slow convergence in chtMultiRegionSimpleFoam
Like Tree6Likes
  • 4 Post By ulli
  • 2 Post By anothr_acc
Old   March 4, 2011, 08:24
Default slow convergence in chtMultiRegionSimpleFoam
Sven Degner
sven82 is on a distinguished road
Hi Foamers,
I simulate a cht-case.
the case setup for the fluid
p{
solver GAMG;
tolerance 1e-6;
relTol 0.01;
".*" //other fields
solver PBiCG; //also GAMG
tolerance 1e-7;
relTol 0.1; //also 0.01 and 0
The relaxation are
T 1;
k,omega 0.7;
U 0.4;
p 0.7;
the same for the solid temperaturefield.
The problem is the very slow convergence,
the delta temprature between the iteration steps (deltat)
are something like 0.003 Kelvin !!!????
Im not sure how I come two a faster convergence?
I try also relTol from 0.01 and 0.
and lower relaxations.
But for my eyes the relaxation
got high values
sven82 is offline   Reply With Quote
Old   January 9, 2012, 03:40
M3hdi is on a distinguished road
Hi sven82,
I am facing the same problem of low convrgence for T field in the solid region in a CHT case.
Have you solved the issu since then ?
Thanks in advance
M.
M3hdi is offline   Reply With Quote
Old   January 9, 2012, 04:53
Ulrich Heck
ulli is on a distinguished road
Dear all,
we got a much fast convergence for chtMultiRegionSimpleFoam in many cases when we increase the number of iterations for T in the solid region (e.g. more nonOrthogonalCorrectors in the solid regions).
Hope this helps.
Ulli
ulli is offline   Reply With Quote
Old   January 24, 2012, 07:40
Tibor Nyers
Toorop is on a distinguished road
Hi Ull,
great tip, the increased iteration number really helps the cht solver in the solid domain.
Anyone with experience on the topic of chtMultiRegionFoam solvers? When to use the steady-state / transient version?
Toorop is offline   Reply With Quote
Old   October 2, 2014, 10:15
ms
anothr_acc is on a distinguished road
I was in the same place, using layers in OF 2.3.0 with compressible::turbulentTemperatureCoupledBaffleMix ed. While I don't understand why convergence is so different with solids with and without layers, my incredibly slow convergence (days with 48 cores, steady state and a few hundred thousand cells) was accelerated by adjusting the relaxation factor for h up from 0.7 to 0.9. I saw no difference with nNonOrthogonalCorrectors as my convergence criteria were being met on the second sub-iteration. Successive iterations caused by setting nNonOrthogonalCorrectors gave no change to h residuals.
Good luck all.
Mark.
derekm and dasa like this.
anothr_acc is offline   Reply With Quote
Slow convergence of chtMultiRegionSimpleFoam crmccreary OpenFOAM 1 November 11, 2010 20:52
Convergence of CFX field in FSI analysis nasdak CFX 2 June 29, 2009 01:17
Ultra slow convergence velocity in the simulation demigod FLUENT 1 October 5, 2005 08:03
Slow convergence for Boundary Layer flow Biga Main CFD Forum 2 November 18, 2004 16:51
Slow convergence Jesper CFX 1 July 7, 2004 16:59
