October 18, 2009, 05:38 |
airfoil optimizer chain with drag problem
Matthias Arnold
Rep Power: 16 |
hi,
to say it first: I'm a beginner in OF (vers 1.6). Now my Problem: My aim ist to build a small optimizer chain to find the optimum low drag airfoil for casing of struts with a constant angle of attack of 0°. To reach this aim every optimizer iteration is done by following steps: perlscript write_blockmesh_edgegrading.pl -> move blockMeshDict to /constant/polymesh/ -> blockMesh -> simpleFoam -> read out cd_value This steps work automatic, but the result is not so nice for example for a NACA0018 airfoil to case a diameter of 0.18m (=> chord 1m) the result of the simulation is approx: cd = 0,0155 with a look to the measured data of this airfoil it should be around 0.0075 So the result is with a faktor of 2 to high. As far as I analysed the Problem the friction drag looks good, but the pressure part is to high. Resulting from this the optimizer converges to a unphysical result (NACA0004 looks a bit wrong. expected result around 0028), because it has a to high attitude to search for a low pressure drag and not for the combinition of pressure drag and friction drag. what i already tried to solve the problem: checking convergence: the residuals are <= 10^-6 and the drag value ist at it's final value after 400 of the 1000 iterations changing turbulencemodell: i found in the forum that the SpalartAllmaras modell is used frequently for airfoil calculation. with this modell the cd converged to 0.04. with the RNGkEpsilon modell i had the above result of 0.0155. with all other modells i had worse results. changing mesh resolution: there was no big change in results on rising the number of meshcells. (approx +- 2%) searching the forum to find a solution: I found many hints, but they didn't give me a solution for my problem. changing velocity: with the higher Re the cd value got a little bit smaller, but not in a significant size. So my question is: can you please take a look on my casefiles attached? As i worte above I'm a beginner with OF, so i fear there could be some "stupid" mistakes. thank you very much for your help. |
October 18, 2009, 05:47 |
Matthias Arnold
Rep Power: 16 |
Sorry, made a mistake with the uploaded case files. They had a mixed up in turbulence modell.
Sorry for that. |
October 18, 2009, 13:43 |
Simon Lapointe
Rep Power: 17 |
These results don't seem so wrong to me. You will rarely obtain the good drag values using RANS models.
On an airfoil at a low angle, an important part of the boundary layer is laminar, hence the friction drag is smaller than in a turbulent boundary layer. Traditional RANS models (SA, k-epsilon...) predict a fully turbulent boundary layer resulting in a higher drag than experimental data. Concerning the bad result with the SpalartAllmaras model, did you have a mesh with y+ around 1 ? Unless you use wall functions (which are optional with SpalartAllmaras) you need a good resolution to resolve the near-wall region. In my experience, near wall resolution gives a little better drag prediction than wall functions. Hope this helps. |
[FloWorks] Request advice for an airfoil calculation problem | Bogey Jammer | Main CFD Forum | 0 | September 29, 2009 17:06 |
problem saving drag convergence history | raheelrasool | FLUENT | 3 | April 20, 2009 09:04 |
airfoil: drag and lift coefficients | Pedro Clode | FLUENT | 1 | January 1, 2007 12:44 |
Drag predicion for a NACA 0012 airfoil | Peter Giannakopoulos | FLUENT | 7 | March 9, 2004 15:32 |
airfoil drag | aaa | FLUENT | 1 | November 6, 2002 18:36 |
