Convergence problem with tetrahedral grids
Like Tree3Likes
Old   December 2, 2010, 17:58
Default Convergence problem with tetrahedral grids
Tarak
Tarak is on a distinguished road
Hii,
I am running the case of flow over a square cylinder using LES by ICEM generated grid. But only after a few time steps, the code diverges, with Courant number crossing 4 or 5. I tried to use Upwind Schemes as well as first order time stepping to tackle the problem, but still the issue wasn't solved. At last, I increased the number of PISO non-orthogonal correctors to 5 (since increasing to 3 didn't help), and now its converging, but its painstakingly slow.
Can you please let me know of a way by which I can run OF with tethrahedral grids smoothly.
Thanks,
Tarak
Tarak is offline   Reply With Quote
Old   December 3, 2010, 04:28
maddalena's Avatar
maddalena
maddalena will become famous soon enough
I am also facing difficulties on getting a 3D tetra mesh converging with OF 1.6.x.
The case is quite standard: some pipes with two fans that put the fluid in motion. The geometry is complex and I have no possibility to use a hexa mesh. The case is steady state and turbulent (simpleFoam); BC are as tested on similar (working) cases.
fvSchemes are:
gradSchemes: faceMDLimited Gauss linear 0.5;
divSchemes: Gauss linearUpwind cellLimited Gauss linear 1;
laplacianSchemes: Gauss linear limited 0.5;
fvSolution:
p
        solver          GAMG;
        tolerance       1e-12;
        relTol          0;
        smoother        GaussSeidel;
        nPreSweeps      0;
        nPostSweeps     2;
        cacheAgglomeration true;
        nCellsInCoarsestLevel 10;
        agglomerator    faceAreaPair;
        mergeLevels     1;
    U - epsilon - k
        solver          smoothSolver;
        tolerance       1e-10;
        relTol          0;
SIMPLE
    nNonOrthogonalCorrectors 2;
    pRefCell        0;
    pRefValue       0;
relaxationFactors  ///really low in the beginning to let the simulation start.
    default         0;
    p               0.05;
    U               0.2;
    k               0.2;
    epsilon            0.2;
    nuTilda            0.3;
The solution converges for the first 150 steps nicely, but after on it start to get unstable and finally crashes. I really do not know what to do for keep it running...
Suggestions?
mad
maddalena is offline   Reply With Quote
Old   December 3, 2010, 04:54
Vesselin Krastev
vkrastev is on a distinguished road
fvSchemes are:
fvSolution:
p
        solver          GAMG;
        tolerance       1e-12;
        relTol          0;
        nPreSweeps      0;
        nPostSweeps     2;
        mergeLevels     1;
    U - epsilon - k
        tolerance       1e-10;
        relTol          0;
SIMPLE
    pRefCell        0;
    pRefValue       0;
    default         0;
    p               0.05;
    U               0.2;
    k               0.2;
    epsilon            0.2;
    nuTilda            0.3;
Suggestions?
mad
Hi Maddalena,
if you are using linearUpwind for all the divSchemes, try instead to set div(phi,U) to Gauss linearUpwindV faceMDLimited Gauss linear 1, and div(phi,k/epsilon) to Gauss upwind. By the way, why so strong underrelaxation factors? Have you tried to leave the URF for p at the 0.3 standard value, for U at 0.7 and to set the URF's for k and epsilon to 0.4-0.5?
Best Regards
Vesselin
vkrastev is offline   Reply With Quote
Old   December 3, 2010, 04:57
Vesselin Krastev
Originally Posted by Tarak View Post
Hii,
Thanks,
Tarak
Hi Tarak,
two hints: 1) use hexa-meshes for LES calculations; 2) you cannot use first order schemes for LES, because they are too diffusive: you'll have to use at least a limited second order scheme, such as limitedLinear.
Best regards
Vesselin
Old   December 3, 2010, 05:02
Vesselin Krastev
Oops, I haven't noticed the comment in the fvSolution dictionary So
, let me change the question: what are your URF's after the first n-steps in which you leave so low values?
