reactingFoam crashes mysteriously
Old   March 20, 2011, 08:30
Default reactingFoam crashes mysteriously
José Rodrigues
jose_rodrig is on a distinguished road
hi forum,
I am experiencing lots of instability with the solver reactionFoam with parallelization and they are not the janafthermo sort
My domain has around 260 000 elements and was divided in 32 domains for parallelization - divided as (16 2 1) to minimize proc borders. Im using the chemkin reader to read a single step combustion of CH4 oxidation in a GT combustor (diffusion flames). Inlet velocities are between 20 and 50 m/s.
I started fixing Courant No to 0.1. Everything looks good for about thousands of iterations but suddenly it crashes with a floating point exception. I say suddendly because I dont see a change in timestep or even the problematic janafThermo error message.
Also, it never crashes at the same timestep: if I simply restart the solver with the same parameters (no CourantNo change or any other) it will crash in a different timeStep.
It just goes!... as you can see in the following output after decreasing CourantNo to 0.035 (it still crashes!). I also attached a txt with the complete error message. Bellow the output i also posted the fvSolution and fvSchemes so you can take and criticize.
Thank you
José
DILUPBiCG: Solving for epsilon, Initial residual = 4.32044e-06, Final residual = 9.94436e-09, No Iterations 1
DILUPBiCG: Solving for k, Initial residual = 1.74131e-06, Final residual = 3.09184e-09, No Iterations 1
ExecutionTime = 161537 s ClockTime = 164174 s
Courant Number mean: 0.00125684 max: 0.0349221
deltaT = 3.80307e-07
Time = 0.3549768
Solving chemistry
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG: Solving for Ux, Initial residual = 1.19096e-05, Final residual = 6.46123e-09, No Iterations 1
[24] #0 Foam::error:rintStack(Foam::Ostream&)[25] #0 Foam::error:rintStack(Foam::Ostream&)[26] #0 Foam::error:rintStack(Foam::Ostream&)[27] #0
fvSolution
solvers
rho
solver PCG;
preconditioner DIC;
tolerance 1e-06;
relTol 0;
p
solver PCG;
preconditioner DIC;
tolerance 1e-6;
relTol 0.0;
pFinal
solver PCG;
preconditioner DIC;
tolerance 1e-6;
relTol 0.0;
"(U|Yi|hs|k|epsilon)"
solver PBiCG;
preconditioner DILU;
tolerance 1e-06;
relTol 0;
PISO
nCorrectors 3;
nNonOrthogonalCorrectors 6;
relaxationFactors
rho 0.6;
U 0.6;
pFinal 0.4;
p 0.4;
k 0.6;
epsilon 0.6;
hs 0.6;
T 0.6;
fvSchemes
ddtSchemes
default Euler; //CrankNicholson 1; //Euler;
gradSchemes
default Gauss linear;
grad(p) Gauss linear;
divSchemes
default none;
div(phi,U) Gauss limitedLinearV 1;
div(phi,Yi_h) Gauss limitedLinear01 1;
div(phi,hs) Gauss limitedLinear 1;
div(phiU,p) Gauss limitedLinear 1;
div(phid,p) Gauss limitedLinear 1;
div(phi,epsilon) Gauss limitedLinear 1;
div(phi,k) Gauss limitedLinear 1;
div((muEff*dev2(grad(U).T()))) Gauss linear;
laplacianSchemes
default Gauss linear uncorrected;
laplacian(muEff,U) Gauss linear uncorrected;
laplacian(mut,U) Gauss linear uncorrected;
laplacian(DkEff,k) Gauss linear uncorrected;
laplacian(DepsilonEff,epsilon) Gauss linear uncorrected;
laplacian((rho*(1|A(U))),p) Gauss linear uncorrected;
laplacian(alphaEff,hs) Gauss linear uncorrected;
interpolationSchemes
default linear;
snGradSchemes
default uncorrected;
fluxRequired
default no;
p;
jose_rodrig is offline   Reply With Quote
Old   March 20, 2011, 09:01
Default error log
José Rodrigues
sorry, forgot the attachment
Old   March 21, 2011, 03:52
Alberto Passalacqua
does it always crash on the same equation, namely Uy?
