attempt to use janafThermo<equationOfState> out of temperature range 200 -> 5000; |
July 30, 2010, 15:54 |
Hi
I was using the reactingFoam tutorial on OpenFOAM 1.6, and made changes as suggested in the OPenFOAM Wiki. I got the following error message: attempt to use janafThermo<equationOfState> out of temperature range 200 -> 5000; T = 5000.05#0 Foam::error:rintStack(Foam::Ostream&) in "/home/gkewlani/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #1 Foam::error::abort() in "/home/gkewlani/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libOpenFOAM.so" #2 Foam::specieThermo<Foam::janafThermo<Foam:erfect Gas> >::H(double) const in "/home/gkewlani/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libreactionThermophysicalModels.so" #3 Foam::ODEChemistryModel<Foam:siChemistryModel, Foam::sutherlandTransport<Foam::specieThermo<Foam: :janafThermo<Foam:erfectGas> > > >::solve(double, double) in "/home/gkewlani/OpenFOAM/OpenFOAM-1.6/lib/linux64GccDPOpt/libchemistryModel.so" #4 main in "/home/gkewlani/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/reactingFoam" #5 __libc_start_main in "/lib/libc.so.6" #6 _start in "/home/gkewlani/OpenFOAM/OpenFOAM-1.6/applications/bin/linux64GccDPOpt/reactingFoam" How can I change the temperature range above? Is something else going wrong? I am new to this software, so any help would be useful. Thanks! |
August 5, 2010, 16:42 |
Same problem
Seyyed Ali H.M.
Hello Foamers
I have the same problem(also posted on other threads), can any body help?
SAHM |
August 6, 2010, 08:38 |
Rickard
Im having the same problem, so maybe not much of help here.
What I was thinking - since im using very high injection speed and therefore very big density gradient - is to refine the mesh and use very small timesteps. In this case the courant number will be satisfied as well. If you are very skeptical, read this thread http://www.cfd-online.com/Forums/ope...your-time.html apparently then , janaf would be a bug and cant be solved if using combustion |
August 6, 2010, 12:16 |
I got it, but new problem
Seyyed Ali H.M.
Hi everyone,
I just made my mesh 4X finer with fixed courant number, and this time it worked, but there is another problem. in the oxidizer field, there is no reaction, but the temperature drops as soon as the flow gets into the domain. I don't know what exactly causes this, but that has to do something with Cp or mixture properties. I`m looking for this new problem, as my results does not look good. You can see my case through this link. Remember to change the mesh and constant/Reactions file, as the file was not defined correctly. Have fun, Take care.
SAHM Last edited by sahm; August 6, 2010 at 12:18. Reason: forgot. |
August 6, 2010, 14:16 |
Rickard
Hey man, your link didnt work please post it again.
What kind of case are you doing? DieselFOAM? |
August 6, 2010, 14:19 |
ReactingFoam Error
Seyyed Ali H.M.
http://www.cfd-online.com/Forums/ope...oam-error.html
The address is that, If it didn't work, go to my profile, and bring statistics, go to my latest posts.
SAHM |
August 9, 2010, 08:09 |
Redefining JANAF-THERMO limits
Hello to all,
I just tripped over a similar problem, the JANAF giving a warning of a too low temperature. Here is a way to change these limits - not less, but surely not more! It might work in case the rest of the simulation would be going well and it is just these three or four degrees that would make the calculation fail. About the outcome if you redefine the limits I cannot say anything, I am just starting to get into the program! So here it is: - Open ../constant/thermophysicalProperties - Look for the line with plenty of numbers In my case the second triplet of numbers were the ones defining the JANAF-parameters. The first one set the low temperature limit, the next one the upper temperature limit, the third one gives some value that is needed by the library. - Change the value corresponding to your failing limit - Be happy (or not) with the results! I would be happy if someone could explain the entries in the "thermophysicalProperties" file, so I really can understand it. Of course, pointing to a thread where that is done would be equally welcome. |
August 9, 2010, 08:23 |
#8 | |
Rickard
Hi, thanks for your reply. Would you please copy the file you mean in here so that I can get an idea of what you mean. Are you actually talking about the therm.dat file in the chemkin ? Are you doing dieselFoam?
Thx! Quote:
August 9, 2010, 13:16 |
#9 | ||
So I did not try too much with it, thus cannot say anything about the results (or problems) with changed value. The file I was using was a basic "thermophysicalProperties" as I found it in one of the tutorials. Unfortunately somehow it doesn't work to upload it, but it contains following text: Quote:
The numbers 100 10000 and 1000 are the ones of interest in this case. 100 is the low limit, 10000 the upper one, and 1000 seems to be interesting for averaging... |
August 10, 2010, 01:18 |
Josiah Xu
In my experience,the modification of the limit values can not help you to solve the janaf error. It just can move the calculation forward for several steps. That problem will appear finally.
August 23, 2010, 04:45 |
#11 |
I agree, Josiah! The way I described would help only, if it really was just very few degrees AND the janaf-library contains the necessary values.
But just at that point another question: I know that in my case most probably at some point I will reach temperatures close to air liquefaction (vacuum breaches, air getting sucked in, extreme temperature drop due to immensely increased volume...). Does anybody know a solver and libraries that would provide me with the means for such thing including possible liquefaction of air (or the contained gases, to be exact)? (I will post this question in an extra thread in case I find nothing similar. So if you have an answer, perhaps the other thread would be the better place for posting the answer. So others looking would find it more easily...) Thanks in advance for your answers/opinions! |
June 13, 2011, 22:41 |
#12 |
桂莹
Hi,Josiah
I have the same problem with the solver coalChemistryFoam for a long time, I refine the mesh from 0.67 million to 0.9 million,but it still doesn't work,do you know how to solve it? best regards, ying |
June 23, 2011, 10:54 |
Newer JANAF implementation
#13 |
Jim Carow
I stumbled onto the thread linked below while trying to find more info about OpenFOAM's thermophysical models.
