activating field Averages
Old   August 26, 2010, 02:49
Question activating field Averages
m.maneshi's Avatar
Mehdi
m.maneshi is on a distinguished road
Hello all
there are some field averaging subroutines for example on MDTOOLS on
src/lagrangian/molecularDynamics/molecule/mdTools
which are not in effect in the tutorial files and i found no clue who to make them work. has anyone got any idea what to do?
thanks in advance.
m.maneshi is offline   Reply With Quote
Old   August 27, 2010, 03:15
Erik Arlemark
Erik is on a distinguished road
Hello Mehdi,
To get the field averaging working I included the following header files in the main solver file i.e. mdFoam.C:
# include "createMDFields.H"
# include "calculateMDFields.H"
# include "averageMDFields.H"
# include "resetMDFields.H"
in the following places:
#include "fvCFD.H"
#include "md.H"
int main(int argc, char *argv[])
# include "setRootCase.H"
# include "createTime.H"
# include "createMesh.H"
potential pot(mesh);
moleculeCloud molecules(mesh, pot);
# include "temperatureAndPressureVariables.H"
label nAveragingSteps = 0;
Info << "\nStarting time loop\n" << endl;
while (runTime.loop())
nAveragingSteps++;
Info << "Time = " << runTime.timeName() << endl;
molecules.evolve();
# include "meanMomentumEnergyAndNMols.H"
# include "temperatureAndPressure.H"
runTime.write();
if (runTime.outputTime())
Info << "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
<< " ClockTime = " << runTime.elapsedClockTime() << " s"
<< nl << endl;
Info << "End\n" << endl;
return 0;
Cheers,
Erik
Erik is offline   Reply With Quote
Old   August 27, 2010, 03:40
m.maneshi's Avatar
Mehdi
Thanks alot . i will test it ASAP.
Old   August 27, 2010, 08:26
m.maneshi's Avatar
Mehdi
Did so and all seems to be going all well , isn't there any need to call the functions in the Control Dict or any other places ? why isnt there any new variables added to data like Density , bulk velocity and so forth ?? plus is it needed to re make the edited solver file ? Can the averaging parameters such as bin sizes and so on be changed for a run ?
Old   August 28, 2010, 11:38
Erik Arlemark
HI Mehdi,
After you added these lines did you compile the solver by running "wclean" and then "wmake" in the same folder as you have the Make directory. This needs to be done in order for any changes to be made. If this does not work then maybe you need to compile the molecule library as well by running "wclean libso" and then "wmake libso".
cheers,
Erik
Old   August 28, 2010, 13:20
m.maneshi's Avatar
Mehdi
i did the wclean libso and wmake libso after wards in the folder relating to mdfoam.c and here is the result :
HTML Code:
cd /home/mehdi/OpenFOAM/OpenFOAM-1.6/applications/solvers/discreteMethods/molecularDynamics/mdFoam/
mehdi@mehdi-laptop:~/OpenFOAM/OpenFOAM-1.6/applications/solvers/discreteMethods/molecularDynamics/mdFoam$ wclean libso
wclean ./
mehdi@mehdi-laptop:~/OpenFOAM/OpenFOAM-1.6/applications/solvers/discreteMethods/molecularDynamics/mdFoam$ wmake libso
wmakeLnInclude: linking include files to ./lnInclude
Making dependency list for source file mdFoam.C
SOURCE=mdFoam.C ;  g++ -m32 -Dlinux -DWM_DP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3  -DNoRepository -ftemplate-depth-40 -I/home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude -I/home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/potential/lnInclude -I/home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecularMeasurements/lnInclude -I/home/mehdi/OpenFOAM/OpenFOAM-1.6/src/finiteVolume/lnInclude -I/home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/basic/lnInclude -I/home/mehdi/OpenFOAM/OpenFOAM-1.6/src/meshTools/lnInclude -IlnInclude -I. -I/home/mehdi/OpenFOAM/OpenFOAM-1.6/src/OpenFOAM/lnInclude -I/home/mehdi/OpenFOAM/OpenFOAM-1.6/src/OSspecific/POSIX/lnInclude   -fPIC -c $SOURCE -o Make/linuxGccDPOpt/mdFoam.o
In file included from mdFoam.C:50:
/home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/createMDFields.H: In function ‘int main(int, char**)’:
/home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/createMDFields.H:5: error: ‘class Foam::moleculeCloud’ has no member named ‘potential’
/home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/createMDFields.H:11: error: ‘class Foam::moleculeCloud’ has no member named ‘potential’
/home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/createMDFields.H:17: error: ‘class Foam::moleculeCloud’ has no member named ‘potential’
/home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/createMDFields.H:23: error: ‘class Foam::moleculeCloud’ has no member named ‘potential’
/home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/createMDFields.H:37: error: ‘class Foam::moleculeCloud’ has no member named ‘potential’