I have a similar problem with another solver, if I use PBiCG solvers with DILU preconditioner. You might want to try with another type of linear solver for that equation to verify if it still happens.
Best,
Alberto Passalacqua
Old   March 21, 2011, 04:52
José Rodrigues
Hi alberto,
No, it crashes pretty randomly.
Actually, my simulation crashes in two ways:
a) mpi sends a message of "floating point exception" error (signal 8);
b) mpi sends a message of "Hang Up" (signal 1)
Are these 2 types of error related?
A workmate told me that openFoam sometimes hangs on opensuse (i am using 11.4): do you think this might be the problem?
Old   March 21, 2011, 05:05
Alberto Passalacqua
Originally Posted by jose_rodrig View Post
Hi alberto,
I am using the same distribution, but I use openMPI from the ThirdParty package, even though I use the system gcc compiler (4.5), so I would exclude distro-specific problems. I also observe a similar behaviour on RHEL 5.2.
Out of curiosity, do you use the system OpenMPI, the one in ThirdParty or a different version?
Best,
Alberto Passalacqua
Old   March 21, 2011, 05:15
José Rodrigues
hi,
I am using openMPI 1.4.1 from the Third Party package. I've compiled OpenFOAM myself.
regards
jose
Old   March 21, 2011, 05:35
Alberto Passalacqua
OK, we are using exactly the same configuration then. I am going to test a different MPI implementation to see if it might depend on that, and I'll let you know.
Maybe you should report it as a bug however. I reported mine, but we believed it was specific to the solver. You just confirmed it is not.
Best,
Alberto Passalacqua
Old   March 21, 2011, 07:32
José Rodrigues
Ok, I ll report my problem ASAP.
One more thing, I d like you to take a look in my other post. It is not related to this one but is also turning my head around.
Here is the link http://www.cfd-online.com/Forums/ope...dary-face.html
Regards
Old   June 26, 2012, 04:42
achinta
achinta is on a distinguished road
hello reactingFoamers ,
i am new to reactingFoam solver. I am first interested in mixing of gases(without reaction). Some threads suggested reactingFoam (with chemistry switched off). I ran the solver and it crashed after 16 milliseconds. Here is my set-up
chemistry properties file
psiChemistryModel ODEChemistryModel<gasThermoPhysics>;
chemistry off; // switch off chemistry
chemistrySolver ode;
initialChemicalTimeStep 1e-07;
sequentialCoeffs
cTauChem 0.001;
EulerImplicitCoeffs
cTauChem 0.05;
equilibriumRateLimiter off;
odeCoeffs
solver SIBS;
eps 0.05;
scale 1;
Combustion properties file
combustionModel PaSR<psiChemistryCombustionModel>;
active false; //combustion switched off
infinitelyFastChemistryCoeffs
C 10.0;
PaSRCoeffs
Cmix Cmix [ 0 0 0 0 0 0 0 ] 0.1;
turbulentReaction off; //switched off
reactions file
species
O2
H2O
CH4
CO2
N2
reactions
methaneReaction
type irreversibleArrheniusReaction;
reaction "CH4 + 2O2 = CO2 + 2H2O";
A 5.2e16;
beta 0;
Ta 14906;
Thermophysical properties file
thermoType hsPsiMixtureThermo<reactingMixture<gasThermoPhysic s>>;
inertSpecie N2;
chemistryReader foamChemistryReader;
foamChemistryFile "$FOAM_CASE/constant/reactions";
foamChemistryThermoFile "$FOAM_CASE/constant/thermo.compressibleGas";
i am using SST turbulence model. Below are the boundary conditions:
mut and alphat
internalField uniform 0;
boundaryField
INLET
type fixedValue;
value uniform 0;
OUTLET
type zeroGradient;
mut for walls
type mutUSpaldingWallFunction;
value uniform 0;
alphat for walls
type alphatWallFunction;
Prt 0.85;
value uniform 0;
T:
internalField uniform 550;
boundaryField
INLET_FUEL
type fixedValue;
value uniform 293;
INLET_AIR
type fixedValue;
value uniform 550;
OUTLET
type zeroGradient;
WALL
type zeroGradient;
I don't think there could be problems with boundary conditions of U,CH4,N2,O2,k,omega and Ydefault and i won't write them here as it will lengthen the post.