Old   December 3, 2010, 05:29
maddalena's Avatar
maddalena
Unfortunately, I cannot get too far to have the time to increase them! After 120 steps the solution starts to be unstable, thus increase them sounds as not a good idea...
you want to increase diffusion of turbulence quantities, do not you?
BTW... sounds a bit weird that, whenever I change my fvSchemes & fvSolution, I cannot get too far with my simulation. May there be something more subtle than this? May be due to the 2 fan BC I imposed?
mad
PS: seems like in the last day we are the only active people in the forum
Old   December 3, 2010, 06:37
Vesselin Krastev
Yes, It's a matter of trade-off between accuracy and stability: I've noticed in some of my runs that changing only the div(phi,U) scheme to something more accurate than the first order upwind, gives very significant improvements to the results comparing with an all-upwind setting for the divSchemes. On the other hand, till now, with tetra-dominant meshes I was not able to reach satisfactory convergemce patterns for k and epsilon with higher order schemes...So, better a quite accurate and converging result, than a very accurate but no-converging-at-all result...
Yes, the problem could be easily far from the fvSchemes/Solution tuning (what is your checkMesh "opinion" about it?)...unfortunately I have no experience with fan BC's, so I cannot give you any useful advice...
So it seems...
Vesselin
Old   December 3, 2010, 07:33
maddalena's Avatar
maddalena
Especially if you have some close-by deadlines...
    Overall domain bounding box (-12 -1.804 -7.19731e-17) (14.905 1.804 10.0839)
    Mesh (non-empty, non-wedge) directions (1 1 1)
    Mesh (non-empty) directions (1 1 1)
    Boundary openness (-3.66027e-18 -7.23166e-17 -1.6178e-15) OK.
    Max cell openness = 2.94713e-16 OK.
    Max aspect ratio = 7.21422 OK.
    Minumum face area = 2.38932e-06. Maximum face area = 0.734457.  Face area magnitudes OK.
    Min volume = 2.87124e-09. Max volume = 0.183334.  Total volume = 327.312.  Cell volumes OK.
    Mesh non-orthogonality Max: 65.408 average: 20.4121
    Non-orthogonality check OK.
    Face pyramids OK.
    Max skewness = 0.763815 OK.
checkMesh says that the problem lies somewhere else...
I will give a try to upwind on k and epsilon. Thank you in the meanwhile..
mad
Old   December 3, 2010, 08:25
Vesselin Krastev
That's for sure!
    Face pyramids OK.
I agree with "him"
Good luck!
V
Old   December 6, 2010, 12:33
santiagomarquezd's Avatar
Santiago Marquez Damian
santiagomarquezd will become famous soon enough
Hi Tarak, Did you try renumberMesh after importing the mesh to FOAM? I've found that meshes imported from Fluent are not very efficient in the numeration and this impacts strongly in iterative solvers.
Regards.
Santiago MÁRQUEZ DAMIÁN, Ph.D.
Research Scientist
Research Center for Computational Methods (CIMEC) - CONICET/UNL
Tel: 54-342-4511594 Int. 7032
Colectora Ruta Nac. 168 / Paraje El Pozo
(3000) Santa Fe - Argentina.
http://www.cimec.org.ar
santiagomarquezd is offline   Reply With Quote
Old   December 7, 2010, 02:09
maddalena's Avatar
maddalena
NB: this will not work if you have cyclic patch! When renumbering mesh, the cyclics will be lost!
mad
Old   February 7, 2011, 03:38
Default suggestions?
  #12
maddalena's Avatar
maddalena
Hi everybody,
seems like all my problems are still there, on a case that is similar to what posted above. I wrote on a different thread: http://www.cfd-online.com/Forums/ope...tml#post293910
Maybe you can take a look to it and suggest something more on the subject...
mad
Old   February 7, 2011, 10:16
Travis Carrigan
tcarrigan is on a distinguished road
This is the thread I meant to post on. I started clicking your links and posted to the wrong one . I'll repeat my post:
Just curious, have you tried using leastSquares for the gradScheme?
