kOmegaSSTSAS model
Old   August 24, 2009, 21:00
Wink kOmegaSSTSAS model
Kyungrock Kim
Kr_kim is on a distinguished road
I've successfully simulated kOmegaSST in OF-1.5
but I got following error message using kOmegaSSTSAS in OF-1.6
Is there anybody that know what this problem is and how to resolve it?
Thanks in advance
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/kkim64/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/kkim64/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted:
#3 Foam::divide(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/home/kkim64/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libOpenFOAM.so"
#4 void Foam::divide<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/home/kkim64/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libincompressibleRASModels.so"
#5 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator/<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) in "/home/kkim64/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libincompressibleRASModels.so"
#6 Foam::incompressible::LESModels::kOmegaSSTSAS::F2( ) const in "/home/kkim64/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libincompressibleLESModels.so"
#7 Foam::incompressible::LESModels::kOmegaSSTSAS::upd ateSubGridScaleFields(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/home/kkim64/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libincompressibleLESModels.so"
#8 Foam::incompressible::LESModels::kOmegaSSTSAS::kOm egaSSTSAS(Foam::GeometricField<Foam::Vector<double >, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&, Foam::word const&) in "/home/kkim64/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libincompressibleLESModels.so"
#9 Foam::incompressible::LESModel::adddictionaryConst ructorToTable<Foam::incompressible::LESModels::kOm egaSSTSAS>::New(Foam::GeometricField<Foam::Vector< double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&) in "/home/kkim64/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libincompressibleLESModels.so"
#10 Foam::incompressible::LESModel::New(Foam::Geometri cField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&) in "/home/kkim64/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libincompressibleLESModels.so"
#11 Foam::incompressible::turbulenceModel::addturbulen ceModelConstructorToTable<Foam::incompressible::LE SModel>::NewturbulenceModel(Foam::GeometricField<F oam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&) in "/home/kkim64/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libincompressibleLESModels.so"
#12 Foam::incompressible::turbulenceModel::New(Foam::G eometricField<Foam::Vector<double>, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::transportModel&) in "/home/kkim64/OpenFOAM/OpenFOAM-1.6/lib/linuxGccDPOpt/libincompressibleTurbulenceModel.so"
#13 main in "/home/kkim64/OpenFOAM/OpenFOAM-1.6/applications/bin/linuxGccDPOpt/pisoFoam"
#14 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
#15 _start at /usr/src/packages/BUILD/glibc-2.9/csu/../sysdeps/i386/elf/start.S:122
Kr_kim is offline   Reply With Quote
Old   August 25, 2009, 04:01
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Kim
You divide by 0. This imply that you have put zero on either boundaries or internal volumes for k or omega. These needs to be finite, e.g. 1e-11.
Best regards,
Niels
ngj is offline   Reply With Quote
Old   September 1, 2009, 22:59
Kyungrock Kim
Thaks for the reply
Although I changed the values which you recommended but the same problem occurred. Is there any problem in code in itself?
http://openfoamwiki.net/index.php/HowTo_debugging
If there is some problem in code itself, how can I debug it(for specific files)
Best regards,
Kyungrock Kim
Old   October 19, 2009, 14:20
Default kOmegaSSTSAS on channelFoam
Kyungrock Kim
Originally Posted by ngj View Post
Hi Kim
Best regards,
Niels
I have one more question on kOmegaSSTSAS. SAS mode was worked correctly in pisoFoam by quantifying correct initial and boudary data for omega and k at pisoFoam.
Question) But is it viable at channelFoam. It looks possible, I guess, because I have the same error with in pisoFoam(dividing by zero blah blah...) but I couldn't overcome it yet. To make sure it. is it possible in your opinion and if it is, what's the difference to pisoFoam?
Old   October 19, 2009, 14:39
Default to clarify the problem
Kyungrock Kim
Hi Kim
Best regards,
Niels
Ubar is bulk velocity and it is used at pisoFoam and channelFoam with the same token. So k, epsilon and omega should be calculated based on Ubar values and asssign these values at internal Field, and the boundary condition at the both wall for k and omega should be zeroGradient. Are they right? I belive so. I'm waiting for your reply
Thanks in advance.
Old   February 4, 2010, 13:46
Pierre-Olivier Dallaire
podallaire is on a distinguished road
moved my post to Bugs - thanks
podallaire is offline   Reply With Quote
Reynolds Stress model in CFX vs Fluent Tim CFX 1 October 7, 2009 06:19
references about the fan/radiator model Mihai ARGHIR Main CFD Forum 1 January 8, 2001 15:49
references about the fan/radiator model Mihai ARGHIR Main CFD Forum 0 December 21, 2000 03:06
references about the fan/radiator model Mihai ARGHIR Main CFD Forum 1 December 17, 2000 07:01
references about the fan/radiator model Mihai ARGHIR FLUENT 0 December 17, 2000 06:40
