interFoam 1.6.x vs 1.5 : same mesh, same bc but different results |
April 8, 2010, 12:03 |
Water Flow around hull ship : interFoam 1.6.x vs 1.5
Emanuele
Hi, i simulated a flow around an hull ship with interFoam (only water, no air and free surface). I have results with v1.5 and they seems really good. I tried to repeat the problem setting up a complete similar case in v 1.6.x but it gives me bad pressure and velocity field (all force coeffs are wrong and the simulation stopped after two days giving me an error ). I d like to know the differences between v1.5 and v1.6.x and if i setted in the wrong way the different params of simulation. I attach a pdf with the principal files.
EDIT: contours of p and U here http://dl.dropbox.com/u/3617688/contours.tar.gz Last edited by nuovodna; April 22, 2010 at 05:47. |
April 13, 2010, 06:56 |
Interesting
GRD
This is interesting. Anyone else facing this problem? Has anyone fixed it?
OF-1.6.x has some really nice features for hull analysis, but unless we figure out what is going on with the results they're useless. Regards, Gonzalo |
April 13, 2010, 07:21 |
GRD
Having a look to your files I found a couple of things that might help, but still I don't think you'll get the same results.
1. In the inlet B.C I found that setting alpha to a constant value with setFields helps convergence. 2. You should also have an atmosphere patch. 3. Try with the hull as bouyantPressure too. Good luck, although we're still missing something. I wish there was more documentation about interFoam in 1.6.x Gonzalo |
April 22, 2010, 05:46 |
Emanuele
i think i have to change boundary condition on pressure : if in 1.5 i have zeroGradient, in 1.6.x i have to switch on buoyantPressure on the patch orthogonal to pressure gradient. I ll keep you updated on simulation's results. Stay tuned
May 3, 2010, 08:37 |
Emanuele
I changed the pressure boundary conditions and now p field seems good. But i have a local "dicontinuity" of U field on symmetry patch. How can i solve it?? I attach the screenshots
http://dl.dropbox.com/u/3617688/Ufield.png http://dl.dropbox.com/u/3617688/UfieldMesh.png |
May 4, 2010, 05:34 |
Pablo
Hi Emanuele,
That is because unstrured mesh (tetras) is not working nice. Change your mesh to hexa and if possible structured and you will see everything better. |
June 10, 2010, 07:55 |
stephane sanchi
Rep Power: 18 |
Hi Emanuele,
could you put your settings for OF-1.6.x ? Have you improve your calculation ? Best regards, Stephane |
June 14, 2010, 05:27 |
Emanuele
I have set a less value of Courant number and now it works and it's running on 4 CPUs from two weeks
June 14, 2010, 05:34 |
stephane sanchi
Rep Power: 18 |
Hi Emanuele,
You have a very low Courant Number ! The wigley hull of Eric Paterson runs well with Courant Number 0.8. Regards, Stephane. |
June 14, 2010, 05:45 |
Emanuele
Do you think i have to investigate what are wrong in other part of the case?? I thought the mesh but checkMesh is perfect...any idea??
interFoam with irregular Mesh | luther | OpenFOAM | 9 | August 14, 2009 07:43 |
incorrect results with a tetrahedral mesh | jcmasters | OpenFOAM | 5 | May 20, 2009 16:44 |
Mesh for 3 dim Geometry | Phil | FLUENT | 9 | July 12, 2000 04:39 |
Mesh | Mignard | FLUENT | 2 | March 22, 2000 05:12 |
