get it in Starccm+ I converted the mesh into a Fluent mesh foamMeshToFluent. I converted the Mesh to 2D in Starccm+. The original Mesh is 1m thick in the z-direction. In Starccm+ i used the exact same setup for the boundary conditions. A screenshot of the force monitor setup. Both cases ran for about 2000 iterations. Foam Residuals Starccm+ Residuals. Results 2D StarCCM+ - OpenFOAM - diff C_d 0.03924 0.0389159 - -0.83% The drag is spot on but the lift is way off, any hints here?C_l 0.015874 - 0.0545671 - 70.9% Now the funny part comes when changing to an axisymmetric case. 2D for Starccm+ and a wedge shape geometry for OpenFOAM. Running the exact same setup I have to change the Aref in the controlDict since my mesh is not 1m in the z-direction (from what I can read in the forums), but rather sin(2.5)*2=0.087239. Center of the profile is ~2m up from the axis. If I set the Aref to 1 in controlDict for the axisymmetric case it produces a drag coefficient that if you take the OpenFOAM drag and divide by the Starccm+ drag 0.00661139/0.075348=0.087745 which is ~0.087239. If I use this Aref I get similar results, but my wedge is 5degree in angle and not 2.5degree. Results axisymmetric StarCCM+ - OpenFOAM - diff (star/foam) C_d 0.075348 - 0.0754326 - 0.1121% Does anyone else have experience with forces and axisymmetric cases? Because I don't think this can be correct.C_l -0.17969 - -0.156871 - -14.54% Last edited by linnemann; June 29, 2009 at 06:31. Reason: typos |
June 26, 2009, 10:23 |
Niels Nielsen
Rep Power: 27 |
Some of the pictures haven't been uploaded, will do on monday,
Regards |
June 28, 2009, 03:19 |
autoPatch 45
amin
Rep Power: 17 |
Hi
what is autopatch? how does it work? thanks |
June 28, 2009, 11:21 |
Niels Nielsen
Rep Power: 27 |
autoPatch does the same as "Split by angle" in Starccm+.
So it takes one patch and splits it into several patches, the input is an angle so autoPatch 45 splits the one patch into several where the angle exceeds 45degree Regards |
June 29, 2009, 04:30 |
Niels Nielsen
Rep Power: 27 |
Update with some more results.
The drag is almost spot on from the 2D case but it seems the lift is somewhat off. Here are some scalar plots from the comparison (2D) and from what I can deduct the results are very similar, but have a look and please feel free to comment. The needed information is really about axisymmetric cases and the force coefficients. |
June 29, 2009, 04:31 |
Niels Nielsen
Rep Power: 27 |
September 10, 2009, 03:29 |
Mads Reck
Rep Power: 17 |
Hi!
Interesting. I am also struggling a bit, validating forces for a 2D cylinder with OpenFOAM. Did you manage to get this working? /Mads
Online free airfoil-mesher for OpenFOAM here |
September 10, 2009, 14:44 |
Matvey Kraposhin
Rep Power: 21 |
I'm not sure, but i think, that OpenFOAM case doesn't converge. Preesure residual too big.
Why did you switch from upwind to linear? |
May 5, 2010, 08:33 |
how export from salome 2d axi-symmetric case
#9 |
sasha
Rep Power: 16 |
Hi all,
can somebody please explain how export from Salome 2d axi symmetric case to OpenFoam i am creating a surface mesh and then "revolve" him, but when i tried to convert .unv file i have "cannot open file file: /home/caelinux/Desktop/axi/system/controlDict at line 0. From function regIOobject::readStream(const word&) in file db/regIOobject/regIOobjectRead.C at line 66. FOAM exiting" i think something wrong with creation of mesh . thank in advance Sasha |
May 6, 2010, 15:04 |
#10 | |
Alberto Passalacqua
Rep Power: 36 |
You might want to try to reduce the requested tolerance for p in fvSolution to 10^-10. In addition, check if you're using the same under-relaxation Best, Alberto
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
June 15, 2011, 10:43 |
#11 | |
Juanito
Rep Power: 15 |
I have noticed that it is quite difficult to obtain a small residual for p, and as a consecuence the aerodynamic coefficients are different from expected, I think that this is the cause of bad coefficients obtained in this thread http://www.cfd-online.com/Forums/ope...parison-3.html I upload an airfoil example with the obtained residuals, I suggest all of you to find a solution, all together, to this common problem. I look forward to reading your suggestions. http://www.mediafire.com/file/t6286l...il2D_SA.tar.gz residuals.png |
June 15, 2011, 13:02 |
#12 |
Alberto Passalacqua
Rep Power: 36 |
Usually setting the relTol to zero in the linear solvers, and requiring a stricter residual for p than form U helps.
June 16, 2011, 05:43 |
#13 | |
Juanito
Rep Power: 15 |
Sorry, it didn't work. I set relTol to zero and tolerance to 1e-09 and the residuals are now almost the same. residualstol0.jpg Could be a problem with the mesh? Its averaged yPlus is about 125. |
axisymmetric, drag, forces, lift, starccm+ |