/home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/createMDFields.H:43: error: ‘class Foam::moleculeCloud’ has no member named ‘potential’
/home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/createMDFields.H:52: error: ‘class Foam::moleculeCloud’ has no member named ‘potential’
/home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/createMDFields.H:92: error: ‘class Foam::moleculeCloud’ has no member named ‘potential’
/home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/createMDFields.H:98: error: ‘class Foam::moleculeCloud’ has no member named ‘potential’
/home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/createMDFields.H:107: error: ‘class Foam::moleculeCloud’ has no member named ‘potential’
/home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/createMDFields.H:147: error: ‘class Foam::moleculeCloud’ has no member named ‘potential’
/home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/createMDFields.H:153: error: ‘class Foam::moleculeCloud’ has no member named ‘potential’
/home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/createMDFields.H:162: error: ‘class Foam::moleculeCloud’ has no member named ‘potential’
/home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/createMDFields.H:221: error: ‘class Foam::moleculeCloud’ has no member named ‘potential’
/home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/createMDFields.H:227: error: ‘class Foam::moleculeCloud’ has no member named ‘potential’
/home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/createMDFields.H:236: error: ‘class Foam::moleculeCloud’ has no member named ‘potential’
/home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/createMDFields.H:277: error: ‘class Foam::moleculeCloud’ has no member named ‘potential’
/home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/createMDFields.H:283: error: ‘class Foam::moleculeCloud’ has no member named ‘potential’
/home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/createMDFields.H:292: error: ‘class Foam::moleculeCloud’ has no member named ‘potential’
In file included from mdFoam.C:67:
/home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/calculateMDFields.H:13: error: ‘class Foam::molecule’ has no member named ‘U’
/home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/calculateMDFields.H:17: error: ‘class Foam::molecule’ has no member named ‘mass’
In file included from mdFoam.C:69:
/home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/resetMDFields.H:5: error: ‘class Foam::moleculeCloud’ has no member named ‘potential’
/home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/resetMDFields.H:11: error: ‘class Foam::moleculeCloud’ has no member named ‘potential’
/home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/resetMDFields.H:17: error: ‘class Foam::moleculeCloud’ has no member named ‘potential’
/home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/resetMDFields.H:23: error: ‘class Foam::moleculeCloud’ has no member named ‘potential’
make: *** [Make/linuxGccDPOpt/mdFoam.o] Error 1
what point am i missing already ?
Old   August 28, 2010, 13:28
Erik Arlemark
in the folder of mdFoam.C you should only type "wclean" and then "wmake" the commands "wclean libso" and "wmake libso" should only be used in case you are compiling a library e.g. the molecule library.
Old   August 28, 2010, 13:39
m.maneshi's Avatar
Mehdi
ok did that in the mdfoam directory and here is the result :
HTML Code:
seems there is a problem with moleculeCloud ??
Old   August 28, 2010, 13:58
m.maneshi's Avatar
Mehdi
there seems nothing especial happens after compiling the solver and library and when i run the mdFoam for my problem there goes the same as before and no averaging or volume field or etc is calculated
Old   August 28, 2010, 15:06
Erik Arlemark
Ok, sorry I forgot that some changes need to be made to the molecule library. You therefore need to go to the directory:
$(LIB_SRC)/lagrangian/molecularDynamics/molecule
and do the following changes:
in createMDfields.H and resetMDfields.H you need to search and replace potential() with pot().
in calculateMDfields.H the representation of velocity U is now represented by v and the mass is no longer a molecular attribute but a property defined in the molecularPropertiesDict:
therefore, in the same file, you need to replace:
allSpeciesM_RU[molId][cell] += mol->mass();
with the two lines:
const molecule::constantProperties& constProp = molecules.constProps(molId);
allSpeciesM_RU[molId][cell] += constProp.mass();
After this you get to use commands "wclean libso" and then "wmake libso" to compile the library. Then navigate to the directory of the solver and compile using wclean and wmake.
