August 13, 2009, 16:33 |
parallel bug
qqj
hello all,
I am calculate a foil pitching. $ mpirun -np 2 `which icoDyMFoam` -parallel < /dev/null >& log & The error is shown below.Can anyone tell me what this error message means? ------------------------------------------------------- PID : 20238 Case : nProcs : 2 Slaves : 1 ( node31.20239 ) Pstream initialized with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : nonBlocking // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Selecting dynamicFvMesh dynamicMotionSolverFvMesh Selecting motion solver: velocityLaplacian [1] [1] [0] [0] [0] size 580 is not equal to the given value of 292 [0] [0] file: /home/qqj/OpenFOAM/qqj-1.5.x/run/naca0012_test/processor0/0/pointMotionU::foil from line 46 to line 637.[0][0] From function Field<Type>::Field(const word& keyword, const dictionary& dict, const label s)[0] in file /home/qqj/OpenFOAM/OpenFOAM-1.5.x/src/OpenFOAM/lnInclude/Field.C at line 224.[0] FOAM parallel run exiting[0][node31:20238] MPI_ABORT invoked on rank 0 in communicator MPI_COMM_WORLD with errorcode 1 [1] size 580 is not equal to the given value of 292[1][1] file: /home/qqj/OpenFOAM/qqj-1.5.x/run/naca0012_test/processor1/0/pointMotionU::foil from line 46 to line 637.[1][1] From function Field<Type>::Field(const word& keyword, const dictionary& dict, const label s)[1] in file /home/qqj/OpenFOAM/OpenFOAM-1.5.x/src/OpenFOAM/lnInclude/Field.C at line 224.[1] FOAM parallel run exiting[1] [node31:20239] MPI_ABORT invoked on rank 1 in communicator MPI_COMM_WORLD with errorcode 1 |
August 13, 2009, 20:50 |
J. Cai
Hi, ranas, your mpi command seems ok, please run it without parallel at first. Maybe the problem is not at the point of prallel. please also check your B.C. setting of pointMotionU.
best regards, Chiven |
August 13, 2009, 22:46 |
qqj
Hi,chiven,it works well without parallel. I find another similar problem, but i don not understand what they said.
http://www.cfd-online.com/Forums/ope...atch-case.html best wish ranas |
August 14, 2009, 01:11 |
Cem Albukrek
Try changing your decomposePar dictionary settings to use metis and see if it helps:
FoamFile { version 2.0; format ascii; root ""; case ""; instance ""; local ""; class dictionary; object decomposeParDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // numberOfSubdomains 2; method metis; metisCoeffs { processorWeights ( 1 1 ); } distributed no; // ************************************************** *********************** // |
August 14, 2009, 03:10 |
qqj
Hi, cem
I tried and it dosn't work. The log file: Exec : /home/qqj/OpenFOAM/OpenFOAM-1.5.x/applications/bin/linux64GccDPOpt/icoDyMFoam -parallel Date : Aug 14 2009 Time : 15:02:42 Host : node31 PID : 21961 Case : /home/qqj/OpenFOAM/qqj-1.5.x/run/naca0012_test nProcs : 2 Slaves : 1 ( node31.21962 ) Pstream initialized with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : nonBlocking // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Selecting dynamicFvMesh dynamicMotionSolverFvMesh Selecting motion solver: velocityLaplacian [0] [0] [0] size 580 is not equal to the given value of 340 [0] [0] file: /home/qqj/OpenFOAM/qqj-1.5.x/run/naca0012_test/processor0/0/pointMotionU::foil from line [1] 46 to line 637. [0] [0] From function Field<Type>::Field(const word& keyword, const dictionary& dict, const label s) [0] in file /home/qqj/OpenFOAM/OpenFOAM-1.5.x/src/OpenFOAM/lnInclude/Field.C at line 224. [0] FOAM parallel run exiting [0] [1] [1] size 580 is not equal to the given value of 244 [1] [1] file: /home/qqj/OpenFOAM/qqj-1.5.x/run/naca0012_test/processor1/0/pointMotionU::foil from line 46 to line 637. [1] [1] From function Field<Type>::Field(const word& keyword, const dictionary& dict, const label s) [1] in file /home/qqj/OpenFOAM/OpenFOAM-1.5.x/src/OpenFOAM/lnInclude/Field.C at line 224. [1] FOAM parallel run exiting [1] [node31:21961] MPI_ABORT invoked on rank 0 in communicator MPI_COMM_WORLD with errorcode 1 [node31:21962] MPI_ABORT invoked on rank 1 in communicator MPI_COMM_WORLD with errorcode 1 |
August 14, 2009, 03:15 |
qqj
I found that 580 is the number of grid on the nacafoil. It said "size 580 is not equal to the given value of 340". I guess the grid on the nacafoil is not decomposed into two part.
August 17, 2009, 11:28 |
Pierre-Olivier Dallaire
I have the same problem, posted my error here : http://www.cfd-online.com/Forums/ope...atch-case.html Regards, PO |
August 19, 2009, 05:35 |
qqj
Hi, PO
Modify the files pointMotionU in the processor0/0 processor1/0 .... after you execute the command "decomposePar" . I found that the boundary condition can not be divided into several parts. You can do it youself. I do not know why the command does not work, may be it is a bug. Hope it is helpful. best regards ranas |
interDyMFoam parallel bug? | nikos_fb16 | OpenFOAM Bugs | 7 | January 19, 2018 05:06 |
Parallel Moving Mesh Bug for Multi-patch Case | albcem | OpenFOAM Bugs | 17 | April 28, 2013 23:44 |
Parallel Moving Mesh Bug for Multi-patch Case | albcem | OpenFOAM | 0 | May 21, 2009 00:23 |
OpenFOAM 14 stock version parallel bug | msrinath80 | OpenFOAM Bugs | 2 | May 30, 2007 14:47 |
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 | Amitava Majumdar | Main CFD Forum | 0 | January 5, 1999 12:00 |
