Coupled Pressure-Flow Outlet Boundary Condition (Windkessel)
Old   January 23, 2012, 09:34
Default Coupled Pressure-Flow Outlet Boundary Condition (Windkessel)
torben_w is on a distinguished road
Hi there,
is it possible to use a Windkessel type outlet boundary condition with OpenFoam?
Here, P(t) depends on P(t-1) and Phi(t). How can this be done as a UDF?
The question is similar to an unsolved thread http://www.cfd-online.com/Forums/flu...indkessel.html.
Cheers
torben_w is offline   Reply With Quote
Old   February 29, 2012, 05:51
Michael Bruckner
michaelb is on a distinguished road
have you find a way of implementing the Windkessel boundary conditions in OpenFoam ?
I'd be very interested in knowing how you proceeded.
Cheers,
Michael
michaelb is offline   Reply With Quote
Old   March 2, 2012, 11:12
Vitaly
Vitaly is on a distinguished road
Hi, the previous thread read:
I'm trying to apply a windkessel type boundary condition at the outlet, which is of the form:
P(t) + k*P'(t) = Q(t), where k is a known constant
To do this, I model the outlet as a 'pressure-outlet' and use a UDF to impose P(t) on the outlet faces.
To calculate P(t), I approximate P'(t) by [P(t) - P(t-1)]/delta_t, and arrive at the closed form expression
P(t) = Function[P(t-1), Q(t), k, delta_t]
My question is:
how do I specify this equation in the UDF ?
At present, I'm using the DEFINE_PROFILE(pressure, t, i) macro,
calculating Q(t) by
density = 100; sumFlow = 0; face_t f; begin_f_loop(f, t) { sumFlow = sumFlow + F_FLUX(f,t); } end_f_loop(f, t) sumFlow = sumFlow/density;
Now, what is the best way to find P(t-1) on all the faces of the outlet ?
Is there a macro like F_P_M1(f,t) ?
I am also starting to work on this issue. I think that you can find P(t-1) using a memory macro, and I think you can find Q(t) using the code supplied. If you only have one outlet for an incompressible fluid, then Q(t) should not be a problem.
In my case, I have multiple outlets. But, I think that if each outlet has the same R and C values, then the flow split should stay the same.
Vitaly is offline   Reply With Quote
total pressure boundary problem ==> flow from outlet to inlet!! mrshb4 OpenFOAM 0 November 20, 2010 12:41
Pressure outlet in two-phase flow in horizontal 2D channel AlmostSurelyRob Main CFD Forum 0 November 17, 2010 07:32
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
Pressure Boundary Condition Matt Umbel Main CFD Forum 0 January 11, 2002 10:06
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 13:19
