Setting up case with a moving part between to static ones
Old   January 6, 2012, 04:03
Default Setting up case with a moving part between to static ones
Onno
Kaskade is on a distinguished road
I was wondering if someone could help me out. I am trying to set up a transient 3D case using pimpleDyMFoam and GGIs, consisting of a rotating pump impeller connected to a static inlet duct and a static outlet spiral. I haven't seen a tutorial so far which explains how to hande two pairs of moving-static-interfaces, and don't know how to set them up in the dynamicMeshDict.
Also: is it correct, that the moving CellZone needs to be called movingCells? Or will the solver deduct this from the connected moving faces?
I am using OF-1.6-ext. Thanks in advance for any advice.
Kaskade is offline   Reply With Quote
Old   February 12, 2012, 14:03
Onno
In dynamicMeshDict:
slider
moving ( FACE1a FACE2a );
static ( FACE1b FACE2b );
The names can of course be chosen freely.
Old   February 13, 2012, 02:08
linnemann's Avatar
Niels Nielsen
linnemann will become famous soon enough
Using multiple rotating parts you need to use something like this
| \\      /  F ield         | OpenFOAM Extend Project: Open Source CFD        |
|  \\    /   O peration     | Version:  1.6-ext                               |
|   \\  /    A nd           | Web:      www.extend-project.de                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      dynamicMeshDict;
dynamicFvMesh       turboFvMesh;
turboFvMeshCoeffs
    coordinateSystem
        type            cylindrical;
        origin          (0 0 0);
        axis            (0 0 1);
        direction       (1 0 0);
    rpm
        cellRegion0  60;
        cellRegion1  -20;
    slider
Linnemann
PS. I do not do personal support, so please post in the forums.
linnemann is offline   Reply With Quote
Old   February 13, 2012, 02:09
linnemann's Avatar
Niels Nielsen
Did not see you only had one rotating part,
Then yes using the mixerGgiFvMesh method the rotating cellZone has to be named movingCells.
Best
Linnemann
Old   February 13, 2012, 09:32
Onno
Thanks for answering.
I think in OpenFOAM 2.1 the name of the mesh-part that is supposed to move can be chosen freely.
Old   March 31, 2012, 19:33
Jason Eason
JulytoNovember is on a distinguished road
Could you better help me to understand the turboFvMesh?
My case contains a co-axial rotor system, 2 rotors with 2 ggi's, inside a cylinder that represent the atmosphere.
1. Does it require a ggi? Or can it rotate meshes without the ggi? I see no slider info was input.
2. Is it a moving mesh? Viewing the meshes rotation is key for my case.
Debian Squeeze - OpenFOAM-2.1.x, Paraview-3.12.0
JulytoNovember is offline   Reply With Quote
Old   April 1, 2012, 01:13
Onno
Could you maybe send a drawing of your setup?
defining a term for a domain using DEFINE_ADJUST MASOUD Fluent UDF and Scheme Programming 1 September 24, 2010 05:08
Setting static pressure as the inlet BC ruined FLUENT 1 March 21, 2008 14:57
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
Moving Cascade Test Case Shukla Main CFD Forum 1 November 10, 2005 17:37
Body force - Does it work? Jan Rusås CFX 5 August 27, 2002 09:50
