error on a case with cyclic BC after a good checkmesh |
Miles
Rep Power: 14 ![]() |
p { margin-bottom: 0.21cm; } Hi
I have convert a fluent mesh with internal baflles. I have convert them in cyclic BC with the createBaffles utility. I have done a checkmesh : everything was fine. Now i run the case in parallel and I have this type of error : Can anyone help me please. Regards, Create mesh for time = 0 [10] processorPolyPatch: ![]() [10] [10] [10] --> FOAM FATAL ERROR: [10] face 0 area does not match neighbour by 76.9523% -- possible face ordering problem. patch ![]() Mesh face:34207 vertices:3((0.982212 0.183 0.522319) (0.987211 0.183 0.520419) (0.984341 0.183 0.525431)) If you are certain your matching is correct you can increase the 'matchTolerance' setting in the patch dictionary in the boundary file. Rerun with processor debug flag set for more information. [10] [10] From function processorPolyPatch::calcGeometry() [10] in file meshes/polyMesh/polyPatches/constraint/processor/processorPolyPatch.C at line 211. [10] FOAM parallel run exiting [10] [9] processorPolyPatch: ![]() -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 10 in communicator MPI_COMM_WORLD with errorcode 1. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- [9] [9] [9] --> FOAM FATAL ERROR: [9] face 0 area does not match neighbour by 76.9523% -- possible face ordering problem. patch ![]() Mesh face:34943 vertices:3((0.981248 0.183 0.517581) (0.984847 0.183 0.511895) (0.987211 0.183 0.520419)) If you are certain your matching is correct you can increase the 'matchTolerance' setting in the patch dictionary in the boundary file. Rerun with processor debug flag set for more information. [9] [9] From function processorPolyPatch::calcGeometry() [9] in file meshes/polyMesh/polyPatches/constraint/processor/processorPolyPatch.C at line 211. [9] FOAM parallel run exiting [9] -------------------------------------------------------------------------- mpirun has exited due to process rank 10 with PID 23469 on node deathstar exiting without calling "finalize". This may have caused other processes in the application to be terminated by signals sent by mpirun (as reported here). -------------------------------------------------------------------------- [deathstar:23458] 1 more process has sent help message help-mpi-api.txt / mpi-abort [deathstar:23458] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages |
[Other] How to delete cells in OF based on CheckMesh? | AndTen | OpenFOAM Meshing & Mesh Conversion | 15 | July 27, 2018 06:13 |
How to setup cyclic BCs in simpleFOAM | hhuang84 | OpenFOAM Running, Solving & CFD | 14 | December 8, 2016 11:39 |
Arbitrary Cyclic beta code | luca | OpenFOAM Running, Solving & CFD | 0 | June 13, 2007 10:10 |
Recommended setup for cyclic turbomachinery computations | hani | OpenFOAM Running, Solving & CFD | 5 | January 25, 2006 03:11 |
Discretization scheme: whih one is good in my case | Julie Polyakh | Siemens | 3 | June 24, 2003 20:27 |
