GGI implementation in MRFSimpleFoam
Like Tree1Likes
  • 1 Post By amgode
Old   September 15, 2009, 06:45
Question GGI implementation in MRFSimpleFoam
amgode's Avatar
Amol
amgode is on a distinguished road
Hi all,
I am trying to implement a ggi interface while using MRFSimpleFoam for solving a 3D mixer problem. (OpenFoam-1.5-dev )
the procedure as described in openwiki:
- mergeMeshes rotor stator
- implement ggi
- implement MRFSimpleFoam
Now, what if the mergeMeshes step is replaced by something like - importing the fluent mesh directly. (or importing from tgrid by simultaneously reading the rotor and stator meshes.)
On doing the above I get the following message.
Create time
Create mesh for time = 0
Reading field p
Reading field U
Problem with patch-to zone addressing: some patch faces not found in interpolation zone
From function void ggiPolyPatch::calcZoneAddressing() const
in file meshes/polyMesh/polyPatches/constraint/ggi/ggiPolyPatch.C at line 77.
FOAM aborting
Aborted
Thanks in advance.
Amol
amgode is offline   Reply With Quote
Old   September 16, 2009, 01:01
amgode's Avatar
Amol
Well, that was not hard.
just had to set the faces to the patch.........that's all........
Got it working now.................
Regards,
Amol
Old   October 9, 2009, 15:33
Dnyanesh Digraskar
ddigrask is on a distinguished road
Hi Amol,
Can you explain how you got that working in detail. Even I am getting that error. Thanks for your help.
ddigrask is offline   Reply With Quote
Old   March 20, 2010, 12:51
Jason Eason
JulytoNovember is on a distinguished road
Excuse me Amol, did you ever get your simulation to run correctly, and did the ggi implimentation make MRFSimpleFoam rotate? Lastly, did you have to add the dynamicMeshDict?
Debian Squeeze - OpenFOAM-2.1.x, Paraview-3.12.0
JulytoNovember is offline   Reply With Quote
Old   March 21, 2010, 23:26
amgode's Avatar
Amol
Yes ofcourse ! without any problems....
Since MRFSimpleFoam is a steady state solver and I was interested in steady state solution, there was no need to dynamically rotate the MRF region and hence no need for dynamicMeshDict as such....
I hope u get the point !
Old   May 21, 2010, 12:55
John Deas
johndeas is on a distinguished road
I am also trying to create a mesh in Gambit, and then set it to work with interfaces.
So, what I do is:
1. fluent3DMeshToFoam
2. edit boundary to change patch types to ggi
3. setSet -batch setBatch
4. setsToZones -noFlipMap
When I finally run my solver, I get the following error: "Problem with patch-to zone addressing: some patch faces not found in interpolation zone".
Since this is very similar to other problems reported here, i would like to know what to check first.
Thank you !
JD
johndeas is offline   Reply With Quote
Old   May 23, 2010, 03:09
amgode's Avatar
Amol
JD
The reason for this error has something to do with the definition of the ggi patches in the boundary file. If you could post your boundary file here it would be most helpful.
As a prelude, you could check the facezone names being given for the ggi pairs in the boundary file.
Hope it helps !
Regards,
Amol
st_hoerner likes this.
Old   May 23, 2010, 08:16
John Deas
Thank you !
My error was indeed related to a malformed boundary file: I assigned the wrong zones to the wrong patches. Now that this has been corrected, I am able to launch my test case correctly.
Old   August 5, 2011, 06:03
Default GGI implementation in pimpleDyMFOAM
shyam prasad
shyam is on a distinguished road
Hi Faomers,
I am trying to implement GGI for a stirred tank in pimpleDyMFOAM. I have run the mixerGGI tutorial and it works fine. I have a 3d mesh from gambit for which i want to implement pimpleDyMFOAM. I have changed the constant/polyMesh/boundary file to reflect interfaces as ggi as per the mixerGGI tutorial. When I run pimpleDyMFoam I get the following error.
--> FOAM FATAL ERROR:
unable to figure out what to do!
Can anyone help ?
shyam is offline   Reply With Quote
Convergence with MRFSimpleFoam grugg OpenFOAM Running, Solving & CFD 7 March 28, 2014 04:56
MRFSimpleFoam Tutorial bastil OpenFOAM Running, Solving & CFD 48 August 1, 2012 10:00
GGI in OpenFOAM hjasak OpenFOAM Running, Solving & CFD 59 April 30, 2010 08:30
CFX GGI Interface Error (non-overlapping) surge519 CFX 1 August 3, 2009 18:54
GGI ERCOFTAC and general questions david OpenFOAM Running, Solving & CFD 8 August 25, 2008 09:22