It is neater however if you copy the solver and and molecule directories to your user folder and make the changes there. That way you preserve the original OF the default way. For this later issue I would consult the userguide.
good luck,
Erik
Old   August 29, 2010, 11:03
m.maneshi's Avatar
Mehdi
with the two lines:
did so but the U as you siad is still a problem
HTML Code:
/home/mehdi/OpenFOAM/OpenFOAM-1.6/src/lagrangian/molecularDynamics/molecule/lnInclude/calculateMDFields.H: In function ‘int main(int, char**)’:
have you got any ideas ?
Old   August 29, 2010, 12:08
Erik Arlemark
The error message that you show says that U is unknown still. So you should replace U with v.
Old   August 29, 2010, 12:23
m.maneshi's Avatar
Mehdi
hi , thanks for your replies.
so i did the replacement
the calculateMDFiels.H now is like this
HTML Code:
const List<DynamicList<molecule*> >& cellOccupancy = molecules.cellOccupancy();
forAll(cellOccupancy, cell)
    const List<molecule*>& molsInCell = cellOccupancy[cell];
    forAll(molsInCell, mIC)
        molecule* mol = molsInCell[mIC];
        const label molId = mol->id();
        const vector& molU = mol->v();
        allSpeciesN_RU[molId][cell]++;
        allSpeciesVelocitySum_RU[molId][cell] += molU;
        allSpeciesVelocityMagSquaredSum_RU[molId][cell] += molU & molU;
is it all right ? or molU and others shall be like molv and so forth ? are the replacements limited to this header file only ?
Old   August 29, 2010, 12:55
Erik Arlemark
No worries,
It should work now. molU can remain molU since it is declared and used locally.
Old   August 29, 2010, 13:08
m.maneshi's Avatar
Mehdi
so as i perform wclean and subsequently wmake here is the result
HTML Code:
/usr/lib/crt1.o: In function `_start':
/build/buildd/glibc-2.9/csu/../sysdeps/i386/elf/start.S:115: undefined reference to `main'
collect2: ld returned 1 exit status
make: *** [OpenFOAM.out] Error 1
Old   August 29, 2010, 13:44
Erik Arlemark
I think you are trying to use wclean and wmake commands for compiling the molecule class. This does not work since it does not have main in it. The molecule class should be compiled using wclean libso and then wmake libso. Then navigate to the solver and use the wclean and wmake commands.
Old   August 29, 2010, 16:03
m.maneshi's Avatar
Mehdi
Thanks alot. it finally solve the problem. just one other question to ask . is it possible to change the binning size for the calculation of average values ?
Old   August 29, 2010, 16:37
Erik Arlemark
No problem. The averaging is done cell wise so these bins sizes are determined from the blockMeshDict file.
Old   September 8, 2010, 13:29
m.maneshi's Avatar
Mehdi
followed your leads and all seems to work fine . there remains but two questions of you could help i would be most grateful.
First of all when modeling a simple nano pressure driven channel with a gravity like .5 along the channel and periodic inlet / outlet the simulation never reaches a steady state even after 5*10^-11 seconds. why is it so ?
Second is that averages Calculated for run are very mesh size dependent as anticipated but there seems to be no appropriate mesh size to create smooth profiles for density , velocity and so forth ? what is wrong wish cell averaging ? must i resume with some other methods ?
Thanks in advance .
Phase Field modeling in OpenFOAM adona058 OpenFOAM Running, Solving & CFD 35 November 16, 2021 00:16
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Turbulence dampening due to magnetic field in LES and RAS eelcovv OpenFOAM 0 June 8, 2010 11:35
Zero size field taranov OpenFOAM Bugs 2 April 20, 2010 04:51
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 06:51
