September 28, 2009, 07:07 |
A question about chtMultiRegionFoam.
Petri Sulasalmi
Rep Power: 16 |
Hello all,
I'm building a case based on multiRegionHeater. I'm using liquid phase as a fluid. I'd like to know which Thermophysical model is appropriate for liquids? I.e. which input I need to put in thermophysicalProperties -file as there must be defined thermoType ····<····<····<····<····<·········>>>>> I tried to use the same input as in multiRegionHeater but it didn't produce any reasonable result (although it might be due to that there's somethin else wrong). Regards, Petri |
September 29, 2009, 05:26 |
Petri Sulasalmi
Rep Power: 16 |
Hi all,
Another question: can I solve the problem just replacing in solvers/heatTransfer/chtMultiRegionFoam/chtMultiRegionFoam.C #include "basicPsiThermo.H" with some other thermodynamic model and compiling it again? And which model(s) is suitable for liquid phases? I'd really appreciate if someone could help me with this! Thank you! Petri |
October 2, 2009, 04:59 |
Aram Amouzandeh
Rep Power: 17 |
Hi Petri!
Check the user guide (p U-171) for more details on how to define thermo-physical properties in OF. For the chtMultiregionFoam they are defined in the case directory, in constant/<fluidRegion>/thermophysicalProperties. As far as I remember the multiRegionHeater tutorial prescribes the properties of air; hence it should be clear why you do not get reasonable results if you want to simulate the behaviour of a liquid. Hope that helps! Regards, Aram |
June 19, 2010, 09:58 |
Michea Ferrari
Rep Power: 16 |
Dear Petri,
I have the same problem related to the implementation of a liquid using the solver chtMultiRegionFoam... Have you solve this problem? If yes, can you please help me to find the solution? Many thanks Best Regards Michea |
Before you post a question please read this | ghorrocks | CFX | 5 | October 23, 2019 07:44 |
Unanswered question | niklas | OpenFOAM | 2 | July 31, 2013 16:03 |
Poisson Solver question | Suresh | Main CFD Forum | 3 | August 12, 2005 04:37 |
CHANNEL FLOW: a question and a request | Carlos | Main CFD Forum | 4 | August 23, 2002 05:55 |
question | K.L.Huang | Siemens | 1 | March 29, 2000 04:57 |
