heat flux on boussinesq
Old   December 11, 2011, 12:18
Default heat flux on boussinesq
AV.
Andrev is on a distinguished road
Dear Foam's,
Im trying to set heat flux as a boundary condition of my buoyantboussinesqSimpleFoam case. But my solution is too dependent of the mesh resolution, as I refine my mesh the final temperature of the fluid descreases each time more.
Qflux = k*(gradT)
gradT = qflux/k ; k=0,17 , Qflux = 10000
so Im setting in the T file :
fixedWalls
type fixedGradient;
gradient uniform 58823;
Can anyone tell me what am I doing wrong ?
Thanks for the attention.
Andrev is offline   Reply With Quote
Old   December 11, 2011, 12:19
AV.
(Im considering K constant...)
Old   December 12, 2011, 02:27
romant's Avatar
Roman Thiele
romant is on a distinguished road
does the temperature become less than the temperature that you calculate with the a simple heat balance?
what kind of turbulence modeling do you use?
~roman
romant is offline   Reply With Quote
Old   December 12, 2011, 06:05
AV.
Yes, it become less then that i calculated with simple heat balance as I refine mesh.
Its a laminar flow.
Old   December 12, 2011, 06:11
romant's Avatar
Roman Thiele
Its a laminar flow.
what kind of geometry are we talking about, what is your yPlus of your first cell and what kind of fluid do u treat (Pr = 1, Pr > 1 or Pr < 1)
~roman
Old   December 12, 2011, 06:23
AV.
Its a simple rectangular channel section flow with constant heatflux on the fixed walls (4 walls), ethanol is the fluid (Pr ~ 16.5).
Sign of Heat Flux at wall Kyung FLUENT 2 February 26, 2016 16:25
Variable name for heat flux peterle CFX 4 February 13, 2014 02:21
Heat Flux at wall in a conjugate heat transfer problem Chander CFX 2 July 9, 2011 22:22
Heat Flux Wall Boundary Confusion. Joee FLUENT 1 August 21, 2010 12:20
Heat flux in ansys cfx juliom OpenFOAM Running, Solving & CFD 2 April 14, 2009 14:30
