simpleFoam symbol lookup error
Old   September 6, 2011, 11:18
Default simpleFoam symbol lookup error
botobeno is on a distinguished road
I'mworking with openFoam installed on ubuntu. The case i'm working on is an altered version of the motorBike tutorial. I've made my own mesh in Salome and i've edited motorBike to use mine. Four days ago, i successfully ran simpleFoam. I had to change all the patchnames and remove references to the motorbike.stl and all that but it worked.
Today, i tried to do the same with a finer mesh. The first one was very coarse, just a test to see if i could get it solved. I copied the previous case folder, replaced the Mesh_1.unv with the new one, did ideasUnvToFoam and made the boundary changes (patch type to wall) where needed just as i had done for the coarse mesh.
But now it gives the following error:
simpleFoam symbol lookup error: /opt/openfoam200/platforms/linuxGccDPOpt/lib/libincompressibleLESModels.so: undefined symbol: _ZN4Foam8LESdelta34destroydictionaryConstructorTab lesEv
I tried using simplefoam in my old case folder, the one with the coarse mesh that worked four days ago and it gives the same error. I've tried to google for it, but havent found anything yet. I never made any changes to that file. The only files i touch are the ones in the tutorial cases. So i suppose i did something wrong there, but i dont know what. Four ago it worked and now it doesnt work anymore. How can i fix this error?
botobeno is offline   Reply With Quote
Old   September 6, 2011, 12:55
Assistant Moderator
Bernhard Gschaider
c++filt _ZN4Foam8LESdelta34destroydictionaryConstructorTab lesEv
says the missing symbol is
Foam::LESdelta::destroydictionaryConstructorTables ()
which should be in one of the LES-libraries (nothing about your case can change that). Is it possible that in the meantime parts of your OF-installation got updated/recompiled? Try other solvers that use turbulence
Old   September 6, 2011, 13:59
I didnt update Ubuntu itself or any installed progam. It is possible that it is sneakily updating without telling me through automatic updates in the background, but nothing that i've seen or asked for.
Would reinstalling openFoam fix it?
Old   September 6, 2011, 14:07
Assistant Moderator
Bernhard Gschaider
The main suspect would have been an update of OF. Ubuntu-updates shouldn't trigger THAT kind of behaviour
Honestly: don't know. Did you compile it yourself or use binary packages?
error, openfoam, simplefoam, symbol
OpenFOAM install on Ubuntu Natty 11.04 bkubicek OpenFOAM 13 May 26, 2011 05:48
compile errors of boundary condition "expDirectionMixed" liying02ts OpenFOAM Bugs 2 February 1, 2010 20:11
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
[Netgen] Installation of Netgen in SuSE Linux 92 edvardsenpriv OpenFOAM Meshing & Mesh Conversion 23 January 16, 2009 06:12
user defined function cfduser CFX 0 April 29, 2006 10:58
