Create internal faces after createPatch
Old   July 10, 2009, 05:36
Default Create internal faces after createPatch
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
Hi
Im using the createPatch tool to create a cyclic boundary condition for the fan BC, when doing so it does not delete the two patches shown.
The problem only arises when the fan_in/fan_out patches doesn't cut through the whole domain.
I've attached 2 pictures of the problem.
I want to either delete the two patches or make them into an internal face.
I have tried using the splitMesh tool on the faceset from the patches but it just states that the face is not an internal face, hey I knew that , but thx for the info splitMesh.
I'm using Salome to create the Mesh and it cannot mesh if I only have an edge inside the domain. I think it is a netgen problem with regards to internal faces
Does anyone have a good ideas how to handle this kind of problem.
linnemann is offline   Reply With Quote
Old   July 23, 2009, 19:40
Poncho
Fonss is on a distinguished road
I'm in the same Boat. Similarly, I want to add a quick fan here and there on some electronic enclosures/radiator arrangements and such. From Salome I can't seem to mesh a 3d domain that contains an internal surface
Fonss is offline   Reply With Quote
Old   July 23, 2009, 20:04
Poncho
Here are some pictures of what I want to do
http://www.flickr.com/photos/32908745@N04/3750924602/
http://www.flickr.com/photos/3290874...n/photostream/
Old   July 24, 2009, 04:00
linnemann's Avatar
Niels Nielsen
I have actually found a workaround.
If you set the "matchTolerance" sufficiently low in the createPatchDict it wont merge the mesh but will retain the cut in the geometry and you can just set the outer walls to zerogradient and it wont affect the flow. It will still create the cyclic boundary condition and stuff just works :-). Just make a thin cut in your geometry from Salome and you will be flying.
My createPatchDict
class dictionary;
object createPatcheDict;
// Tolerance used in matching faces. Absolute tolerance is span of
// face times this factor.
matchTolerance 0.0015;
// Do a synchronisation of coupled points.
pointSync true;
// Patches to create.
// If no patches does a coupled point and face synchronisation anyway.
patches
// Name of new patch
name fan;
// Type of new patch
type cyclic;
// How to construct: either 'patches' or 'set'
constructFrom patches;
// If constructFrom = patches : names of patches
patches (fan_in fan_out);
Regards Linnemann
[Gmsh] Internal faces from gmsh how to create patches in OpenFoam podallaire OpenFOAM Meshing & Mesh Conversion 27 April 25, 2012 21:24
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 10:37
boundary conditions for internal faces Tom Pendrey FLUENT 1 March 5, 2007 18:25