I did some 2D calculations for a NACA airfoil using both structured and unstructured grids. I too suffered convergence issues when running the calculation for the unstructured case. However, switching the gradScheme to a cellLimited leastSquares happened to solve the problem.
Let me know if this works.
And to answer your question, there may not be an advantage to using leastSquares, it's just an observation made from several simulations I've run for unstructured grids. Most of the time I have issues obtaining convergence when using tet grids and the Gauss linear gradScheme. Just and observation, was curious to see if it had any effect on your calculation.
tcarrigan is offline   Reply With Quote
Old   February 7, 2011, 10:20
maddalena's Avatar
maddalena
Ok, I'll give it a try...
mad
Old   February 7, 2011, 11:26
Tarak
Hii,
I would recommend using Gamma Differencing Scheme with appropriate blending factor for obtaining good convergence/stability for tetrahedral grids. This is how I managed to get the code run.
Thanks,
Tarak
Old   February 9, 2011, 04:27
maddalena's Avatar
maddalena
So, here an answer to your observations: http://www.cfd-online.com/Forums/ope...tml#post294338
mad
Old   February 9, 2011, 08:57
Hrvoje Jasak
In 1.6-ext, we've got special discretisation scheme for tet meshes: use it on convection in the momentum equation and on interpolate(U). The scheme is called reconCentral, and the settings for a tet mesh look like this:
gradSchemes
default cellLimited leastSquares 1.0;
divSchemes
div(phi,U) Gauss reconCentral cellLimited leastSquares 1.0;
laplacianSchemes
default Gauss linear limited 0.5;
interpolationSchemes
default linear;
interpolate(HbyA) linear;
interpolate(U) reconCentral phi cellLimited leastSquares 1.0;
Enjoy,
Hrv
fumiya and Traction like this.
Hrvoje Jasak
Old   April 9, 2016, 19:13
Sami
Mehrez is on a distinguished road
Hi Foamers,
I am facing the same problem using multiphaseEulerFoam (OpenFoam 2.3.0) on Ubuntu 16.
In fact, my geometry is discretized by a tetrahedral mesh and when I run checkMesh, I get the Mesh OK message.
My problem is that the solver craches because the simulations become quickly unstable and the Courant number diverges. Using adaptable time steps didn't help.
I have tried to modify my fvSchemes as described above but this didn't help. Here is my fvSchemes :
ddtSchemes
default Euler;
gradSchemes
divSchemes
default none;
"div\(phi,alpha.*\)" Gauss reconCentral cellLimited leastSquares 1.0;
"div\(phir,alpha.*,alpha.*\)" Gauss vanLeer;
"div\(phiAlpha.*,U.*\)" Gauss limitedLinearV 1;
div(Rc) Gauss linear;
"div\(phi.*,U.*\)" Gauss limitedLinearV 1;
laplacianSchemes
default Gauss linear corrected;
default linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p ;
pcorr ;
I saw different threads exposing this problem (unstable OpenFoam solvers with tetrahedral meshes) but didn't find a solution. Your help will be appreciated.
Thank you.
Mhrz
gradSchemes
divSchemes
laplacianSchemes
default linear;
Enjoy,
Hrv
Mehrez is offline   Reply With Quote
Old   April 11, 2016, 14:43
Travis Carrigan
Mehrez,
I run hybrid prism, pyramid, tet meshes using OpenFOAM pretty frequently and have come up with a standard fvSchemes dictionary that I start with every time. I also have a fvSolution dictionary that I've created that works equally well coupled with the changes I made to fvSchemes. Both are listed below for your reference.
