error message with interFoam
Old   October 5, 2009, 19:49
Default error message with interFoam
Ovie Doro
ovie is on a distinguished road
I am trying to implement interFoam for a falling film on a flat plate but I am getting an error message which I dont understand. Could someone please help?
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/ovie/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/ovie/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted: [0xb7f69400]
#3 Foam::Time::adjustDeltaT() in "/home/ovie/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so"
#4 Foam::Time::setDeltaT(double) in "/home/ovie/OpenFOAM/OpenFOAM-1.5/lib/linuxGccDPOpt/libOpenFOAM.so"
#5 main in "/home/ovie/OpenFOAM/OpenFOAM-1.5/applications/bin/linuxGccDPOpt/interFoam"
#6 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
#7 _start at /build/buildd/glibc-2.9/csu/../sysdeps/i386/elf/start.S:122
Floating point exception
ovie is offline   Reply With Quote
Old   October 6, 2009, 02:47
ngj
Niels Gjoel Jacobsen
ngj will become famous soon enoughngj will become famous soon enough
Hi Ovie
Without having seen what's immediately prior to these errors, my guess is that you time step gets smaller and smaller, hence the crash is simply a symptom on the fact that your computation is diverging.
Bests
Niels
ngj is offline   Reply With Quote
Old   October 6, 2009, 13:03
Ovie Doro
Thanks Niels,
I went back to review the tutorials and figured that I had to execute setFields prior to running the computation. Problem solved.
One quick question, do you have any idea if its possible to implement the MULES solver for volume fraction variable in steady state?
Thanks again.
interFoam / bubbleFoam to simulate an aerated tank Meratb OpenFOAM Running, Solving & CFD 3 November 6, 2020 11:45
InterFoam stops after deltaT goes to 1e14 francesco_b OpenFOAM Running, Solving & CFD 9 July 25, 2020 06:36
Latest git 1.6.x: Crash when using inletOutlet for variable alpha1 in interFoam carsten OpenFOAM Bugs 6 September 23, 2009 09:46
Temporal discretisation in interFoam sebonator OpenFOAM 2 August 21, 2009 07:39
Open Channel Flow using InterFoam type solver sxhdhi OpenFOAM Running, Solving & CFD 3 May 5, 2009 21:58
