Internal Compressible Flow: boundary conditions |
November 14, 2011, 16:31 |
Francesco Capuano
Rep Power: 16 |
Hi everyone,
I have some problems in setting up the proper boundary conditions for an internal compressible flow (e.g. flow through a convergent-divergent nozzle), using a generic compressible solver like rhoSimpleFoam. I have found out that many OF users have encountered the same issues, so I think it would be nice if, once and for all, we could find a solution. Tipically, such cases comprise, in addition to a wall (on which a no-slip condition is assumed), an INLET face and an OUTLET face. So the question is: what are the right boundary conditions to be set for p and U on such faces in order to reach a convergent solution? Thanks in advance. |
November 15, 2011, 09:53 |
Francesco Capuano
Rep Power: 16 |
someone who could send a converged test case for a similar flow would be greatly appreciated. Thanks |
November 18, 2014, 05:39 |
Christian
Rep Power: 12 |
Hi Francesco,
did you make any progress? I am trying to modify rhoSimplefoam as well as I am having problems with floating points due to thermal properties, maybe we can work on that together, let me know! |
November 21, 2014, 04:51 |
#4 | |
Sindre Tosse
Rep Power: 11 |
Hi, guys!
I have been working on a similar problem for the last couple of weeks (using a modified version of the fireFoam solver), and have had severe difficulties getting a correct flow field with a module with inflow/outflow. I have tried many different configurations, but what has worked for me is to use totalPressure BCs for p_rgh with a pressure gradient between the inflow and outflow patch, and pressureInletOutletVelocity for U. p_rgh: Quote:
Regards, Sindre |
November 21, 2014, 13:44 |
Christian
Rep Power: 12 |
Hi Sindre, thank you for sharing your findings, would try it out when I have some free time!
bcs, compressible flow, rhosimplefoam |
Boundary Conditions for Internal compressible Flow | xisto | OpenFOAM Pre-Processing | 26 | May 17, 2016 02:30 |
Compressible Flow over Airfoil. Boundary Conditions | jose21 | OpenFOAM | 2 | November 3, 2013 06:58 |
Boundary conditions low Mach number flow | lost.identity | Main CFD Forum | 0 | November 28, 2010 04:44 |
setting boundary conditions on internal edges | Renate Stump | FLUENT | 4 | November 7, 2008 10:55 |
boundary conditions for compressible flow | George | Main CFD Forum | 12 | March 16, 2005 09:26 |
