October 19, 2009, 11:46 |
engine-mesh, layer removal?
anonymous
I made a case to run with dieselEngineFoam(kivaTest+aachenBomb). Everything is ok but mesh. I started the simulation at BDC. At TDC I have a deformed mesh with the same number of cells. There is no layer removal.
-would you please guide me to set the case correctly. -should I change the code or do any pre-processing? Thank you |
October 20, 2009, 04:22 |
Rep Power: 17 |
u have to implement the engineTopoChangerMesh class engineTopoChangerMesh layerAR; instead of engineMesh layered; in the engineGeometry file. Define delta and offset and min/maxlayerthickness for your calculation. That should be almost all. If u have more questions please search for papers from Tommaso Lucchini. regards |
Dynamic Mesh with Boundary Layer | Marcell | FLUENT | 0 | March 11, 2009 09:40 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 15:09 |
Need help to mesh Wankel engine | Sam | Main CFD Forum | 3 | October 4, 2007 21:33 |
[Technical] 3D mesh with boundary layer | fra76 | OpenFOAM Meshing & Mesh Conversion | 0 | May 21, 2006 04:32 |
boundary layer mesh | merac | FLUENT | 1 | June 19, 2001 12:45 |
