Exploding h/rho in rhoSimpleFoam
Old   February 17, 2010, 10:41
Default Exploding h/rho in rhoSimpleFoam
BastiL
bastil is on a distinguished road
Dear Solver-Experts,
I am running a case in rhoSimpleFoam and I get exploding values for temperature and especially density after few iterations, but no divergence. This even happens for turbulence turned off. I have to blame a few cells in my prism layer (low-Re, layer next to wall) for this.
I am trying to bound rho and h in some way, but without success so far. I tried:
interpolationSchemes
      interpolate(rho) limitedLimitedLinear phi 1.0 1.0 1.25;
to bound rho between 1.0 and 1.25 but this does not work at all. I get higer densities after 4 iterations... How can these values be bounded? Thanks.
Regards
bastil is offline   Reply With Quote
Old   February 18, 2010, 05:05
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
Have you tried severely underrelaxing rho? For example, a value of 0.05 might get you over the rough spots.
olesen is offline   Reply With Quote
Old   February 18, 2010, 05:53
BastiL
Thanks Mark. Yes I do this. I still have problems in some critical areas. I am also wondering about BCs at walls. We use for walls:
fixedValue, 1e-20 for k and epsilon (for LaunderSharma-k-epsilon)
zeroGradient for temperature
I am not sure for temperature... The only similar tutorial case is NacaAirfoil from turbFoam. This uses zeroGradient for temperature but also for k and epsilon which is obviously wrong?
Any other ideas? Thanks.
Regards BastiL
TRANSONIC FLOW in RHOSIMPLEFOAM dinonettis OpenFOAM Running, Solving & CFD 10 September 13, 2018 10:22
rhoSimpleFoam OF1.6 sheintz OpenFOAM 4 September 3, 2009 07:41
Monitor viscosity - RhoSimpleFoam ABouvier OpenFOAM Post-Processing 5 April 24, 2009 18:37
RhoSimpleFoam FoamX spv24 OpenFOAM Running, Solving & CFD 1 July 21, 2008 10:29
Stability startup problems with rhoSimpleFoam olesen OpenFOAM Running, Solving & CFD 1 July 18, 2006 08:09
