interTrackFoam faMesh error
Old   February 7, 2011, 07:05
Default interTrackFoam faMesh error
Tong Zhongyao
lionlove0903 is on a distinguished road
Hello everyone,
I am trying to solve a inclined film flow problem with interTrackFoam, but I am in trouble with the faMesh. This is my blockMeshDict:
convertToMeters 1;
vertices
(0 0 0)
(0.1 0 0)
(0 0.005 0)
(0.1 0.005 0)
(0 0.01 0)
(0.1 0.01 0)
(0 0 0.001)
(0.1 0 0.001)
(0 0.005 0.001)
(0.1 0.005 0.001)
(0 0.01 0.001)
(0.1 0.01 0.001)
blocks
hex (0 1 3 2 6 7 9 8) (100 5 1) simpleGrading (1 1 1)
hex (2 3 5 4 8 9 11 10) (100 5 1) simpleGrading (1 1 1)
edges
patches
wall bottom
(0 1 7 6)
patch inlet1
(0 2 8 6)
patch inlet2
(2 4 10 8)
patch outlet
(1 3 9 7)
(3 5 11 9)
patch freeSurface
(4 5 11 10)
empty frontAndBackPlanes
(0 1 3 2)
(6 7 9 8)
(2 3 5 4)
(8 9 11 10)
mergePatchPairs
And this is my faMeshDefinition:
polyMeshPatches 1( freeSurface );
boundary
inlet1
type patch;
ownerPolyPatch freeSurface;
neighbourPolyPatch inlet1;
inlet2
type patch;
neighbourPolyPatch inlet2;
outlet
type patch;
neighbourPolyPatch outlet;
frontAndBack
type empty;
neighbourPolyPatch frontAndBackPlanes;
And this is my error message:
Create time
Create mesh for time = 0
Create faMesh ... Done
Add faPatches ... bool faBoundaryMesh::checkDefinition(const bool report) const : Problem with boundary patch 0.
The patch should start on face no 99 and the boundary file specifies 100.
bool faBoundaryMesh::checkDefinition(const bool report) const : Problem with boundary patch 1.
The patch should start on face no 100 and the boundary file specifies 101.
bool faBoundaryMesh::checkDefinition(const bool report) const : Problem with boundary patch 2.
The patch should start on face no 101 and the boundary file specifies 57.
--> FOAM Serious Error :
From function bool faBoundaryMesh::checkDefinition(const bool report) const
in file faMesh/faBoundaryMesh/faBoundaryMesh.C at line 280
This mesh is not valid: boundary definition is in error.
Done
Write finite area mesh ... Done
I have created the mesh with blockMesh command.
I have solved the problem with one 'inlet', but when I divided the inlet boundary into two parts, the problem comes out.
By the way, I can not compile the groovyBC in OpenFOAM-1.6-ext, so I have to divided the inlet into different parts to define different velocity. Has anyone successfully compiled groovyBC in OF-1.6-ext?
Can anyone help me?
Thanks a lot!
lionlove0903 is offline   Reply With Quote
Old   February 8, 2011, 09:57
Bernhard
Bernhard is on a distinguished road
What was your solution for one inlet? I don't get any error when I change the patches to walls, but that is not what you want probably.
By the way, I had no problems with groovyBC for 1.6-ext.
Bernhard is offline   Reply With Quote
Old   February 9, 2011, 03:23
Tong Zhongyao
Dear Bernhard,
I modified the faMeshDefinition document and deleted the 'inlet1' like this:
boundary
inlet2
type patch;
outlet
type patch;
frontAndBack
type empty;
Now the interTrackFoam works. I think maybe it is because 'inlet1' is not the 'neighbourPolyPartch' of the freeSurface Patch.
But I still can not compile the groovyBC in OpenFOAM-1.6-ext. I downloaded the OpenFOAM-1.6-ext from http://openfoamwiki.net/index.php/Installation with the command: sudo apt-get install openfoam-1.6-ext. And I downloaded the GroovyBC from http://openfoamwiki.net/index.php/Contrib_groovyBC with svn. I can compile it in the OpenFOAM-1.7.1 and OpenFOAM-1.6.
So my questions are:
1. Did you install OpenFOAM-1.6-ext in this way or you compiled it yourself?
2. Have you tried to run the interTrackFoam in the parallel way?
Thank you very much for your reply!
Old   February 9, 2011, 03:32
Bernhard
1. I've downloaded the source, and compiled using ./Allwmake
2. No, I've not run interTrackFoam in parallel yet, but I'm planning to do it in the futur. I've seen that that's not straightforward, but managable.
What were your problems in installing groovyBC for 1.6-ext? Sooner or later you want to use it anyway I suppose.
Old   February 9, 2011, 03:59
Tong Zhongyao
Can you tell me where you downloaded the source and how to compile it? I used to download the source in this way:
git clone git://openfoam-extend.git.sourceforge.net/gitroot/openfoam-extend/OpenFOAM-1.6-ext
then I source the bashrc in etc and ./Allwmake, but I can not compile it successfully.
My system is ubuntu 10.04 32bit and I have installed the OpenFOAM-1.7.1 on it.
Old   February 9, 2011, 04:36
Bernhard
I got it from the same location of course, but without error messages it is difficult to say what went wrong. Furthermore, I don't know why you want to go through compiling again, that won't solve your groovyBC problem.
Old   February 9, 2011, 05:01
Tong Zhongyao
Because I found the OpenFOAM-1.6-ext I installed with 'sudo apt-get install openfoam-1.6-ext' has the different directories from the version I got from 'git clone git://openfoam-extend.git.sourceforge.net/gitroot/openfoam-extend/OpenFOAM-1.6-ext'. I mean the directory structures are different in the two versions. And the latter one has the same directory structure with OpenFOAM-1.7.1 and OpenFOAM-1.6.
When I compile groovyBC in my installed OpenFOAM-1.6-ext, the program can not find the documents because there are no such directories as in standard version OpenFOAMs.
Would you please tell me what system and gcc version you are using?
Thanks!
Old   February 9, 2011, 05:28
Bernhard
This version was compiled on SuSE 11.1 and with gcc 4.3.2. But please a open a new topic about your installation issues, so more people will find it to help you out.
Old   February 9, 2011, 05:32
Tong Zhongyao
Yes, I think I must do that because it is so difficult to compile OpenFOAM.
Thank you very much, Bernhard
intertrackfoam
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 17:43
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
user defined function cfduser CFX 0 April 29, 2006 10:58