Take a look: http://www.cfd-online.com/Forums/ope...naf-model.html regards, Jim |
June 24, 2011, 04:33 |
#14 |
桂莹
Hi,Jim
thank you for reply I try as http://openfoamwiki.net/index.php/Janaf ,but it seems doesn't help,I am trying to solve it! |
June 17, 2015, 11:53 |
#15 |
Ali Kadar
Rep Power: 11 |
Is there a way to disable the warning ?? "attempt to use janafThermo<EquationOfState> out of temperature range 300 -> 3500" Because the warning is generated every time step and for each cell(where temperature is not in the Janaf limit), the log file generated is very large and it also slows down the processing due to IO. Because, for my case I know that the warning eventually disappears by end of the simulation, I would like to disable it from the very beginning. Is there a way to disable it ... I have tried to make changes here by commenting out the block which generates the warning. Can somebody suggest if I am doing the right way ?? OpenFOAM/OpenFOAM-2.3.x/blob/master/src/thermophysicalModels/specie/thermo/janaf/janafThermoI.H if (T < Tlow_ || T > Thigh_) { //COMMENTED return min(max(T, Tlow_), Thigh_); } else { return T; }
A good solution is one which does justice to the inner nature of the problem- Cornelius Lanczos in a letter to Albert Einstein on March 9, 1947 |
June 18, 2015, 04:07 |
#16 |
Ali Kadar
Rep Power: 11 |
yes, commenting the code here does work and there are no Janaf Messages.
OpenFOAM/OpenFOAM-2.3.x/blob/master/src/thermophysicalModels/specie/thermo/janaf/janafThermoI.H if (T < Tlow_ || T > Thigh_) { //COMMENTED return min(max(T, Tlow_), Thigh_); } else { return T; } However I realized that its not a very good idea to disable the warnings completely. I would like to have this warning once every time iteration(if the limits are exceeded for any of the cells) and not for each cell seperately. This would also reduce the size of the log file generated and will also make the log more readable. A more elegant way would be to display the count of the cells where the Janaf limit is exceeded each time step. But I do not understand how can it be done, where to add the code, I assume a flag needs to be provided by the user to disable the warnings completely, display the count or to enable the warnings(default). This flag can be a part of the dictionary file but where and how will it be read.. any ideas ?
June 19, 2015, 07:29 |
#17 |
Ali Kadar
Rep Power: 11 |
To remove the JANAF Warnings from the log file I have written a simple shell script using the sed command.
run the script as ./shellScript log Code:
#!/bin/sh echo "The JANAF THERMO warnings will be removed from the following file $1" oldLineCount=$(sed -n '$=' $1) oldFileSize=$(du -h $1 | cut -f -1) sed -i '/--> FOAM Warning/,/out of temperature range/d' $1 echo -e "\nThe JANAF warnings have been removed" >> $1 newLineCount=$(sed -n '$=' $1) newFileSize=$(du -h $1 | cut -f -1) echo "The line count before = $oldLineCount and size = $oldFileSize" >> $1 echo "The line count after = $newLineCount and size = $newFileSize" >> $1 The JANAF warnings have been removed The line count before = 240592584 and size = 18G The line count after = 531150 and size = 35M I am doing the benchmark test case Sandia Flame D where the air inlet and fuel inlet are at temperatures 291k and 294K respectively with the Pilot jet at 1880K for ignition. It is quite obvious that the temperature at some places in the domain will fall below the JANAF lower limit example janafThermo<EquationOfState> out of temperature range 300 -> 3500; T = 293.62368 Is there an elegant way to disable/minimize the warnings ?? It is really frustrating when the log generated is of size 20-30G. It slows down the processing significantly when global reaction is used. Is there a workaround ??
October 2, 2016, 15:40 |
#18 |
Sheikh Ahmed
Rep Power: 10 |
dear all
Did anyone recently face similar problem with the janaf? I was running reactingFoam in OF 2.3.1 and got the same warning. I commented the block (as shown below) but still getting the same warning. I ran 'wmake' in the reactingFoam directory to activate/recompile the change I made in the header fle. Could anyone please share his/her recent experience on this issue, how to solve it? //{ // if (T < Tlow_ || T > Thigh_) // { // WarningIn // ( // "janafThermo<EquationOfState>::limit(const scalar T) const" // ) << "attempt to use janafThermo<EquationOfState>" // " out of temperature range " // << Tlow_ << " -> " << Thigh_ << "; T = " << T // << endl; // // return min(max(T, Tlow_), Thigh_); // } // else // { return T; // } //} |
October 3, 2016, 10:33 |
#19 |
Sheikh Ahmed
Rep Power: 10 |
Any kind of help or suggestion from anyone PLEASE? I still have the problem.
October 5, 2016, 11:26 |
problem solved
#20 |
Sheikh Ahmed
Rep Power: 10 |
I solved the problem by decreasing the number of cores in my parallel runs. It is working fine now without showing any warning msg and taking unnecessary times.
Hope this will help others. |
Coal gasification (coalChemistryFoam) | N. A. | OpenFOAM | 12 | June 29, 2017 07:22 |
Tubrogrid - Error on cut-off at TE | Flavio | CFX | 5 | January 12, 2017 09:41 |
DieselFoam and temperature out of janaf range | hoogland | OpenFOAM Running, Solving & CFD | 5 | January 28, 2016 12:30 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Residence time per temperature range | Roman | FLUENT | 0 | February 16, 2000 01:58 |
