September 8, 2009, 07:55 |
Pitz Daily oodles pressure field problem
Prapanch Nair
Rep Power: 17 |
I was trying to run pitzDaily tutotial case under oodles (OF1.5.x). The pressure field is not making any sense to me. The pressure field is switching between +ve to negative values throughout and changing from time step to time step. I changed the fluctuation scale value in turbulentInlet boundary condition of U to (0 0 0) and then I was getting consistent pressure values. why would this happen? Is the pressure BC at the inlet wrong ? I tried oodles on an external flow sim where forces were important and I was getting similar fluctuation in field, ( drag and lift oscillating in random). Anybody has some insight on this? Thanks, Prapanj. |
September 27, 2010, 12:32 |
vinz
Hi:
I'm also trying to run pitzDaily tutorial case under oodles (OF 1.5.X). I have a problem like your. I want to know how you can correct it. Thanks a lot, vicent87 |
March 29, 2012, 11:15 |
#3 | |
Joyi Wang
Rep Power: 16 |
Hej, now 2 years has gone, I have the same problem now. unphysical pressure field with turbulentInlet. Did anybody slove it
April 12, 2012, 01:49 |
#4 | |
fluentfreak
Rep Power: 17 |
I have the same problem in the latest version with pisoFoam solver and the LES PitzDaily tutorial: http://www.cfd-online.com/Forums/ope...-pisofoam.html Someone please help! |
fluctuation, oodles, pitzdaily, pressure, turbulentinlet |
HELP! rail tunnel pressure problem | miguel.berrozpe | Main CFD Forum | 1 | February 14, 2012 08:35 |
Pressure correction problem | richard_larson | OpenFOAM Running, Solving & CFD | 8 | October 30, 2008 08:48 |
Problem with rhoSimpleFoam | matteo_gautero | OpenFOAM Running, Solving & CFD | 0 | February 28, 2008 06:51 |
Problem with the pressure field using interFoam | zoune | OpenFOAM Running, Solving & CFD | 20 | February 4, 2008 18:42 |
Using SIMPLE | david | Main CFD Forum | 5 | July 21, 1999 02:38 |