There error message seems to do something with mut wall function and happens because its diverging-Tempearure is going out of range. But the Courant number is below 1. Probably, i have to improve my fvSchemes and fvSolution
fvSchemes
ddtSchemes
default backward;
gradSchemes
divSchemes
default none;
div(phi,U) Gauss linearUpwindV grad(U);
div(phi,h) Gauss limitedLinear 1;
div(phi,K) Gauss limitedLinear 1;
div(phi,omega) Gauss limitedLinear 1;
div((muEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
default Gauss linear corrected;
default linear;
snGradSchemes
default corrected;
fluxRequired
default no;
p;
fvSolution
solvers
rho
solver PCG;
preconditioner DIC;
tolerance 1e-06;
relTol 0.05;
rhoFinal
$rho;
tolerance 1e-06;
relTol 0;
p
solver PCG;
preconditioner DIC;
tolerance 1e-6;
relTol 0.05;
pFinal
$p;
tolerance 1e-6;
relTol 0.0;
"(U|hs||k|omega)"
solver PBiCG;
tolerance 1e-06;
relTol 0.05;
"(U|hs||k|omega)Final"
solver PBiCG;
tolerance 1e-06;
relTol 0;
Yi
$hsFinal;
PIMPLE
momentumPredictor no;
nOuterCorrectors 1;
nCorrectors 2;
nNonOrthogonalCorrectors 1;
I kindly request OpeFOAM experts to help me. I have spent lot of time on this problem. I didn't find many tutorials about reacting foam and i am not able to proceed with my simulation.
Regards,
Achinta
achinta is offline   Reply With Quote
Old   August 4, 2015, 10:18
Zhiyi Li
comingdaytime is on a distinguished road
hi forum,
Thank you
José
Time = 0.3549768
Solving chemistry
fvSolution
solvers
rho
solver PCG;
preconditioner DIC;
tolerance 1e-06;
relTol 0;
p
solver PCG;
preconditioner DIC;
tolerance 1e-6;
relTol 0.0;
pFinal
solver PCG;
preconditioner DIC;
tolerance 1e-6;
relTol 0.0;
solver PBiCG;
tolerance 1e-06;
relTol 0;
PISO
nCorrectors 3;
relaxationFactors
rho 0.6;
U 0.6;
pFinal 0.4;
p 0.4;
k 0.6;
epsilon 0.6;
hs 0.6;
T 0.6;
fvSchemes
ddtSchemes
gradSchemes
divSchemes
default none;
laplacianSchemes
default linear;
snGradSchemes
fluxRequired
default no;
p;
Hey,
I saw in your case, fvSolution, you used PISO algorithm. But when I don't define PIMPLE in the fvSolution, there will be an error message. Do you think the PIMPLE keyword is required necessarily?
Thank you
Bes Regard
Litchy
comingdaytime is offline   Reply With Quote
[OpenFOAM] paraFoam crashes with channelFoam example mgdenno ParaView 2 February 5, 2011 07:46
reactingFoam wedge handling wrong U dhondupant OpenFOAM Bugs 1 December 9, 2010 07:34
reactingFoam floating point exception pajofego OpenFOAM 0 November 6, 2010 17:29
reactingFoam - turbulent reacting flow hamburgFoam OpenFOAM 0 December 7, 2009 12:57
Solver crashes only while writing a bak file hagupta CFX 1 April 11, 2006 18:10