fvSchemes
ddtSchemes
default steadyState;
gradSchemes
default faceMDLimited Gauss linear 0.333;
divSchemes
default none;
div(phi,U) bounded Gauss linearUpwindV grad(U);
div(phi,U) bounded Gauss upwind;
div(phi,nuTilda) bounded Gauss upwind;
div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
default Gauss linear limited 0.333;
default linear;
snGradSchemes
default limited 0.333;
fluxRequired
default no;
pcorr ;
p ;
fvSolution
solvers
p
solver GAMG;
tolerance 1e-6;
relTol 0.01;
smoother FDIC;
nPreSweeps 1;
nPostSweeps 2;
nFinestSweeps 2;
cacheAgglomeration on;
nCellsInCoarsestLevel 1000;
mergeLevels 1;
U
type coupled;
solver PBiCCCG;
preconditioner DILU;
tolerance (1e-6 1e-6 1e-6);
relTol (0.01 0.01 0.01);
"(k|omega|nuTilda)"
solver PBiCG;
tolerance 1e-6;
relTol 0.01;
SIMPLE
nNonOrthogonalCorrectors 3;
potentialFlow
nNonOrthogonalCorrectors 10;
relaxationFactors
fields
p 0.2;
equations
U 0.5;
k 0.5;
omega 0.5;
nuTilda 0.5;
cache
grad(U);
ashish.vinayak likes this.
Travis Carrigan
Manager, Business Development
Pointwise, Inc.
Old   April 11, 2016, 15:40
Question
  #20
Sami
Dear tcarrigan,
Thank you for your answer and for sharing your files.
I have edited my fvSchemes and fvSolution files as follows:
fvSchemes
ddtSchemes
default steadyState;//Euler;
gradSchemes
default faceMDLimited Gauss linear 0.333;//Gauss linear;
divSchemes
default none;
"div\(phi,alpha.*\)" bounded Gauss upwind;//Gauss vanLeer;
"div\(phir,alpha.*,alpha.*\)" bounded Gauss upwind;//Gauss vanLeer;
"div\(phiAlpha.*,U.*\)" bounded Gauss linearUpwindV grad(U);//Gauss limitedLinearV 1;
"div\(phiAlpha.*,U.*\)" bounded Gauss upwind;//Gauss limitedLinearV 1;
"div\(phi.*,U.*\)" bounded Gauss linearUpwindV grad(U);//Gauss limitedLinearV 1;
"div\(phi.*,U.*\)" bounded Gauss upwind;//Gauss limitedLinearV 1;
laplacianSchemes
default Gauss linear limited 0.333;//Gauss linear corrected;
default linear;
snGradSchemes
default limited 0.333;//corrected;
fluxRequired
default no;
p ;
pcorr ;
fvSolution
solvers
alpha
nAlphaSubCycles 2;
p
solver GAMG;
tolerance 1e-6;
relTol 0.01;
smoother FDIC;
nPreSweeps 1;
nPostSweeps 2;
nFinestSweeps 2;
mergeLevels 1;
pFinal
$p;
tolerance 1e-14;
relTol 0;
pcorr
$p;
tolerance 1e-14;
relTol 0;
"U.*"
type coupled;
solver PBiCCCG;
PIMPLE
nOuterCorrectors 1;
nCorrectors 2;
relaxationFactors
fields
p 0.2;
equations
U 0.5;
cache
grad(U);
I have tried to run a simulation using these files but it goes quickly unstable. Here is a copy of my log file where the deltaT is going down:
Courant Number mean: 0.0021156010062783 max: 0.049408733271849
deltaT = 7.6566763768132e-19
Time = 6.18252270356846e-06
MULES: Solving for alpha.gas
gas volume fraction, min, max = 0.30019748795334 0.23897356139625 0.41705604707805
MULES: Solving for alpha.liquid
liquid volume fraction, min, max = 0.70087632594298 0.3 0.86565308392893
Phase-sum volume fraction, min, max = 1.0010738138963 0.59999999999999 1.1699030447477
gas volume fraction, min, max = 0.30019798328777 0.2386702783917 0.41704447896555
liquid volume fraction, min, max = 0.70087752844775 0.3 0.86618197518773
Phase-sum volume fraction, min, max = 1.0010755117355 0.59999999999999 1.1703801282208
GAMG: Solving for p, Initial residual = 0.23419353824923, Final residual = 0.0023325036575349, No Iterations 2
