Pipe flow in settlingFoam floating point exception
Old   December 21, 2011, 11:18
Default Pipe flow in settlingFoam floating point exception
Jochem van den Bosch
jochemvandenbosch is on a distinguished road
Dear fellow FOAM'ers,
I'm trying to simulate a two phase (sand/water) flow in a straight pipe using settlingFoam.
To start, I altered the tank3D tutorial of settlingFoam. I use a pipe mesh which I already have succesfully used with single phase flows. Unfortunately, whatever I try, I'm getting a 'Floating point exception' after 5-20 iterations. I suppose this has something to do with the boundary conditions but I cannot find my mistake. These are them. Would anybody know where I went wrong???
FoamFile
object alpha;
dimensions [0 0 0 0 0 0 0];
internalField uniform 0;
boundaryField
inlet
type fixedValue;
value uniform 0.02;
outlet
type zeroGradient;
walls
type zeroGradient;
FoamFile
object epsilon;
dimensions [0 2 -3 0 0 0 0];
internalField uniform 1.973e-07;
boundaryField
inlet
type fixedValue;
value uniform 1.973e-07;
outlet
type zeroGradient;
walls
type zeroGradient;
FoamFile
object k;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0.000259;
boundaryField
inlet
type fixedValue;
value uniform 0.000259;
outlet
type zeroGradient;
walls
type zeroGradient;
FoamFile
object p_rgh;
dimensions [1 -1 -2 0 0 0 0];
boundaryField
inlet
type buoyantPressure;
value uniform 0;
outlet
type fixedValue;
value uniform 0;
walls
value uniform 0;
FoamFile
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 10 0);
boundaryField
inlet
type fixedValue;
value uniform (0 10 0);
outlet
type zeroGradient;
walls
type fixedValue;
value uniform (0 0 0);
The exact error I'm getting is
Courant Number mean: 3.13403e+06 max: 3.03993e+10
diagonal: Solving for rho, Initial residual = 0, Final residual = 0, No Iterations 0
DILUPBiCG: Solving for Ux, Initial residual = 5.45561e-06, Final residual = 7.99833e-08, No Iterations 994
DILUPBiCG: Solving for Uy, Initial residual = 4.44506e-08, Final residual = 4.44506e-08, No Iterations 0
DILUPBiCG: Solving for Uz, Initial residual = 2.06501e-05, Final residual = 1.53366e-07, No Iterations 1001
DILUPBiCG: Solving for Alpha, Initial residual = 0.910986, Final residual = 0.00487461, No Iterations 1001
Solid phase fraction = 0.0275489 Min(Alpha) = -8.70379 Max(Alpha) = 13.7391
DICPCG: Solving for p_rgh, Initial residual = 1, Final residual = 2807.85, No Iterations 1001
time step continuity errors : sum local = -9.55556e+49, global = 9.42608e+49, cumulative = 1.72383e+57
DICPCG: Solving for p_rgh, Initial residual = 1, Final residual = 2.80816e-05, No Iterations 1001
time step continuity errors : sum local = -8.77632e+120, global = 6.77406e+120, cumulative = 6.77406e+120
#0 Foam::error:rintStack(Foam::Ostream&) in "/opt/openfoam201/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam201/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#2 Uninterpreted:
#3 void Foam::fvMatrix<double>::setValuesFromList<Foam::UL ist>(Foam::UList<int> const&, Foam::UList<double> const&) in "/opt/openfoam201/platforms/linuxGccDPOpt/bin/settlingFoam"
#5 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6"
Any help would be very very much appreciated!!!!!!
jochemvandenbosch is offline   Reply With Quote
Old   December 21, 2011, 16:03
Stephen Lucchesi
insane_alien is on a distinguished road
your courant number is going crazy. Likely the timestep is set too big. try reducing it.
insane_alien is offline   Reply With Quote
Old   December 22, 2011, 04:12
Hi Stephen, my courant number is going like crazy indeed, but when I reduce my timestep with a factor 1000! to 0.0001 I get the same message after 54 iterations.
But when I look at those 54 iterations in ParaView I see no pressure distribution (see attachment) and also no speeds... This makes me believe there is something wrong in the boundary conditions....
Time = 0.0054
Courant Number mean: 0.0418895 max: 355.16
DILUPBiCG: Solving for Ux, Initial residual = 4.47596e-05, Final residual = 7.60243e-08, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 6.83522e-07, Final residual = 8.58481e-08, No Iterations 125
DILUPBiCG: Solving for Uz, Initial residual = 9.32447e-06, Final residual = 1.20745e-08, No Iterations 1
DILUPBiCG: Solving for Alpha, Initial residual = 0.917158, Final residual = 6.78599e-06, No Iterations 1001
Solid phase fraction = 22.4908 Min(Alpha) = -117512 Max(Alpha) = 92780.4
DICPCG: Solving for p_rgh, Initial residual = 0.996912, Final residual = 0.334048, No Iterations 1001
time step continuity errors : sum local = 6.29575e+53, global = 2.09099e+53, cumulative = -6.60704e+65
DICPCG: Solving for p_rgh, Initial residual = 1, Final residual = 1.16875e-16, No Iterations 2
time step continuity errors : sum local = 2.51501e+150, global = 2.51501e+150, cumulative = 2.51501e+150
#2 Uninterpreted:
#3 Foam::multiply(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/opt/openfoam201/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#5 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator*<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/opt/openfoam201/platforms/linuxGccDPOpt/bin/settlingFoam"
#7 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6"
Old   February 16, 2012, 03:05
Matt
Matt321 is on a distinguished road
Hi Jochem, I am having a similar issue to this, did you manage to fix it?
Matt321 is offline   Reply With Quote
Old   February 16, 2012, 03:24
Hi Matt, my problem was that I set the speed in a direction perpendicular to the wall instead of parallel. But in general the problem can be solved by decreasing your time step. What solver are you using?
Floating point exception error Alan OpenFOAM Running, Solving & CFD 11 July 1, 2021 21:51
simpleFoam Floating point exception error -help sudhasran OpenFOAM Running, Solving & CFD 3 March 12, 2012 16:23
rhoPimpleFoam aborting with floating point exception (because of wrong bc p?) space OpenFOAM Running, Solving & CFD 2 October 5, 2011 05:44
floating point exception in turbulent model marco Siemens 0 December 19, 2008 11:02
Floating point exception during the initialisation Julie Polyakh FLUENT 1 January 6, 2004 23:07
