time step continuity error
Old   June 11, 2010, 03:51
Default time step continuity error
bephi is on a distinguished road
Hi at all,
i am doing some simulation of a flow through a pistol valve using the simpleFoam-solver containing k-w-SST turbulence model. unfortunately my calculations often crash or when they run from start- to endtime, solution are diverging.
maybe you have an idea, what can be improved to avoid such errors?! timeStep is calculated with CFL-No. <1.
examples:
1) here the velocity component U_z increases.
Time = 0.74498
DILUPBiCG:  Solving for Ux, Initial residual = 2.50978e-05, Final residual = 8.49602e-07, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 2.54388e-05, Final residual = 2.2754e-06, No Iterations 2
DILUPBiCG:  Solving for Uz, Initial residual = 8.85837e-06, Final residual = 1.02878e+13, No Iterations 1001
DICPCG:  Solving for p, Initial residual = 1, Final residual = 0.00995054, No Iterations 108
DICPCG:  Solving for p, Initial residual = 0.113132, Final residual = 0.00109658, No Iterations 32
DICPCG:  Solving for p, Initial residual = 0.018198, Final residual = 0.00017058, No Iterations 98
time step continuity errors : sum local = 3.2839e+07, global = -124559, cumulative = -124377
63 additional processes aborted (not shown)
2) here just the cumulative time step error is big.
Time = 0.36633
DILUPBiCG:  Solving for Ux, Initial residual = 0.0126915, Final residual = 0.000657026, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 0.00954027, Final residual = 0.000545504, No Iterations 2
DILUPBiCG:  Solving for Uz, Initial residual = 0.00808909, Final residual = 0.000426527, No Iterations 2
DICPCG:  Solving for p, Initial residual = 7.40292e-07, Final residual = 9.93734e-08, No Iterations 45
DICPCG:  Solving for p, Initial residual = 5.64208e-07, Final residual = 9.98093e-08, No Iterations 4
DICPCG:  Solving for p, Initial residual = 1.38451e-07, Final residual = 9.08471e-08, No Iterations 1
time step continuity errors : sum local = 11.0104, global = -0.956176, cumulative = 62676.9
And what can in general be said about the duration the user should define (startTime /endTime)? Is there any relation between this defined time and the physical time which the fluid needs to flow trough the geometry? or is most priority that the variable we are looking for, is converged?
bephi is offline   Reply With Quote
Old   June 11, 2010, 04:05
Stefan Herbert
herbert is on a distinguished road
Hi bephi,
simpleFoam is a solver for steady state problems. Therefore the time step has no effect on solution, convergence, etc. The first step to improve stability is to reduce relaxation factors.
Yes of course. You should only trust your solution if its converged.
Regards,
Stefan
herbert is offline   Reply With Quote
Old   June 11, 2010, 04:25
Hi thanks for your answer.
Which URF should be decreased in your opinion?
Regards!
Philipp
Compile problem ivanyao OpenFOAM Running, Solving & CFD 1 October 12, 2012 09:31
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 12:34
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