GAMG: Solving for p, Initial residual = 0.052855980175197, Final residual = 0.0003817033201444, No Iterations 2
GAMG: Solving for p, Initial residual = 0.014025336427512, Final residual = 8.8046943721164e-05, No Iterations 2
GAMG: Solving for p, Initial residual = 0.0048650690815121, Final residual = 4.0782603314908e-05, No Iterations 2
time step continuity errors : sum local = 9.3649763390591e-09, global = 7.9493516767848e-10, cumulative = 8.2571867820764e-08
GAMG: Solving for p, Initial residual = 0.20867553926075, Final residual = 0.00073649732328669, No Iterations 3
GAMG: Solving for p, Initial residual = 0.050332050313325, Final residual = 0.00029712401985861, No Iterations 2
GAMG: Solving for p, Initial residual = 0.013334743089887, Final residual = 8.741559351822e-05, No Iterations 2
GAMG: Solving for p, Initial residual = 0.0048312307962256, Final residual = 7.7390130904333e-15, No Iterations 26
time step continuity errors : sum local = 1.8252376105909e-18, global = -3.8452675495394e-20, cumulative = 8.2571867820725e-08
ExecutionTime = 424.27 s
Expression Re_l : average=2.7438854159252e+20 min=6.7983965132898e+18 max=4.2263684536994e+21
Expression Re_g : average=1.2645680808052e+20 min=3.1815443817709e+18 max=2.7037109361158e+21
Expression rho_avg : average=489.19817329068 min=447.12039199452 max=600.27512277584
Expression head : average=9022.1840703653
Expression alpha_g on outlet_gas: average=0.30283498588815 min=0.2386702783917 max=0.36663713347938
Expression alpha_g on outlet_liquid: average=0.3006588178025 min=0.2974219141048 max=0.30429082494955
Expression alpha_g on inlet: average=0.3 min=0.3 max=0.3
Expression Q_all on outlet_gas: sum=-24210659648582 min=-4793324780552.7 max=247183322085.2
Expression Q_all on outlet_liquid: sum=17816623940489 min=193138733172.99 max=521444731230.64
Expression Q_all on inlet: sum=6394035708093.2 min=-1215092696559.3 max=597712717234.6
Expression Q_l on outlet_gas: sum=-17262638871291 min=-3156101143802.7 max=235004594945.67
Expression Q_l on outlet_liquid: sum=12558463445253 min=137931428364.81 max=379354434355.94
Expression Q_l on inlet: sum=1580810441283.7 min=-596686394611.29 max=299229574724.19
Expression Q_g on outlet_gas: sum=-6948020777290.6 min=-1637223636750 max=794642130398.71
Expression Q_g on outlet_liquid: sum=5258160495235.8 min=51791175935.031 max=161116494634.18
Expression Q_g on inlet: sum=4813225266809.5 min=-618406301947.99 max=305405324047.52
Expression p_avg on outlet_gas: average=0 min=0 max=0
Expression p_avg on outlet_liquid: average=7000 min=7000 max=7000
Expression p_avg on inlet: average=9003.4061139999 min=9003.4061139999 max=9003.4061139999
Expression recycle on outlet_liquid: sum=2.7864442355142
Expression p_inlet on inlet: average=9003.4061139999
Expression p_inlet_proporionalTerm on inlet: average=0
Thank you for your help,
Mhrz
convergence problem commonyue Main CFD Forum 1 December 1, 2009 03:54
Submerged fin, Convergence problem supermouniette FLUENT 10 July 6, 2009 10:47
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
convergence problem in comsol anderson COMSOL 0 February 24, 2008 16:54
CONVERGENCE PROBLEM - oil boiler MM FLUENT 1 February 15, 2007 05:24
